Question about Sony Playstation 3 (PS3) Console
Ps3 updates causing disk error
Hi there. last week i was installing latest update on ps3 i left the ps3 to it and went out , when i came back it was saying internet connection was interrupted. Now ps3 will start up ( if I leave it long enough ) for just a few min's then freeze and the screen becomes blockey and pixilated . I have contacted sony and they looked at it on-line and decided that it is a disk error and there is nothing I can do except swap it with Sony for another machine. I am reluctant to do this as I have a 60gb machine that plays ps2&1 games. Someone mentioned if I pop the hard drive into another ps3 it will re-format my H/D and this may work I'm not so sure what do you think ?
Thank you Michael
  • michael_jaki Nov 19, 2008
    cheers megadeth I shall look into that
    Scholar:
  • 151 Answers
Poppin it into another machine will do nothing. its the drive thats bad, not the machine.
U can buy another drive if u wish as they are not that expensive and worth it and u will still play ps2 games on it as the HD has nothing to do with backwards compatibilty.
u can buy a 160 gig drive for around $100 sometimes less and in ur ps3 manual it tells u how to replace it.
Posted on Nov 19, 2008
  • Jean Leblanc Nov 19, 2008
    No problem, and so u know, a HD is basically a big *** memory card, and as far as i know, if u send it to sony for repairs, chances are good they just send a a diff machine thats refurbished, so u may lose backwards compatibilty.And u have to remove ur hard drive before sending it in for repairs, check ur manual.
    Replacement HD is somewhat simple enough and i would immagine u could do it in under 30 mins.
    Good luck.
    In case ur wonderin, PS3's use SEAGATE hard drives, but any hard drive should do it.
I have a 60gb Phat Ps3. I recently went to update it to the latest firmware and it downloaded the update fine and was running normally. Then as it was installing the update, the system shut itself off...
Hello there vincent
If you have the red blinking light then you have the RED light of death AKA the RLOD.
The light is a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the RLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click Here For The PS3 Manual which has helped so many people like you.
Good luck
Best regards
Peter
Aug 29, 2011 | Sony Playstation 3 (PS3) Console
Tip
How to solve error code 8002F14E on a ps3 or playstation 3
This error code relates to an update error either the update didnt complete or it was a bad update.
If you have any warranty left on your ps3 then please dont mess about with it just take it back to where you brought it from and get it exchanged for a new one.
Below is a couple of ideas that people have used to solve this problem now the first solution i can advise you to do as it dont require you to remove any parts and does usually solve the problem, i have solved the problem that way a couple of times on peoples ps3 and it works say 8 out of 10 of the times so you can give that a try just goto the ps3 official website for your country and then you can download the updates and try a full update.
Now the second way does sometimes work but less often and messing with your hard drive means your going to lose anything saved on it and you may get errors after so i cant advise you on doing this at all as its not recomended to work but may work its all up to you at the end of the day.
try the new update first then get back to me with what happens before trying the second way ok,
Go to the UK PS3 official site and access the download PS3 updates page. Download the latest PS3 updates from this site onto a USB Memory Stick, saved in a Folder PS3\UPDATES (must be in capitals). Plug the memory stick into any of the USB ports on the PS3 and try to run the update again. I had to swith it off, and back on again numerous times still getting the same error but then for no reason it decided to complete the update and now everything is ok.
This is the second way but dont try this untill you have tried the first way several times the update may not take so you need to keep trying until it does take only do the next option as a last resort but it will format the hard drive meaning you lose everything saved on it and this isnt an advisable coarse of action.
-Open the side of your PS3 where your HDD is. Take the screw out, but leave the HDD in.
-Whenthe update begins, slide your HDD out of the slot. It will tell you an error occured and it tells you to restart your system and try again. Instead, let the count from 60 run out, your screen will go blank for aabout 30 seconds then it will start back up and tell you that your Hard Drive needs to be reformatted. Now, slide your HDD into place again, and continue with the format. You will lose all your saved data, but your console will work again.
If after trying them you still have no joy then you should contact sony and they should fix this for you for free as this isnt a fault you have caused yourself its a fault with with either their update or the ps3 hard drive so contact them and tell them your problem.
