Question about Whirlpool RBS305PDS Electric Single Oven
RBS305PDS single oven whirlpool
I have a rbs305pd oven, after just completing a cleaning cycle, when I select bake it only goes into broil mode. I cycled off the power and same issue. Is there a sensor it is looking at before allowing bake mode?
  • 1 more comment
  • Anonymous Dec 23, 2007
    Whirlpool oven model RB760PXYB did the same thing.
  • Anonymous Jan 01, 2008
    Same problem, Whirlpool is JUNK!
  • Lhensley Feb 02, 2008
    Yes I have the same problem. After using the auto clean the oven would not heat up. The display works but not the elements. I called Whirlpool and they basically told me I'm on my own because the oven is a little over a year old. Guess Whirlpool and Kitchenaid won't be getting my business anymore!
  • 87 Answers
Replace the electronic module.
Posted on Jun 10, 2007
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
How is my RBS305PD whirlpool oven fixed into the cabinet. I need to remove to check the TOD.
OPEN OVENDOOR AND LOOK FOR SKREW HEADS ALONG SIDE EGE OF FRAME UNSKREW AND PULL OUT OVEN
Jul 20, 2009 | Whirlpool RBS305PDS Electric Single Oven
Will only broil, then gives an F2 error
F2 Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Mar 27, 2009 | Whirlpool RBS305PDS Electric Single Oven
Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Dec 17, 2008 | Whirlpool RBS305PDS Electric Single Oven
    I ran the self-clean mode this morning. After it finished this process, I preheated the oven to do some baking, and now the oven won't heat at all.
    I am going to assume that you selected bake as you normally would and there are no faults (error code) reported. - this would mean there would not be a problem with the controller or the temperature sensor. The problem may be with only the bake circuit - so try the broil function - If the broil works then you may have a problem with the bake element or the connections to it or the relay on the controller - check the connections first then the element - If the broil does not work also then you may have a problem with the relay on the controller or the connection of the other leg of the 220v supply.
    Make a check or have someone check it and wrte me back a post here
    Regards
    Oct 04, 2008 | Whirlpool RBS275PD Electric Single Oven
    Whirlpool oven issue
    Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
    SINGLE OVEN MODEL # RBS305PDQ16
    Probably refering to a thermal fuse. This fuse opens when heat is too high. Some of these ovens had a kit where you replaced the cooling fan, fuse and shimmed hinges to correct problem. You can access fuse by removing oven from wall. It will be located on back of unit. You can try replacing just fuse. It will probably be ok for bake and broil. It may happen again during clean.
    Oct 23, 2007 | Whirlpool RBS305PD Electric Single Oven
    No heat after self-cleaning
    gain access to top of oven...pull it out if necessary. remove all panels possible and look for a wire connection that has deteriorated with high temperature. this may not be easy to see, so use a continuity meter and check across each wire-to-terminal connection. it also is possible that the over temperature fuse (or breaker) has opened. check for this also. for further help, ask me.
    Aug 10, 2007 | Whirlpool RBS305PD Electric Single Oven
    Whirlpool RBS305PDS Electric Single Oven Logo
    219 people viewed this question
    Top Whirlpool Ovens Experts
    Sal De
    Oloyede Monsuru
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
