Question about JVC Car Audio & Video
No instalation manual electric arial wont extend been instaled as a replasement to original radio by previous owner of Prajero wires look like bunch of spagetti
  • 226 Answers
Please could you supply the make and model of the replacement radio and the model and year of your Mitsubishi Pajero. I'll then do my best to help you out.
Posted on Nov 20, 2008
I have a 2000 night train where the previous owner disconnected blinkers. fronts are gone but would like to hook up rear. will rear blinkers work if the fronts are not installed. Also speedo has been...
Yes, the rears should work but, if the front wires haven't been capped properly you might blow a fuse. Not sure about the speedo but, you'll have to determine how it was installed originally and where your electrical hookups are.
Jan 16, 2014 | 2000 Harley Davidson FXSTB Night Train
Honda civic gli radio replacement won't work
Dannielle, if the previous owner installed the radio, it must have worked. It is possible that error code may have no connection with the replaced radio which may work when connected to battery. It depends on the complexity of the new radio. If it is simple, s/b ok.
Jan 03, 2014 | Cars & Trucks
I have a several problems whit the electrical installation
there is lots of wiring diagrams
wich one u need
May 08, 2010 | 1993 Chevrolet Lumina APV
My 325i 2001 radio doesn't have good reception to the radio? how can i fix this
check behind the head unit if the arial cable is pluged in or damaged, then see if u cn follow the wire to the rear of the vehicle far damage, also check of its a motorised arial make sure it extends. beware if its a factory unit like Becker, ull need a security code if the power is disconnected that you can only get from BMW
May 03, 2010 | BMW 02+ 3 5 X5 M3 Series Car Radio Wiring...
My 2001 Honda accord has a radio wont shut off!
If this is an aftermarket radio, they hooked it up wrong when they installed it. Either way, this is a wiring issue. Remove the radio and make sure the wiring harness is corrected before installing again. Good luck!
Nov 05, 2017 | 2001 Honda Accord
1995 toyota tacoma stereo installation - yellow 12v wire and red power wire - where do I connect these? Original radio was removed by previous owner. Factory connector cut but I have all wire showing. I...
Yellow (module memory) 12v wire needs constant power... any "always on" circuit in your car. Red power wire can be connected to your AUX fuse on your fuse panel.... or to the red power lead that powers your original radio.
Oct 12, 2009 | Pioneer CDJ-1000 CD Player
I have a BMW 318i 1993 and when i got it there was a big speaker and amp hooked up. I unhooked it but now i cant get any sound....the radio lites up but no sound. i know speakers work cuz they worked...
Hello pinkpimpin20,
Without knowing exactly what modifications were made to the factory sound system, it's difficult to point you to a particular fix. The number of channels on the "big amp" that you disconnected would help. Even the make and model.
But, from your description it's possible that the previous owner installed a multichannel amp to drive both the "extra bass speaker", usually referred to as a subwoofer, and the original vehicle speakers. In that case, the speaker wiring from the head unit (receiver) was cut and the receiver side of the wires was rerouted to the input of the aftermarket amp. The output of the amp was then connected to the other ends of the speaker wiring.
To restore to the original, you need to pull the stock receiver and resplice the wiring. If the previous owner cut the plug completely, it may be necessary to purchase a replacement from your BMW dealers service or parts department. It's possible, but not likely that the previous owner used both an aftermarket "harness" and an aftermarket "reverse harness" to avoid having to cut the wiring. In that case, all you'd have to do would be remove them and plug the radio harness back into the vehicle harness (or the back of the radio). But most DIY audio enthusists don't mind butchering the vehicle wiring. And you'll probably find that electrical tape was used to secure the wiring. After a year or so under the dash, it'll be a sticky mess to unravel.
The speaker wiring colors for the '93 318i are as follows:
Left Front Speaker Wire (+): Yellow/Red
Left Front Speaker Wire (-): Brown/Orange
Right Front Speaker Wire (+): Black/Red
Right Front Speaker Wire (-): Brown/Orange
Left Rear Speaker Wire (+): Yellow/Black
Left Rear Speaker Wire (-): Black/Orange
Right Rear Speaker Wire (+): Blue/Black
Right Rear Speaker Wire (-): Brown/Orange
Hope this helps.
Sep 24, 2009 | Jensen Car Audio & Video
Original radio wiring harness
Google Volvo wiring diagram. They are available free. The diagram shows the wire location and colors. Otherwise, run a continuity test with a simple meter to discover a connection with some resistance between a pair of wires. If you here a click or two, from the speakers, you have found the right pair. Continue and label the pairs left, right, front,rear, until all are identified. Then reconnect. A pain but not rocket science.
Nov 06, 2008 | 1991 Volvo 240
Automatic electric arial wiring
To my knowledge, Pioneer uses the blue wire to provide the +12 to power antennas.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Car Audio & Video
Car Audio & Video Logo
81 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
