Question about Adobe Acrobat 7.0 for PC
Set default bookmark setting to: action zoom-level ''inherit zoom''
I work in adobe 7. When creating bookmarks I can get them as zoom-level: custom, fit page and fit with, but whatever I do I cannot get adobe to make every bookmark inherit zoom.
I create bookmarks by inserting bookmark (shortcut or clicking on options) I have tried to set it correct and tell it to use this as default but it will not take over the action settings. If I have my view as fit with it will create bookmarks as fit with.
What do I have to do to make adobe set it as inherit zoom?
Jolanda
Diamond E
  • 57 Answers
SOURCE: adobe photoshop 7
yes 1 choose the filter mosiac from the filter menu. 2 choose any options form your window 3 choose "ok" in your special filters you will find the following Pixelate: Color Halftone, Crystallise, Facet, Fragment, Mezzotint, Mosaic,Pointillize. of course you will choose Mosiac. you may want to down sample your photo to 300 dpi then adjust your brightness and contrast to your desired likeness. You can also change the grayscale doing this.
Posted on Sep 14, 2007
SOURCE: Getting a message about and error on page.
Dear Wendy,
This can happen because of multiple reason:
a) It isn't your fault. The file publisher has not correctly made pdf or its corrupt and won't work on your system because all pdf files can be opened in almost all versions.
b)You might like to check your adobe 8.1 settings for complete installation. Have you correctly installed the program. Also check if you are able to other pdf files on your system or not.
c) you can also try an older version of acrobat, which i doubt should affect the problem.
Finally check the file extensions and password protection problems.
If that was helpful please press solved.
Posted on Nov 26, 2007
  • 75 Answers
SOURCE: create soft fade vignette in adobe photoshop 7.0
1)create the edge.
2)select the boundaries of the edge u want to soften.
3)go to select menu>refine edge, and increase the radius value and that's it.ENJOY.
THANK YOU!!!
Posted on Jun 17, 2008
  • 75 Answers
SOURCE: Adobe Photoshop CS3 Extended Automation Action set won't play
hey, there are three ways in which u can just play actions:
1)just select an action by left clicking it(actions will be located in the actions pallette.) and hit the play button on the actions pallette.
2)just ctrl+click the action in the actions pallette.
3)u can also assign a keyboard shortcut to it.Go to edit menu>keyboard shortcuts>(shortcuts for) drop down menu>choose pallette options. on the top of pallette menu are actions. click it and assign a keyboard shortcut for it.
4)to stop it, just select the action and click on the stop button on the actions pallette.
I think u have not selected a particular action to play.Please do it and see.THANK YOU!!!!!
Posted on Jun 28, 2008
Witchunter
  • 98 Answers
SOURCE: Cannot Create PDF from Word Document Using Adobe Professional 6.0
You can try to create PDF file directly from Microsoft Word. Adobe Acrobat Professional installs a virtual printer on your computer. Print the document from Microsoft Word, but make sure you select appropriate printer from the list. It should be called "Adobe Acrobat PDF Printer", or similar.
Posted on Jan 15, 2009
Refresh is not on tool bar
Make sure that toolbars like the "Navigation Toolbar" and the "Bookmarks Toolbar" are visible.
  • Firefox menu button > Options
  • View > Toolbars (press F10 to display the menu bar)
  • Right-click empty toolbar area
Use Toolbar Layout (Customize) to open the Customize window and set which toolbar items to display.
  • check that "Bookmarks Toolbar items" is on the Bookmarks Toolbar
  • if "Bookmarks Toolbar items" is not on the Bookmarks Toolbar then drag it back from the toolbar palette into the Customize window to the Bookmarks Toolbar
  • if missing items are in the toolbar palette then drag them back from the Customize window on the toolbar
  • if you do not see an item on a toolbar and in the toolbar palette then click the "Restore Default Set" button to restore the default toolbar setup
Mar 23, 2014 | Computers & Internet
I deleted all my bookmarks from chrome accidently, i wish to restore all my bookmarks, i have around 2000 book marks
You should be able to see your hidden folder , so that you can see the Local settings folder.
For Xp user's, Go to : C:\Documents and Settings\Administrator\Local Settings\Application Data\Google\Chrome\User Data\Default
For Vista user's, Go to : C:\Users\Administrator\Local Settings\Application Data\Google\Chrome\User Data\Default
You can see a file named 'Bookmarks.bak' . May be you can make a backup copy of this folder for safety purpose, but it works out usually. Delete the file 'Bookmark' and rename the file 'Bookmarks.bak' to 'Bookmarks'.
