Question about GE JGBP26 Gas Kitchen Range
Oven will not heat up.
My oven will not heat up. The ignitor does not glow red and gas does not turn on. The ignitor on the broiler works and the broiler heats up, but the lower burner for the oven is not working. Any ideas on how I can test to eliminate parts? Thanks
  • 4 more comments
  • Eric Erb Dec 13, 2006
    Catriver,
    Thanks for your help. I switched the wires on the control board and the broiler will turn on when the oven is set to bake. This should prove out to be the ignitor. Unfortunately the two ignitors have different electrical connectors so they are not interchangeable without cutting off the old ends and putting on matching ones.
    I ordered the part and should have it on Thursday or Friday. I will post back and let you know if everything worked.
  • Anonymous Mar 13, 2014
    Oven won't heat up or broiler does not work
    Broiler does not work either
  • Anonymous Mar 19, 2014
    OVEN WON'T IGNITE....BROILER DOES
  • Anonymous Mar 25, 2014
    OVEN DOES NOT HEAT UP
  • Anonymous Mar 30, 2014
    Model 790.9601 1405
    Serial No. VF55116796
    President:
  • 878 Answers
Eerb, most likley your ignitor failed. When you turn the oven on to bake you should hear a relay click on the electronic control (clock). You can do a couple of things here. If you have a ohmmeter the ignitor should ohm out at between 50 and 150 ohms. You can physically swap out the bake and broil ignitors to see if the ignitor comes on in bake. Or you can swap the bake and broil wires on the board. They should be marked BA and BR. This way when you turn on bake, the broil ignitor should glow and verify you have power going to it. Carefull when testing, be sure to kill power to the range before any changes. Catriver...post back
Posted on Dec 12, 2006
SOURCE:
My oven is not working The Broiler works and the stove top works fine but the oven will not heat and when you turn it on no gas comes out I tried turning it on and using a lighter but nothing happens
You gave us good clues in information!-- Thanks!
Most modern gas ovens have a device called a Glow Ignitor to light the burner.
If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights:
Do you see a bright glow near the Broiler burner?
(Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like-
But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
I hope this helped.
Mack B
Jan 27, 2011 | GE 30 In Freestanding Gas Range ...
Oven will not heat cooktop works properly
if your oven has a hot surface ignitor it will be visible when looking in the broiler section of your oven if you have an upper and lower burner the bottom of oven will have to be removed to find the ignitor when oven is turned on ignitor should glow a bright red the ignitor works off 120volts if you have the knowledge and testor however a visual inspection if ignitor does not glow and part of the igniter appears white with a smaal crack line in the middle it is probbably broken at that point also if you have testor you will have a continuity reading threw the ignitor
Dec 07, 2009 | Computers & Internet
MY BROIL ELEMENT WON'T IGNITE ON MY MGS5870ADW MATAG GAS RANGE AND I DON'T KNOW WHAT PART TO ORDER. BACK ELEMENT OR IGNITER IS GLOWING RED.
It could be that the ignitor is weak and only partially heating which could be causing the gas control valve not to open and allowing the gas to flow into the broiler burner tube.
I would also suggest you see if you can smell gas to confirm that the gas supply valve is actually opening up. With the oven door closed, turn on the broiler and after 20-30 seconds of having the ignitor glowing red, turn off the broiler control and open the door and see if you can smell gas, if not it could be either a weak ignitor or a faulty gas control valve.
I would suggest that before you start ordering parts, you swap out the oven ignitor with the broiler ignitor to verify that the broiler ignitor is the problem. It could also be the broiler tube has a blockage of some sort possibly from cooking debris, that is preventing gas from flowing into the tube.
Here's a diagram for your unit along with the parts list.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MGS5870ADW&productCategoryId=0124250&brandId=3048&modelName=MAYTAG-COOKING&diagramPageId=00005&componentDescription=GAS%20CONTROLS&documentId=M0412019&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this very helpful and best regards!
Aug 07, 2009 | Ovens
Broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | GE JGBP33 Gas Kitchen Range
Oven wont heat up.
after ignitor glows burners should fire within 30-60 seconds .if not your ignitors are weak (drawing less than 3.5 amps) and should be replaced Hope this helps ,please rate my solution :)
Jun 26, 2009 | KitchenAid KESC307 Electric Kitchen Range
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
New igniter, still won't work
Turn on oven. Ignitor should begin to glow. (if no glow after 30 seconds or so, check to make sure you have 120 volts to ignitor) Observe amperage draw using a clamp on amp meter. When amperage reaches 3.2 to 3.6 (for square syle ignitors) the oven safety valve should open, releasing gas and lighting the burner when the gas hits the red hot ignitor. For broiler, just substitute the word broiler for oven. Old ignitors get " weak " and may not draw enough amperage to allow safety valve to open. Also, voltage will affect the amperage draw, as lower voltage = lower amp draw.
Nov 06, 2008 | Hotpoint RGB745 Gas Kitchen Range
Oven does not heat but broiler does
First thing to suspect would be a weak igniter....see if the amp draw while the igniter is glowing matches the amp rating of the gas valve, the value will be on the side of the valve, if the amp draw of the igniter is lower than the rating of the valve you would need to replace the glow coil/igniter.
Mar 22, 2008 | Bosch HGS 255 Gas Kitchen Range
Electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Nov 13, 2007 | GE JGRP17 Gas Single Oven
Open Questions:
GE JGBP26 Gas Kitchen Range Logo
572 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
