Question about Car Audio & Video
Radio power is on,no volume
By mistake,I removed the faceplate. when I replaced it. I could not get any volume.
    Problem Solver:
  • 8 Answers
Ok mate wat radio do u have there mate
Posted on Nov 21, 2008
Street glide
Press the audio button, select volume, use the up / down arrows on the faceplate
Jul 11, 2013 | Harley Davidson 426290 AM/FM Radio
I have a 2005 Scion XB radio system. The volume down button is stuck in and won't work. I tried to ''pry'' around it to try to free it, but it's like there is a spring inside that is missing. How do I...
Take the radio out and remove the faceplate. Spray a little wd40 on a cloth and wipe down the inside of the faceplate. Worked for us like a charm.
Mar 08, 2010 | Pioneer Car Audio & Video
Another one with Faceplate buttons not working?
The capacitors in these plates tend to burn out quickly for being so hot and lack of air cooling circulation. You can test all connection pins on the deck and faceplate with an ohmmeter in ohm setting to see which pins is not sending 25-30 ohms or 5 volts of power
Oct 23, 2009 | Pioneer DEH-P3500 CD Player
Same problem with volume control
I had this problem. The jog dial just stopped functioning. I repaired it by doing this:
1. Remove the batteries and leave the battery cover off.
2. Remove the case screws from the radio using a jewelers sized Phillips screw driver. There is one screw inside the battery compartment.
3. Gently separate the two halves of the radio just a few inches. Remove the wrist strap; it will just be laying over top of a screw post.
4. Inspect the wring of the jog dial. You will note several wires soldered to the dial, including one small bundle of wires leading from the jog dial to a white plastic connector on the faceplate of the radio.
5. Study the bundle of wires from the jog dial to the faceplate. Is it twisted? Has it been crimped inside the case? Smooth and straighten the wires with your fingers gently. Remove severe bends.
6. Detach the small white plastic connector from the faceplate and untwist and smooth the wires. The connector should slip off easily. Now clean the metal pins that the connector mates to with a Q-Tip. Seat, remove and re-seat the connector 3 times to scrape off any built up corrosion. Ensure the wire bundle is smooth and untwisted and reattach the connector.
7. With the radio still apart, reinstall good batteries. DO NOT USE AC POWER! and check that you have returned the proper function of the jog dial.
8. Reinstall the wrist strap over the top corner post and carefully mate the two halves of the radio together. Continue to test and check the jog dial as you seat the halves together. Reinstall one or two case screws at a time, checking that the dial still functions until the radio is fully reassembled and the case is tight.
Jul 18, 2009 | Kaito KA1103 SW/FM/AM Radio
Buttons stopped working
The contacts on the faceplate or radio are dirty. Remove the faceplate and thoroughly clean the copper contacts with wet Q-tips in alcohol. Also clean the ones on the radio.
May 24, 2009 | Pioneer DEH-P6600 CD Player
System lights up - stuck in demo mode - sometimes CD player plays
if detach face may not be making good contact try removing wipe connections w/rub alchol and put back on
Mar 26, 2009 | Aiwa CDC-X444 CD Player
Display doesn't illuminate on flipdown faceplate
Has unit gotten very cold lately? If faceplate is removable, remove it and clean the brass terminals with a CLEAN pencil eraser, wiking sure to blow off any rubber "crumbs" when finished.
Mar 10, 2009 | Car Audio & Video
Jensen MP5720 radio/faceplate connector is broken or missing spring
I was always afraid this might happen to me so I never removed the faceplate from the radio. This strategy worked fine for two years until two weeks ago. I didn't lock my car because of the freezing rain and somebody stole my faceplate and remote. Anyway I ordered a replacement radio from Amazon last week so I don't have rewire a new one. The replacement cost me $100. I don't really need the rest of the radio so make an offer, my email is cs1713@sbcglobal.net
Regards, Chas
Sep 18, 2008 | Jensen MP5720 CD Player
Faceplate not working
Try disconnecting the unit completely.
Nov 09, 2007 | Sony CDX-F7700 CD Player
The radio plays the CD but the faceplate is dead
Maybe the radio need to be reset. Try disconnecting the battery cable for 5 to ten minutes. If that does not work, the radio will need to be serviced or replaced. Good Luck
Jun 12, 2007 | Pioneer DEH-P4700MP CD/MP3/WMA/WAV...
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
