Question about ViewSonic VA2012WB Monitor
Viewsonic monitor VA2012wb is reading ''out of range''
I am just building a new system and trying to use my old monitor. I apparently set the resolution beyond the monitor's capability and now it reads "out of range" ... no picture. I have a MSI K9N2 Platinum M/B with an AMD Phenom x4 9850 CPU. I am running off the motherboard's DVI link. I have an EVGA 8600 pci-e vid card but, I cannot visualize the BIOS CMOS menus to set the board to use that slot. What can I do to restore my video ????? HELP !!!!!!
  • ukrainian Nov 19, 2008
    No other monitors available and it's 2 a.m. It would seem I need another kick-*** monitor with super resolution beyond 1900x1200 to be sure what the settings are.
    John
    Problem Solver:
  • 7 Answers
Restart the computer and as it is booting up, tap the F8 key on your keyboard. Choose the VGA mode to lower the resolution for the video card. This will allow you to get in and slowly up the resolution.
Posted on Nov 19, 2008
    Problem Solver:
  • 9 Answers
Try to use an other monitor and reset the resolution. I hope it helps.
Just purchased and installed a new ViewSonic 22" VA2231wm widescreen monitor to go with an existing Dell OptiPlex GX620 desktop computer. While attempting to get better resolution, got 'Out of...
Download: http://www.viewsonic.com/products/desktop-monitors/va2231wm.htm
You need to set your PC to the native resolution of the monitor, if it is too high, you will get out off range message: native resolution is 1920x1080p @60Hz.
You can read more here about the message:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 02, 2011 | ViewSonic VX900 19" LCD Monitor
My xfx geforce 9500gt 1gb doesnt work with my dvi single link cord to any monitor i try .viewsonic va2012wb xp pro asus mobo a8n-vm amd 3200+ 1 and a half of ram.please try to help.i get a no signal wen i...
first load defoalt setup then check vha pin check pin 12 13 vertical and horizantal sink if not come go back the signal print wich on ic change the ic if display come dvi port
if fix your problem click yes for vote
Dec 27, 2010 | Computers & Internet
My Monitor ViewSonic E70fSB 17" Monitor is working
Causes of OSD LOCK
1. The monitor is incompartible with the system unit, especially for newer version units versus older monitors
2.Older monitors display attempting to much up to the improved definition functions of newer system units display an operating system malfunction, interpreted as monitor malfunction instead. OPERATING SYSTEM DISPLAY MALFUNCTION
hardware checks
1. consider changing the graphic card on the system unit after attempting to adjust the appearance settings on the desktop once the computer is powered on.
2.Once changing the graphics card on an old system unit, consider changing the processing chip for reasons of achieving peak performance of the new part installed.
3. Once the fxing of the parts are complete, the monitor would continue to display OSD requiring entire system restart or book. after which, adjusting the appearance setting that should by which time display new list capacities due to the new device changes
Dec 06, 2010 | ViewSonic E70f 17" CRT Monitor
Upon powering up, a banner flashes OUT OF RANGE. What is the fix?
The maximum/native resolution for this display is 1024 x 768 @ 60Hz, you need to adjust your PC video resolution, it is too high right now for the Viewsonic to work. Hook up your old monitor and set the new resolution, otherwise bootup in safe mode (hit f8 key while booting up) and choose VGA support, set the new resolution, reboot.
Apr 29, 2010 | ViewSonic VA520 15" Flat Panel LCD Monitor
Turn on computer and va2012wb comes on for 2 sec then go to blank screen but if i turn off monitor and when turn it back on it come on again for 2 sec. help
Most case will be bad capacitors in the power supply, that will be the first place to check, worst case will be the lamps. See example what goes bad in LCD monitors:
http://s807.photobucket.com/home/budm/allalbums
Please post back so it may help out other people also.
Apr 09, 2010 | ViewSonic VA2012WB Monitor
How do i adjust resolution on the monitor?
in menu and go to screen resolution or you can put the monitor in auto and go to your computer in control panel and go to display and choose the resolution yopu want and the monitor support,, pls click tha my solution heltp you
Dec 27, 2009 | ViewSonic VA2012WB Monitor
Can't set 1680x1050 resolution on viewsonic monitor
I found the solution for my problem.
Initially I thought it's a monitor problem and was trying to find the drivers for it.
The problems is not with my monitor but with the video adapter I use.
My video adapter has a intel chipset (Mobile Intel(R) 965 Express Chipset Family). Apparently the driver that I was using was quite old.
The only thing I had to do is:
1. Download the latest video adapter driver
2. Uninstall the current video adapter driver
3. Restart the system (Windows XP)
4. Install the new driver.
5. Restart the system.
May 19, 2009 | ViewSonic VA2026w Monitor
Viewsonic VA2012WB monitor too much red color
I hope there's nothing wrong the the RGB circuitry. Here's what i recommend. degauss, recall the monitor. There's also a temperature setting for the monitor. Change it to COOL or NORMAL.
Mar 15, 2009 | ViewSonic VA2012WB Monitor
Viewsonic on a mac runnib osx 10.3.9
I suspect the screan isnot compatable to the other cpu.change the rete and re boot uour compueter.remember to never fix something that is not broke.
Mar 07, 2008 | ViewSonic VP230mb 23.1" LCD Monitor
Viewsonic VA2012w Wont go into standby with computer.
turns out it may be a heating problem. cut a few extra vent holes in it and seems to be fine.
Sep 08, 2007 | ViewSonic VA2012WB Monitor
Open Questions:
ViewSonic VA2012WB Monitor Logo
288 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
