Question about Dell 3010cn Laser Printer
Error appears 'out of paper' on a Dell3010cn
I am trying to print on a Dell3010cn Printer but nothing is happening when I go into properties it is telling me it is out of paper - The 3 trays have paper in it it is happening everyone that is connected to the printer.
    New Friend:
    Problem Solver:
  • 8 Answers
Try looking at the little blue guides inside of each tray and the tray locks on the outside of the printer. This is almost always the issue. Operator error when someone replaced the paper last.
Posted on Aug 07, 2009
  • 564 Answers
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 21, 2009
Put A4 in upper tray error
Change the printer properties to use paper from the automatic feeder tray. And, unless you are in Europe, you probably don't want to specify A4 paper. Try "letter" or some other size.
The manual is at this URL. See page 49 http://www.manualslib.com/manual/113847/Oki-B4545-Mfp.html
Apr 25, 2016 | OKI Office Equipment & Supplies
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl revert..best of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
The red light is on and appear this message: LOAD CORRECT PAPER CASSETTE. What should I do?
if this happens when you send the print job, you need to choose correct paper size under the printer properties on your pc.
Go to the printers, choose your mf4150, right click and properties, under tab preference, under page size choose correct one i.e. A4.
Turn MF off and back on and try again to print
Aug 04, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
My printer keeps telling me that i have a system error. Remover paper jam then press start but nothing happens. Help
Where does this "system error" message appear? On your printer display or on your computer screen? Try to remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges. Then load some paper. Try to print again and see if the error appears again.
May 05, 2011 | Lexmark X125M All-In-One Printer
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
Error paper output slot. the paper is jammed clear
Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
Ash
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper feeding through printer but not printing
hi! if that printer doesn't print at all,since it was configured by your computer,try to check it's properties to test the function of your printer.doing this go to control panel click printer,then right click printer,click properties.on properties click test your printer,if this printer, print but nothing appear on paper,back to your properties and go to maintenance,on maitenance click clean printer,on try deep cleaning if still doesn't print bring your printer to cannon service center to check the printer head. regards and thank's
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam error in the output does not allow printing
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printer stops at 25%
it has so many guesses like priter is doing its job perfactly but it needs some time to print...try single paper and check...
or if it is happening with single paper too check that printer is giving some error like can not print .....
if this error is coming on your printer check properties of your printer may be your printer needs something...go through these properties u can easily find missing thing...
if u need any help ask me....
chirag
Nov 29, 2007 | Dell 966 All-In-One InkJet Printer
HP 1410 all in one printer problems
Check "Low memory module" on Printer properties / Printing preferences / Advanced...
Sep 26, 2007 | HP PSC 1410 All-In-One InkJet Printer
Dell 3010cn Laser Printer Logo
69 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
