Question about HP Pavilion dv1000 Notebook
HP dv1000 fan problem
I have a HP dv1029 (part of the dv1000 series) and have a problem with the fan for which I'd really appreciate your input.
For the past few months, the fan noise has been been getting noisier than normal...and then finally the fan wasn't turning on all the time and the unit started overheating .
After Googling the issue, a couple of weeks back I took it into the service centre. They took it apart and gave it a good clean, mentioned that there was had been alot of dust accumulation and that it now no longer overheated.
However I'm now noticing that the fan is still often not swtiching on...although the unit has NOT been overheating and switching itself off as it had been before the repair - and i've been leaving it on all night at times.
Interestingly, when i turn the unit over and gently (through the grill) touch/prod the fan with a toothpick, it then begins to function again. Though this usually only lasts for an hour or so before slowly stoppping again.
I assume the bearings on the fan have gone or the fan as a whole needs to just be replaced.
My question is this...
Should I go and buy just a new fan...or a fan AND heat-sink unit? Looking at HP's part's lists, they appear to be two different units.
I'm not confident enough to take my unit apart and do the repair myself...but I do wish to save unecessary repair time by my technician. (HP's Spare Parts Centre is just near my home.)
Thanks in advance for your help and any general suggestions.
  • mountainguy Nov 25, 2008
    Hi Guys,
    Ended up just going with the fan replacement alone option and seems to be OK.
    Thanks.
    Scholar:
  • 80 Answers
Why dont you try to use little bit of spirit or petrol and clean the dust properly by brush. And than check it. and during this cleaning process kindly keep system off and when you clean it and spirit or petrol disappear completely than start the laptop and check it.
Posted on Nov 19, 2008
HP Pavilion dv1000 has a part on motherboard pd27
What is the question? You said something about the part, but did not say what you wanted to know.
Jun 23, 2008 | HP Pavilion dv1000 Notebook
My hp notebook doesnt have audio driver. i wont be able to play music or video. model: hp pavilion dv1000, intel celeron m 1.30 ghz
HI, You can go to the HP website, then click on the link for Support & Download, Then it will ask for the model of your Notebook which is Pavilion DV1000.
Thank you for using FIxya, your high recommendation is highly appreciated.
Sep 23, 2010 | HP Pavilion dv1000 Notebook
Hp pavilion dv1000 fan not working
Try to clean your fan with anti rust oil, maybe due to old age the mechanism inside your fan is already clogged.
http://podnutz-hdlaptoprepairvideos.blogspot.com/
May 26, 2010 | HP Pavilion dv1000 Notebook
How to download hp pavilion dv1000 audio drive
my hp dv 1000 laptop exact model is dv 1693 and os is vista pls tell me about perfect audio driver for this model acxept hp web site
May 20, 2010 | HP Pavilion dv1000 Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I want the replacement motherboard part number
The part number you posted on the FixYa site is correct for a replacement board. It is actually designed for the DV1300 series but will work iin many DV1000 series notebooks. If you get on E-Bay and put that part number in the search box, you will find many that are for sale and under 120 bucks. Good luck
Nov 25, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 heating problem during accessing internet.It works fine often when laptop is not connected to internet. Any suggestions is appreciated.
Try checking the fan, if you see dusts clear them out. If you have a USB fan, its highly recommend you use it. My Answers maybe incorrect, because I do not use heated laptops or PC Desktops.
Jun 05, 2009 | HP Pavilion dv2000t Notebook
My hp dv1000 laptop died and I can't reuse them
  1. Was the computerl on, hard drive accessing, fan running etc..?
  2. When your AC adaptor is connected, do you have the charging indicator ON?
Alex
Nov 02, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
486 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
