Question about Canon PowerShot A20 Digital Camera
How to replace battery door?
Ugh...I'm stumped. I got the replacement battery door for my camera but can't figure out how to take off the old one and put the new one in place. Any help would be appreciated. Thanks!
I just replaced my battery door. You have to take every screw out of the camera. I used a philips eye glass screw driver. Then, pull the front and back covers apart carefully, its only plastic. There is a pin that holds the door to the rear cover. If you push the battery door button back and fourth the pin will start to show out the side of the camera. I pulled it out once it showed with small pair of needle nose pliers. Just reverse the procedure to install the new door.
Posted on Aug 20, 2008
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
Kodak CX6200 Battery Door Replacement
Link to purchase of battery door with instructions
Dec 05, 2007 | Kodak EasyShare CX6200 Digital Camera
The camera won't turn on. It's not the AA batteries but could it possibly be the small watch battery in the camera? I'm stumped because the camera was just sitting in a camera bag and is only a year old.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Apr 23, 2010 | Canon PowerShot A570 IS Digital Camera
Battery door replacement
Does this mean you have a replacement door already?
If so, you will need to figure out how the camera comes apart. This is not always easy to do. I suspect there will be screws or snaps hidden. Improper dis-assembly will cause damage to the case and/or finish.
I would contact Canon and ask if there are any repair shops near you that they could recommend.
Joe
Mar 08, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Remove battery door of Canon A630
This is an old A70, but the way it's done is very similar as I don't think this has changed much over the years. It's a pin design that you have to push out with a stiff unbent paperclip. You push in on the side with the smaller hole. To access the pin you'll need to remove the front and back case covers. See the following:
http://blog.thustra.com/2007/03/canon-a70-ir-modification.html
Jun 19, 2009 | Canon PowerShot A540 Digital Camera
Rplacement battery door
the battrery door if still connected you can use a small strip of crome duct tape it blends in with your camera . close the door the best you can and tape it! good luck
Aug 23, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Broken battery door
This guy on eBay - Darntoothysam has them for replacement/repair
http://cgi.ebay.com/Kodak-DX6340-DX-Camera-Parts-Repair-BATTERY-DOOR_W0QQitemZ250155840074QQihZ015QQcategoryZ64352QQcmdZViewItem
Nov 13, 2007 | Kodak EasyShare DX6340 Zoom Digital Camera
Battery/Camera problem
Return the battery to Radioshack and try another brand of replacement battery. It is possible that the Radioshack battery is in stock for a long period of time. batterries have limited shelf life and it gets worse if they are left discharged for a long period of time.
May 28, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Replacement Battery Cover Assembly
If you're handy, you can replace it in about 3 minutes. Don't attempt it unless you're willing to risk tearing a thin flexible circuit under the rear cover. Looking at the camera from the rear, remove the screws on the right hand side ( 2 ? ) then the screws across the bottom - open the card door, remove the card, and wedge a knife blade between the front and rear cover halves - the card door will be loose with an attached spring coming free. No need to remove the rear housing completely, just enough to expose the tracks for the battery cover hinge. Remove the old door, noting the position of the opening spring at the hinge, by angling one hinge out first. Insert the new battery cover and the card door in reverse order.
Dec 05, 2006 | Kodak EasyShare CX7430 Digital Camera
Replace Battery Door
you may have to remove a few screws and seperate the case a little to slip it in. Some plastic is flexable and it can give a little. If it doesnt look broken that could be good.
Apr 14, 2006 | Olympus Camedia C-740 Ultra Zoom Digital...
Canon PowerShot A20 Digital Camera Logo
970 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
