Question about GPX DV7500 System
Gpx dv7500 dvd player will not power on
It has been working fine for a couple of years, not used too often. Today we tried to turn it on. It powers up for a few seconds and then turns off permanently. It does this once each time it is newly plugged in . Never had an appliance that behaved this way. We just watched a dvd a few days ago. thanks for any advice
    Problem Solver:
  • 6 Answers
I've seen this problem before with devices that have audio amplification circuitry.
In the cases I've seen, the connections to the speakers were the culprits.
First of all, you should only use the GPX speakers that came with the device. I don't know what their impedance is, but if it was 8ohms, you should only use 8ohm speakers. The same for 4 ohm, 6 ohm, etc. The safe bet is to use the speakers that came with the system.
If you are using the intended GPX speakers, and they're hooked up correctly, (only one speaker per output) then I would suspect a short in at least one of the speaker wires.
Amplification circuits apply fluctuating power to the speakers which correlate the sound wave. The power reaches the speaker, has an electromagnetic effect on the speaker cone, which pushes it out or pulls it in. This produces sound. The speakers job is to be affected by the amplifier, and convert the electric power into a mechanical movement. Speakers of different impedances respond to different levels of power. Ideally, your amplifier will supply power to speakers that will use it all up and return none.
An amplifier designed to drive 8 ohm speakers will get too much kickback from little 4 ohm speakers. When I've seen this sympton before, the amplifier had another circuit designed to monitor dangerous conditions such as this and shut down to prevent permanenet damage. Another dangerous condition might be a short in one or more of the speaker wires. Inspect each and make sure none got stuck under the table, or slammed in a drawer or pinch by a staple or whatever.
--Matt
Posted on Nov 02, 2008
Don't buy Chinese **** and you won't have problems like that
Posted on Mar 21, 2008
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
GPX DVD player flashing power light
Ihave a GPX portable dvd player that has a broken charging jack on the unit itself. The model is a GPX 808.
Mar 11, 2009 | GPX D1816 DVD Player
No output from DVD/CD player to TV
Best bet/least effort is to get a newer, slightly more robust DVD player. This unit sells for less than $30. It costs more to ship it over from China than it does to manufacture the player. No kidding! For an ultra-cheap DVD player I'd go with a ~$35 player from wally world. Best of luck.
Feb 27, 2009 | GPX D1816 DVD Player
GPX portable DVD model PD808B - wrong region message
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can now choose between regions on the screen. Select the desired region unlock and press 'enter'. This works well!
Benony Jonsson
Feb 20, 2009 | GPX PD808B Portable DVD Player with Screen
GPX Model D1816 DVD Player
This looks like a power supply problem. I have the same unit with the same problem. I measured the DC voltages coming out of the Power Supply Card inside the unit and they drop down when the power switch is pressed, just when the driver motor starts to run.
Mar 18, 2008 | GPX D1816 DVD Player
Dvd GPX cannot find the remote code for it
I need to program a universal remote with my GPX DVD player
does anyone know the 3 digit code?
Jan 03, 2008 | GPX D1816 DVD Player
Freezing
sounds like a bad solder joint that is cracked...as GPX heats up, the crack starts to get bigger and cutting off electric circuit, then cool down closes the gap and current resumes. First try breaking and then making all possible connections outside then inside unit. Then, if no success, remove the circuit board and clean it with alcohol and brush then carefully look at each solder joint with a magnifying glass. If one found, simply re-solder it.
Nov 27, 2007 | GPX DV7500 System
GPX DVD player w/surround sound
Have you opened it first and looked for a blown fuse. I suggest you unplug the unit and first look for a blown fuse. If this does not help, go to the retailer or the store where you purchaced the unit and see who they send them to for repair. Good Luck
Mar 19, 2007 | GPX DV-1010 DVD Player
Wont turn on
sounds like you gotta power supply problem in the main unit. to repair this your gonna need a service manual most likely or you have to take it in to a repair shop to estimate for you .. if you post a schematic we will assist you in trouble shooting if you have any previous experience. Good luck.
May 02, 2006 | GPX DV7500 System
Progressive Scan Mode Resetting
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
Jan 14, 2006 | GPX DV7500 System
GPX DV7500 System Logo
377 people viewed this question
Top GPX Audio Players & Recorders Experts
Joe Negus
Joe Negus
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