If you have any warranty left on your ps3 then take it back to where you brought it from and they will exchange it for a new one for you.
on Mar 16, 2010 | Video Game Consoles & Games
I cant update,keep getting error code 8002f994,can you give me a solution?...
Your Playstation error code (8002f994) means that too many people are currently downloading the update. I suggest you to update it later.
I hope it works! If not, please leave a reply.
Have a nice day!
May 18, 2011 | Sony Playstation 3 (PS3) Console
PS3 - Game crash followed by disc read error
The update corrupted your hard drive that's why it's not loading any disc.Yes,Restoring the system will work but it will destroy all your saved game data.Updating the system will not remove the hard disk defect.There is only one solution,Reset it.
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
My PS3 wont even start the latest system update, COD WAW (Error)
First try to update the PlayStation software itself and then update the COD.
Due to specs of PS3 soft none of updates will allow background download. and make sure that your internet connection is uninterrupted, I sugest u to use wired connection rather than wireless, and while update is in progress try to keep all other internet connection requiring equipment offline for smoother process.
Update me about your progress
Good luck
Jun 22, 2009 | Dmm Call of Duty: World at War
Carried out an update, but now stuck in loop
Procedure for Entering Safe mode when PS3 is caught in update loop:
When you first turn on the PS3, it will not allow you to go into Safe mode. You must prepare it for this.
link for flash drive prep:
http://www.us.playstation.com/Support/SystemUpdates/PS3/pc_update.html#update_PC
(This will not work for the drive that currently is caught in the update loop. You must take the hard drive out of the PS3 and temporarily replace it with another 2.5” SATA drive. Note: temp drive may need to be initialized… Connect drive to pc, right click on My Computer and select Manage… Then select disk Management… you will then be presented with a dialogue box that will assist in initializing the disk.. However, only initialize it… Do Not Format it!(waste of time) Once the disk is initialized disconnect it from external enclosure or shut down computer and remove disk)
From the top:
1.) Plug in PS3 and flip switch in back of PS3 to on. Red LED in front of PS3 should light up. Also, plug in Controller at this point.
2.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then a final beep and the PS3 will power off again and Red LED will be on
3.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then two beeps
4.) As soon as you hear the two beeps, hold PS button on Controller
a. You will then be presented with an options screen
i. Restart System -- leads back to update loop
ii. Restore Default Settings --
iii. Restore File System -- leads back to update loop (8002F14E)
iv. Rebuild Database --
v. Restore PS3 System --
vi. System Update -- will cause error
5.) You will then remove the temporary SATA drive from the PS3 and replace it with the hard drive that is caught in the update loo
6.) I am currently stuck attempting to Restore Default Settings and Im sure it will end in error, but i have to try all possible solutions.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
My ps3 games wont load after update 2.70
Yes, there have been many ps3's that have gone bad after the firmware update.
You are unable to play your discs because the Blu-Ray Lens that enables the PS3 to read Blu-Ray movies or games has gone bad.
There is nothing you can do about it. You need to take it to an authorized Sony Service Center and get the lens replaced.
Apr 05, 2009 | Sony PlayStation® 3 (60 GB) Console
Hi,i make formar the ps3 disk and i put windows xp on it.now i open the ps3 and say to me :no applicable update was found.insert storage media that contains update data of version 2.41 or later,and press...
download the file from the link below. put it on a USB stick.  If the error still comes up, please specify exactly what the error says.
http://duk01.ps3.update.playstation.net/update/ps3/image/uk/2009_0121_043067d8624040f9f3f1a8dc2e662bce/PS3UPDAT.PUP
Apr 01, 2009 | Sony Playstation 3 (PS3) Console
Hi, I got my ps3 about 2 weeks and it worked fine until last night. It's not recognizing and loading any sort of cd I'm putting in, whether it be a game or dvd.I think my kid may have changed some settings...
A PS3 dose not have settings affecting the performance. Your PS3 should still be under warrenty, so if it dosn't work, just take it back and get a new one. If you want and your willing to take the risk, you can.
Take the system apart and wipe off the lense that scans the cds, or you could just if the system can't read any disks, then connect it to the internet and look for the latest updates, and you could do this by going into the "System Update" program.
Oct 11, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
51 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
