Question about Spidem Trevi 'Exclusive' Espresso Machine
Red Light Blinking (Spidem Trevi Exclusive)
We just got this machine and we are not very familiar with that. A lot of times, when we try to have an expresso, the red light keeps blinking and not allow us to have that. What does it means?
Thank you
  • 7 Answers
SOURCE: Gaggia Trevi or Spidem Trevi
You may have a legitimate mechanical malfunciton but sometimes the simple solution is the right one! The chute on this (and other) superautomatic does not like the oily residue that beans inevitably leave. All it takes it gently putting one or two fingers into the bean hopper as the grinder motor starts to sound louder/faster (this is caused by the grinder motor being under less load/strain because no beans are feeding) and wiggling for 1-2 seconds. If you do this immediately after hearing the grinder motor's rpms increase you will not get a "fill bean hopper" error message2.gif. No hard pushing is required, just a gentle wiggle. There is a shroud over the actual bottom of the hopper, so you don't want to stick your fingers beyond that. If you are concerned about actually sticking your fingers into the hopper while the grinder is running, you can simply push down on the top of the beans with gentle pressure which will in effect force the beans down and accomplish the same thing. This technique + regular cleaning of the grinder may be all you need. Hope this helps! Tony
Posted on Jan 04, 2008
mirran
  • 515 Answers
SOURCE: Spidem Trevi Water Problem
I think it´s your boiler that is leaking, if you don´t decalcify the machine regulary this will happen.
Posted on Jul 11, 2008
mirran
  • 515 Answers
SOURCE: How to Prime Spidem Trevi Combi Plus Espresso Machine
Open the steam knob on the side and make a cup of water (Tea).
Best regards
/Mirran
Posted on Oct 26, 2008
SOURCE: Spidem Trevi-the water is not traveling through the machine to allow the machine to make the espresso.
hi, i have a trevi i bought used with no manual and had problems starting with it, i found an airlock stopping water flowing, i held the water bin over the sink and pressed the valve on the bottom until water flowed out, i do this now when filling the bin and have not had any problems so far. i am still trying to find a copy of manual. i hope this may be your problem as it is easy to remedy. col.
Posted on Feb 04, 2009
SOURCE: Instructions
http://www.partsguru.com/TreviAutomatica.html in this web page, you can find a lot of things about the TREVI automatica, even download the instruction manual,the parts draws, how to emsamble, and many things more, but just in case, the page for the manual in different languages is :
http://www.partsguru.com/user/TREVI%20AUTOMATIC.pdf , I hope you can fin all that you need here.
Posted on Mar 17, 2009
Green power light only on trevi exclusive
When power is turned on, the coffee selection button should blink during warming up. If it is not blinking then the following i possible:
1- The electronic sensor is bad. It is clamp mounted on the boiler to sense temperature and send message to control board to turn the heating off when it is ready to make espresso. The blinking light will be fixed to display this.
2- The heating element on the boiler is bad and not heating. The electronic sensor cannot relay any temperature as it is.not sensing the heating.
3- The electronic control board is bad and not sensing the temperature.
The machine should be opened up to test the sensor or the neating elements, and replace what is bad..
Aug 31, 2014 | Spidem Trevi Automatic Espresso Machine
Can I use coffee cleaning tablets with a Spidem trevi digital plus
I would not use this product unless you exactly know what it is, and if it's appropriate for your coffee machine. Instead get some Saeco decalcifier powder DEZCAL that you add to your water and follow your machine instruction on how to decalcify.
Nov 24, 2012 | Saeco Spidem Trevi Digital Plus Fully...
The decalcification light stays on constantly.
I had the same problem with Spidem My Coffee with no instructions how to turn the light off. used the Saeco instruction and solved.
simply press the steam button for 6 seconds and the light will turn off
Jan 03, 2010 | Spidem Trevi Anthracite Espresso Machine
Gaggia Trevi will not heat up
check reset buton on tank,or maybe element dont work or computer board
Jul 20, 2009 | Spidem Trevi Anthracite Espresso Machine
Spidem trevi digital plus coffee machine not working as it should
it sounds like you need to go into the programing mode. in there you can set the machine so it grinds when you select coffee. at the moment it is pregrinding this is so you can make lots of coffees 1 after the other
Jan 27, 2009 | Spidem Trevi Digital Coffee Maker,...
Best regards
/Mirran
Oct 23, 2008 | Spidem Trevi Automatic Espresso Machine
Instructions
Sep 03, 2008 | Spidem Trevi Automatic Espresso Machine
Spidem trevi exclusive
you have probably removed the tray during the time the brew unit was transporting the coffee. by removing the tray you stopped the transporting unit halfway in this process.
You can solve this by putting back the brew unit. Close the machine Do not put back the dump tray. Look into the machine, at the spot where the dumptray should go. There is a litte slot in the back. but put a little spoon or some small screwdriver into this slot. You can hear the machine finish the transporting cycle. After that you can put back the dumptray and it should work again.
May 12, 2008 | Spidem Trevi 'Exclusive' Espresso Machine
Coffee Makers & Espresso Machines Logo
83 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
ray gallant
nikolay nikolov
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
