I have a dvd video cassette player/recorder LGRC689D and the video rewind keeps stopping before it rewinds. Goes for a few seconds then stops, start it again and it stops etc. The manual is not very good.g details will get you a faster solution from experts
SOURCE: DVD/Video recorder blinking
This is an issue for this machine. It happened to me, and after some internet research, I found that JVC acknowleged it (on their web site). The unit was still under warranty, and JVC had me ship it to them for repair. It was fixed... for about a year. It started doing the same thing recently. I only had enough time to discover that I hadn't purchased any extended warranty, then the thing quit altogether. Wouldn't even power up, wouldn't eject the tape or DVD that were inside. I gave up, and took the case off to recover the tape and DVD. What I found inside was what looked like any DVD or CD drive from any computer. Since I had a case for an external IDE drive, I hooked it up to my Mac using that drive. Good news! Not only did it eject my DVD when I pushed the button, I found that my Mac with OS X Tiger recognized the drive! With absolutely NO software installation (not even a driver), My Mac now burns DVDs beautifully on that drive using Toast. At least I salvaged something really good from that piece of junk sold by JVC.
SOURCE: While rewinding, the DVD player just stopped working
Jeff/360Powner,
Tony/sonydvdvcr here,
I hope this helps. I have been unsuccessful in getting this to fix the tape player, but my sony dvd vcr slv360p unit now works and the dvd plays great. Still working on the tape part. Good Luck!
A few days ago when I was searching online for a solution to my own problem, I came across fixya. After posting the exact same problem as yourself, I began to remove the tape from the unit. Thinking I would have to cut the tape, I attempted to remove the video cassette without cutting it. I was successful. Here are the steps I took:
1. Remove the outer casing.
2. Remove the approx. 8" bar (2 screws) across the VHS entry area. (You can do with or without removing face of player. Be careful if done without)
3. Remove 4 or 5 screws in base holding the entire video assembly to floor.
4. Next, is the tricky part. First determine if the tape is one you want to salvage. If so, slide the tape film out of the roller areas where it is strewd out while it was being rewound so it is free, otherwise cut it. You will then have to pry the VHS up in the front through the entry door and push from the rear. Might have to try a few times, walk away, then try some more. But it will come free. Tension can be eased by simultaneously prying on the sidetabs holding the cassette in the player. Careful not to break tabs.
5. Once tape is free, you may be done, but I kept on in uncertainty.
6. Next I removed the entire video tape assembly by raising it off the tall pointed posts enough to clear them but not too much where you put excessive strain on the several computer bands that are attached.(I did not disconnect those, just be careful)
7. Raise the assembly off of the floor and then replace. There is a slim narrow plug style deal that is fixed to the floor that the assembly rests in. I believe this is significant to allow the player to reset.
8. Check power now before you replace everything. You should see the tape assembly physically reset and disengage from the rewind position.
9. Replace assembly and bar and face accordingly.
I hope this helps. I have been unsuccessful in getting this to fix the tape player, but my unit now works and the dvd plays great. Still working on the tape part. Good Luck!
SOURCE: rewind on vcr stops all the time after a few
The interior drive belts and rubber drive wheels need cleaning. If you are not a technical person, please bring it to an appliance repair shop to be serviced. You can break the delicate drive parts and sensors if you have never worked on a VCR before.
SOURCE: Sanyo DVD Player & Video Cassette Recorder - DVD-7200
dvd does not play but video cassette does...fixable???????