Sep 25, 2013 | Dell Studio 15 Laptop
How do i restore firefox as my browser?
INSTRUCTIONS
  1. Open Firefox in Safe Mode, from your programs menu or by typing "firefox -safe-mode" in Start->Run. run_safe_mode.gif
  2. Choose what you want to be brought back to its original settings by checking one of the following options:
    • Disable all add-ons: Disables all added themes and extensions.
    • Reset toolbars and controls: Removes any made toolbar customization.
    • Reset bookmarks to Firefox defaults: Replaces your bookmarks with the default bookmarks.
    • Reset all user preferences to Firefox defaults: Restores the default Options and preference settings and resets the default theme. It also changes back to default all the entries in the about:config page.
    • Restore default search engines: Adds back all of the default search engines (Google, Yahoo, eBay, Creative Commons, Answers.com, and Amazon.com fixya.com,ehow.com) , without removing any added search engines.
Now everything should be back to default, as if you just installed a new fresh copy of Firefox.
dont forget to leave your comment and tel how helpful this solution is
Oct 05, 2010 | Mozilla Firefox
Reset my mizolla fairfox tools
  1. Open Firefox in Safe Mode, from your programs menu or by typing “firefox -safe-mode” in Start->Run.
    1. Choose what you want to be brought back to its original settings by checking one of the following options:
    2. Disable all add-ons: Disables all added themes and extensions.
    • Restore default search engines: Adds back all of the default search engines (Google, Yahoo, eBay, Creative Commons, Answers.com, and Amazon.com) , without removing any added search engines.
  • Mar 18, 2010 | Microsoft Windows XP Professional With...
    Using bookmarks
    For Creative Vision M:
    Use bottom left button, <- ,to go to the top level menu and select System->Player Settings->My Shortcut Button->Jump to:->Bookmarks. After setting the short cut button to jump to bookmarks, you can then go to a previously set bookmark at any time.
    Dec 18, 2008 | Creative Labs ZEN Vision:M Digital Media...
    Accessing bookmarks from Creative Zen
    To access a bookmark or have the player jump to the bookmark you must...
    1. - Setup your shortcut button to jump to bookmarks
    1.1 - From the top level menu, go to "System", then "Player Settings", then "My Shortcut Button".
    1.2 - Set the shorcut button to "Jump To"
    1.3 - In the "jump to" menu select "Bookmarks"
    Ok so now you can easily access your bookmarks... and also the jump feature will now work :)
    2. - Simply select your bookmark and then press with the PLAY or center button to access your bookmark.
    There may be other ways, but that's the way I did it
    Hope it helps.
    DOPs
    Nov 17, 2008 | Creative Labs Zen Digital Media Player
    Firefox bookmarks toolbar menu disappeared
    In delicious menu there's a hide and show bookmarks menu
    John Lanz (jquery rotating menu)
    Oct 19, 2008 | Computers & Internet
    Setting bookmarks on Creative Zen V
    While playing the book or song click on the bottom right button, ->= ,to set a bookmark at the current location. Then use bottom left button, <- ,to go to the top level menu and select System->Player Settings->My Shortcut Button->Jump to:->Bookmarks. After setting the short cut button to jump to bookmarks, you can then go to a previously set bookmark at any time.
    Jul 14, 2008 | Creative Labs ZEN Vision:M Digital Media...
    Bookmarks in zen
    While playing the book or song click on the bottom right button, ->= ,to set a bookmark at the current location. Then use bottom left button, <- ,to go to the top level menu and select System->Player Settings->My Shortcut Button->Jump to:->Bookmarks. After setting the shortcut button to jump to bookmarks, you can then go to a previously set bookmark at any time by clicking on the top left button, ->.
    May 04, 2008 | Creative Labs ZEN Vision:M Digital Media...
    Bookmark/Save a pdf document
    You may need Quarkto achieve this, I print them from QuarkXpress v4.1 using "PrintToPDF". This works like a printer driver but it converts any blue, underlined Courier text to a hyperlink (e.g. http://www.The-Cool-Book-Shop.co.uk ) and it creates a "bookmark" link for any text which is set in a specific typeface (e.g. Helvetica 14pt bold) and secondary "bookmark" from any text set in another typeface (e.g. Verdana 12pt). So all I have to do is ensure that my required links are in the correct typeface then select "PrintToPDF" in the "Chooser" and the job is done!
    Oct 28, 2007 | Apple MA589LLA Mac Desktop
    Adobe Acrobat 7.0 for PC Logo
    977 people viewed this question
    Top Adobe Computers & Internet Experts
    Alun Cox
    Laxman Bisht
    Laxman Bisht
    Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
