Question about Compaq Presario 700 470024-192 Notebook
Monitor HP LI706 Goes of every 1 minute with an error message "monitor going to sleep" restart with a heavy fan sound
  • 93 Answers
When you said "Monitor", does it means internal LCD screen or external monitor?
Have you checked the "Power Options" in the "Control Panel"?
Posted on Nov 20, 2008
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
Everytime I turn on moniter it goes into sleep mode and won't wake up!!
If there was something wrong with the monitor itself it wouldn't go to sleep it would just turn off. It sounds to be as if there is an issue with the signal going to the monitor itself, try restarting your PC and ensure that the connection on the back of the monitor and the connection on the back of your PC are secure.
Mar 07, 2011 | HP f2105 21" LCD Monitor
My HP W1907 monitor works fine until I try to play The Sims 3 game. I play for several minutes or hours and the monitor shows the message that it is going to sleep and the light on the monitor goes...
Hi there. I had the same problem months ago when I try to play high end games like Sims 3 my monitor goes into power saving mode. I tried to check every possible causes of the problem. It could be that your computer is overheating try to clean your computer and check if your fans still works. Second it could me your power supply malfunctioning, maybe it does not meet the required power to make your game work. Last cause is your video card malfunctioning, what I did is to just buy a new video card and it works.
If you do not have spare power supply or video card you can go to a computer repair shop for them to check the possible problem that causes it to go into power saving mode. It can also save you money before you can buy a new one.
Hope this helps, Have a good day!
Oct 03, 2010 | HP w1907 LCD Monitor
HP f2105 monitor going into sleep mode on it's own
Does it do the same when you use this monitor with other PC, new VGA cable, just need to narrow down the problem first before start taking the monitor apart.
See pictures of what usually goes bad (mostly failed capacitors) with monitors:
http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further
Apr 03, 2010 | HP f2105 21" LCD Monitor
I get a message to change the resolution , but after I do that the message doesn't go and the monitor goes to sleep???
restart the computer and press f 8 and press frequently untill menu will appear then highlight enable vga mode and press enter your problem will be solved
Mar 30, 2010 | HP L1706 17" LCD Monitor
go to control panel, display properties, screen saver, turn off,
than go to power options, turn off the "turn off display" option.
Jun 06, 2009 | HP Computers & Internet
Monitor going to sleep
Please look at the video card of your computer,did you set it correctly?
Apr 01, 2009 | HP Vs17 17" LCD Flat Panel Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor goes to sleep mode quickly without video cable
right click on desktop - click properties - click screensaver tab, and dropdown menu to none. this turns off screen saver. For power/hybernate....
start - control panel - power options. Change all pull down menus to "never"
Problem solved.
Dec 22, 2008 | HP vs15 15"LCD Flat Panel Monitor
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
Compaq Presario 700 470024-192 Notebook Logo
200 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
