Question about Toshiba CZ36V61 TV
Intermittant remote Can the infared diode in the TV go bad? My tv wont work with the remote sometimes. Ive tried new batteries and a universal remote, still sometimes the remotes wont work. If the tv is unplugged for several hours it will work for a while then quit working with the remote. The front panel buttons work fine.
  • 81 Answers
Yes they do go bad. try cleaning the inside of the remote and check for a bad solder connection with-in the remote. the key pad can get dirty from your handling maybe a good cleaning but do not scrub it just lightly touch the pad with cue tip and alcohol
Posted on Mar 20, 2007
Correct code for universal remote will not turn off tv. On the 50" digital led model ELEFT502. Original remote always had a weak signal worked only when pointed a foot away from infared reciever. Then quit...
No universal remote control will work with any TVs as well as the original ones. If the original remote control do not get range, there are two reasons for it; and can be repaired to.
1. Battery weak [Replace with new batteries]
2. The infra-red light emitting diode at the front of the remote control is weak.[Can be replaced with a new one. It can be bought from most of the electronic spare part selling shops]
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Feb 06, 2015 | GE Televison & Video
Vizio remote works intermittantly for tv M550SV, now not working at all, new batteries.
You can get a rocu at your local Walmart and use it a lot cheaper than a new tv hope this helps Merry Christmas
Dec 09, 2017 | Televison & Video
We have a proscan tv and the remote dosent work at all
try a universal remote or replace with new origional remote you can order. If no remotes work on tv, your infared sensor may be faulty
Aug 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
How can you tell if the remote sensor on a tv is broken?
First you need to check if your remote is working. You can use a digital camera to do so. First place new brand batteries in your remote and then look at the signal diode (the small transparent bulb thingy at the top of your remote). If you press the buttons on your remote you should see the diode flash. If not then there are one or more bad components on you printed circuit board or probably open circuits.
Aug 17, 2009 | Philips Magnavox Learning Universal Remote
Remote dead.
A common problem is that people tend to be rough on remotes. Dropping a remote is the most common cause of failure. This will sometimes crack the circuit board. Depending on how the board is damaged it may not be serviceable.
Sometimes, but on rare occasions, the Infared transmission diode becomes defective, or the frequency crystal fails. A TV service center can fix this if they can have the parts. Normally remotes are not supported by the manufactures for service. They will tell you to order a new remote from their parts distribution.
Jerry G.
Jul 20, 2009 | Samsung DVD-P181 DivX DVD Player
Have a new Phillips 42" lcd tv. my cable box remote has been working intermittently. However the white light near the remote sensor on the TV blinks whenever I use the cable remote. after changing bat
your TV and, your cable box both "see" a series of invisible (infared) flashes of light like morse code these flases tell them what to answer is to: buy a universal remote so that you can program a button for each device then when you want to control the cable box just push the "cable" button and, then volume etc. to turn your tv off push "tv" then "off" the service man was right but he should have explained this to you
also your cable remote may be programable to work with your tv like a universal remote check with your cable co.
May 22, 2009 | Televison & Video
Remote not working
If this TV came with an universal remote, try pressing the TV key. Sometimes it works.
If that did not work any other RCA, GE, Proscan universal should work.
Feb 07, 2008 | Proscan 26LA30Q 26 in. LCD Television
T.v and universal remote
i have a remote it is a rca and it is being used for a Daewoo tv.I need the code/model number rcr311
Dec 20, 2007 | Daewoo DTQ-20U4SC 20" TV
Remotes not working for tv
You have already diagnosed the problem,the remote receiver on the tv is bad,is rare but it happens but before you call for help try unpluging the tv from the wall for 10 minutes and then plug it back in and try it,sometimes this takes care of the problem,if that does not do it you will need the help of a servicer ,your remotes are working but the receiver is not processing the information.If you are familiar with tv service it should be easy to locate the receiver,sometimes is soldered to the chassis and sometimes is part of the push button assembly and conected to the chassis by wires,if is part of the push button is easier to replace,if you are not too familiar with tv service be safe and ask for help.
Oct 11, 2006 | Emerson EWF2703 27" TV
Toshiba CZ36V61 TV Logo
150 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
