Question about Samsung YP-K3 MP3 Player
Protection error my ht-tx22 samsung home theater is always turn off every 15 mins and having a problem of protection then suddently turn off.
  • Samsung Master
  • 19,396 Answers
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Yesterday my ipod was working find and about 5 min. later it stop working screen black it has no sign of working
Press home and power buttons 10-15 secs then release home button. When you see the apple logo release the power button too.
Oct 26, 2014 | Apple iPod touch
How to hook up my home theater so i can listen to my mp3 player
I don't have a picture but you probably need a Stereo 1/8" Mini to RCA patch cable. If you go to radioshack.com, search for 15-2474 and they have a picture of the cable you should need. The cable is "high quality" made by Monster and is only $4.97. To be safe, take your MP3 player to the store in case is has an "odd ball" jack instead of the 1/8" Mini which is pretty standard now. Connect the other end with the (2) RCA plugs to one of the available inputs on the back of your home-theater rig (i.e. AUX IN, MD/TAPE IN, etc.). If your MP3 player has a volume control, set the output to about half. Then, select the corresponding input on the home-theater rig and you should be good to go. Now you can control the speaker level with either the MP3's volume control or the master-volume control on the rig.
Mar 29, 2013 | Audio Players & Recorders
Hi my panasonic sa vk90d is giving me an f61 problem when i turn it on
F61 is an error code(protect error code in other brand) for panasonic home theater system. This will trigger if the unit gone to overload to avoid further damaged to other parts. This code is quite technical if your not handy with electronics. However I will say to you the common caused of this error code.
1. Output IC - this is the most common caused of the error code. Once shorts happened to this IC, it will trigger the error code. Exposure to high volume and/or running in the long time will caused this IC to shorts and produce an overload.
2. Shorted Speaker - if one of your speakers shorts, error code will appear also. This may isolate by disconnecting the speaker to the set and play the unit naked. If the symptom still there the fault came from the unit itself.
3. Shorted Inputs - inputs connector is also prone to shorts due to frequent bending and pulling. To isolate this from fault, disconnect all the inputs connected to the unit like the aux input, antenna, mic, etc.
4. Faulty power supply - once gone to out-of-regulation condition, the error code will appear to protect the most expensive parts from further damaged. Bad solder joints in this section is also to consider.
5. Faulty Fan and its circuitry - F61 will appear only after a minute of operation not upon powering on the unit. Check the fan if working or not...
I would advice you to send the unit to your local Panasonic service center and leave the expert isolate the symptoms.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 12, 2011 | Audio Players & Recorders
Speaker Problems
push the "sound edit" button on the remote, it will bring up things like, bass, center spkr, rear spkrs.. change the volume control on the rear spkrs.
Apr 09, 2009 | Samsung YP-U3 MP3 Player
My Samsung YP-U3JQP 2GB MP3 player skips past most of the tracks.
Many WMA's are DRM-protected - the DRM-protected tracks that you have loaded may not have transfer rights, even though they will play fine on a computer. The best bet is to download only songs that are in mp3 format. Another option, which is illegal, is to buy a DRM-stripper and strip your WMA's of the DRM-protection - but, it is illegal, costly, and time-consuming.
-Tha Mp3 Doctor
Feb 22, 2009 | Samsung Audio Players & Recorders
Zen 16 gig won't turn nor charge
hold down the reset button for about 1 min then leave it for about 30 seconds. once you have done that try turning it on, if it does not turn on and it is completely dead leave it pluged in to your computer by using the usb cable, leave for about 30 mins it then might start to charge, if it does start to charge leave it till it is fully charged and then it should turn on. if none of that works then i don't know.
Jan 06, 2009 | Creative Labs Zen Digital Media Player
Itouch black screen and wont turn on
I had the same problem. I pressed the power button and the home button at the same time for about 10 seconds and then the home page showed up.
Aug 05, 2008 | Audio Players & Recorders
Sansa e260 takes 15 mins turning on.
once the blue circle is there, you just need to wait, it'll turn on
if not, take it to a best buy
May 05, 2008 | SanDisk Sansa e260 MP3 Player
Error code COOD11B1
Is that problem only with the music you downloaded from Sympatio or is that with all youre music,
If it is with only with the musci from simpatio it may be right protected or something that wont let it
Nov 02, 2007 | Samsung YP-K5 MP3 Player
Samsung YP-K3 MP3 Player Logo
240 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
sonic boom...
sonic boom...
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
