Question about Compaq Evo Notebook Keyboard N610C/N600c
Sometime my keyboard not working proberly
Keyboard not working
One.key.has.COme.out.of.order.and.some.keys.are.not.working.just.like.space.key.and.m.KEY
Posted on Mar 07, 2010
My qwerty keyboard does not work proberly
You might have to replace the keyboard. Hope you can find the item you want from http://www.etradesupply.com
Mar 02, 2013 | Samsung Cell Phones
I connected extrernal keyboard for aicr labtop whin I dissconnect it the built in keyboard for the laptop does not work proberly some keies changed like m changed to z and so thanks alot for helping
Here are some steps which you might want to try.
- Access BIOS and reload the default settings.
- Boot to Safe Mode with command prompt and test if all keys work properly.
- If the keyboard works properly in Safe Mode with command prompt, the registry inputs of your operating system are messed up. You can do registry editing (recommended for advanced users) or just back up your files and reinstall the operating system.
Hope this helps. Just leave a comment or question if you need further assistance. Thanks.
May 20, 2011 | Computers & Internet
Windshield wiper do not work on my cheeroke 1994 jeep
check fuse, and power at motor if ok proberly motor, if no power proberly wiper control relay. if wiper motor failed usually blows fuse aswell.
May 01, 2011 | 1994 Jeep Cherokee
Keyboard does not work...I have to use on-screen keyboard--which sucks!!! Please help !
Hi... If you spilled liquid on the keyboard it stops working and it has to be replaced, otherwise the keyboard unlike anything else in the laptop it does not just stop working for no reason unless the interface on the mainboard is the problem but then again if that is the case it will not be just the keyboard... You may also want to check if it is connected proberly, there should be few screws in the bottom of the laptop (not all screws) that you can remove and with a thin flat screw driver try to pull the keyboard off, be careful not to damage it or the pc and not to pull it very far, it should be somewhat attached with a wide flat cable... check the connection of that cable and maybe remove and reconnect to be sure, turn the machine on and check if anything happend... hope that helps, if not then maybe you can replace or use an external keyboard... Best of luck
Jan 29, 2011 | Dell Latitude E5400 Laptop
The @ key does not work
either ita a dirty contact under the key or its failing, proberly easy to replace keyboard, or give it a clean up
Nov 18, 2008 | Computers & Internet
The bottom half of the picture goes black intermittently. sometimes it resolves itselt, sometimes you have to smack it
that you have to " smack it " could mean that a cold solder joint on the board proberly out of the vertercial output. To test, while the TV is on use a long plastic or wood tool and push on the board. Sometimes you may have "resolder" EVERY joint, ground, wire connection in that circuit.
Jun 14, 2008 | Philips Televison & Video
Color cartridge
that is most proberly a defective cartridge packermary you need to try another cartridge if it works then return the defective cartridge or else try cleaning the head on the cartridge by using alcohol or spirits and wiping the pins on the cartridge head & the coper part of the cartridge.
Apr 18, 2008 | Dell Inkjet 720 Printer
Logitech Keyboard
Press Ctrl+Alt+F12.
The green light on the keyboard starts blinking.
Press the connect button on the wireless sender then on the bottom of the keyboard. Do it twice if necessary.
The keyboard should do it now.
Do not ask me why ...
Oct 09, 2007 | Logitech Computers & Internet
Keyboard and mouse work only intermittently
yeah.. maybe you have a defective keyboard.. better look at your warranty now..
Sep 30, 2006 | Macally IKEY Keyboard
Computers & Internet Logo
278 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
