Question about Dell E173FPc 17" TFT LCD Flat Panel Monitor
LCD monitor turns off after 2 seconds from boot
Iam having dell lcd monitor[sp2208wfp22"]. It started to flicker few days before. but it is now going blank after booting. power is ok. system is booting properly. If i turn off the monitor and turn it on again, i can see the back ground process(boot, windos load and running) for 1 second. again it goes to blank.
Please let me know if there is any fix for this.
  • maminOO Feb 19, 2009
    E173FPc LCD monitor turns off after 2 seconds from boot pc running properly
Thanks for the suggestion, I have finally found out that the back light for the monitor is culprit. Also dell people and confirmed it . They aggred for a replacement. Thanks for the suggestion again.
Posted on Nov 25, 2008
  • 189 Answers
Try to see the video card and fell if it is hot, if the fan is running when turn on. There is a part of your computer that is hot, that when reach to that temperature it trun blank or off.
Thanks
Posted on Nov 19, 2008
About a week ago my Dell 2007WFPb LCD monitor (purchased in 2007) flickered on and off PIP mode, and would not stay on one setting for PIP for longer than 2 seconds. It was not fixed and now the power...
Not the power cord problem at this point, more likely to have failed Power supply or Inverter board.
http://lcdrepair.us/2007fpw-power.html
http://lcdrepair.us/2007fp-inverter.html
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 15, 2010 | Dell 2007WFPB LCD Monitor
My computer screen flickers when you start it up what could it be
It is normal to flicker if the computer is turned on (on a cold boot), but there could be a problem on it if it keeps on flickering inside the operating system.
Dec 14, 2009 | Dell E207WFP LCD Monitor
I have a Dell Ultrasharp 1907FPV, it's a few years old. Whenever I start my computer, the moniter stays dark and the green power button does these quick flickers. Eash flicker cycle takes less then a...
You don't have a short-circuit. That would have blown the protections or even the monitor. Refer to the manual, that flashing light may be a code that tells you the problem. I don't think the repair would be expensive...
Nov 29, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Syncmaster 226CW showing picture only for a second + flickering
Call and get the RMA for your monitor, the problem is in the power supply and it will only get worse. This is a common problem with LCD monitors after 2-3 years of use.
Buddy
Corporate Computer
www.ccl-la.com
Oct 17, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Dell inspiron does not boot up
Do you see anything on screen? Dell logo? I will assume you see nothing. Not even a Dell logo.
First test your power supply with a meter to be sure it is putting out 18-19 volts. If good, remove the laptop battery and try again. The next tests should be done with the battery not connected to the laptop.
Remove the hard drive and see if it boots. If not, next remove the dvd drive from the laptop and try to boot. If no good, remove the ram, clean the contacts on the ram and the slot with a pink pencil eraser....gently, just make them shiny. Try to boot with no ram/hdd/dvd. Put the ram back in and try again. Try connecting the laptop to an external monitor.
If after all this you still cannot get a Dell logo at boot time, the mainboard is likely dead. A refurbished one (with only 90 day warranty) will probably cost you at least $250 from Dell. Please let this one go and look at a new laptop.....sorry.
Hope this helps :)
Aug 23, 2009 | Dell Inspiron 6400 Notebook
Philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
Jan 10, 2009 | Philips 170S4FG 17" LCD Monitor
Dell E193FP Problem
Probably a failing power supply
Apr 17, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
Flashing on and off
I would suggest trying another monitor to rule out your PC or monitor card. I would also check the video settings on the PC. Then assuming your cable/connector and video card are okay, it sounds like a lamp or lamp driver (a.k.a. ballast or inverter) issue. In other words, an internal issue that probably needs component-level troubleshooting.
Jan 08, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell E173FPc 17" TFT LCD Flat Panel Monitor Logo
749 people viewed this question
Alun Cox
