Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Fridge freezer is not freezing
Every thing works ok its just not freezing
  • Anonymous Nov 22, 2008
    Keeps alarming and is gradually defrosting.Seems that the freezing component has given up.
    Problem Solver:
  • 12 Answers
Try cleaning out the condenser coil with long reach brush. It is underneath the doors behind the grill. Also make sure the condenser and evaporator motors are running.
Posted on Dec 01, 2008
Fridge warm and freeze cold
Rachael, I recently had a similar issue. Unfortunately, the problem you describe could be related to several components & sensors that could have failed which cause similar symptoms. There are a few things that you will need to start with in order to best lead you in the best direction for repair. First, ice building up says that there may be a problem with the auto defrost cycle. Usually a sensor that sits on the evaporator in the freezer side. You want to start with actually measuring the temp in the freezer and the fridge. If you can, remove items, turn fridge off & then unplug fridge from outlet. Let sit overnight with doors open. Two goals, here. One, ensuring that any ice that has formed in the air passages has a chance to melt completely. Second, unplugging the fridge helps "reset" the control module. You stated "hearing the motor" working. Do you mean the compressor or the fan in the fridge. IMPORTANT, you need to make sure that when the fridge is "running" that you can feel air blowing in the freezer & fridge section. Do this before turning off & unplugging. Lastly for now, did anything out of the ordinary happen before you noticed improper operation?
Jan 15, 2014 | Frigidaire Refrigerators
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sep 21, 2017 | Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
Fridge is freezing
My fridge is freezing things: Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
A tip from Gerard in Georgia: My Sears ( Frigidare built ) refrigerator suddenly started freezing thing in the refrigerator compartment. I started to replace the cold control, not having found any other problem, when I discovered that the plastic air deflector at the top rear of the frig had been knocked off. I replaced it and all is OK. I thought you might add this to your suggestion list. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly. Luckily, I found this before rushing out to purchase the control.
Take care.
Jun 25, 2010 | Refrigerators
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Things freezes up in the refrigerator section of the home frige
If fridge is freezing, check the door seal on the freezer part. Make sure it is completely sealed, The freezer can leak air, allowing motor to pump freon continuously to fridge.
If the seal looks ok, try turning down fridge temp. If you have done this already, than I would look into having thermostat or thermometer sensor replaced.
Jun 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
Freezer not freezing solid. Pulled off back
Your not going into defrost, the fridge cycles into defrost every 8-10hrs for approx 20mins....problem could be multile items, the defrost time, defrost thermostat, or the defrost heater, will need a meter to ohm heater and thermostat...thermostat will be a closed circuit when it gets below 22degrees. ohm the heater out...if both check ok, will be a timer issue. Can do a simpler check....in the fridge section near controls there is a smal hole with a gear on the inside....that is your defrost timer. take a falt tip screwdriver and turn that gear until it clicks, this will put the fridge into defrost...if everything on the heater side is ok you will hear a sizzle from the ice melting
Jun 09, 2009 | Amana ABB1921DE Bottom Freezer...
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Fridge is freezing things when temperature guage is on
check damper control or refrigerator door (ajar)
Apr 07, 2009 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
