When I try to disconnect my hard drive I get the message that it can't be disconnected becauseit is still in use, even though I have switched it off Can you help
    Scholar:
  • 80 Answers
This kind of problem occur mostly due to virus problem. If you have any anti-virus than kindly scan the system properly and do the boot scan if you have native boot scan option in your antivirus. and if you do not have anti-virus than Format is the best option always at last.
Posted on Nov 19, 2008
    Sergeant:
    Champion:
  • 274 Answers
Make sure you left click on the USB icon (green arrow) on the lower right of the screen (system tray) and choose to Safely Remove the Drive Device, BEFORE you pull the cable or turn it off. The system may still be writing files from cache and you could loose the last files written.
Four wheel drive problems
It sounds more like a bad actuator/valve
I’m happy to assist further over the phone at https://www.6ya.com/expert/brock_d67526d2a834c47e
Dec 09, 2013 | Cars & Trucks
Hi, I have a colleagues laptop here which seems to power up for a few seconds but then doesn't go any further. There is definitely power getting through the motherboard, and the HDD spins up, but...
I believe that is a No Post issue.
Its not the hard drive because you said " and the HDD spins up, but it seems as though it doesn't reach POST" or else you 'll be getting errors associated with the hard drive
There are some laptops even though it has a RAM NO POST issue will not beep
" no display and no beeping at all "
For us to determine if this a Motherboard Issue we have to disconnect all parts that can be disconnected. Disconnect the hard drive, Memory (RAM), battery, if you have a Modem daugther card, Express card, PCMCIA Card.
Try Turning the computer on using the Power Adapter hooked up on the computer. If you are still getting issues Definetly that is a Motherboard have gone bad but we really need to check up other parts that are disconnected
If Motherboard is good you will be getting video but it will stop on the POST screen and you might be hearing beep sounds as well. That means that the Motherboard is fine. Put the parts that are disconnected and clean the metal contacts as well one at a time and try to isolate at what part that is bad
Jul 05, 2011 | HP Compaq nx6325 Notebook
Hi, I have a Yamaha RXV 459. Have speakers of DSE. The speakers are of 8 impedance. Was listening to music till 4 hrs ago. Switched off the whole unit from the power source. Returned and the unit is...
Disconnect the speaker one at a time, you may have a shorted voice coil, the message was indicated a short in the speaker wiring. If no joy then you may have burned out the power transistors.
May 16, 2017 | Yamaha RX-V459 Receiver
All the lights come on when I switch on my HP Pavillion dv9600 but the screen is blank.
DO THIS FIRST - Perform a hard reset If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Actions to take after performing hard reset If no error message is displayed:
If a text error message is displayed, see Troubleshooting Error Messages on a Black Screen During Startup or Boot c02076104.jpg
Black Screen with No Error Messages Connect an external monitor c02076105.gif If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance. Disconnect all peripherals and repeat the hard reset Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset , some devices are often overlooked. c02069237.gif Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.B
b52compters@gmail.com
B52computers
Chris Thrash
Jan 10, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
I can not access my computer after imminent failure message
> imminent failure message ... cannot access
Bad luck that the 'imminent' failure was _SO_ soon followed by _complete_ failure.
Buy a new disk-drive. Disconnect the old disk-drive.
Install Windows to the new disk-drive.
Reconnect the old disk-drive, as a 'slave' disk-drive, and hope that you can access the files on it, even though you could no longer 'boot' Windows from it.
Oct 26, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
My 500GB hard drive isn't working anymore
There have been issues with the western digital Mybook on the enclosure itself as the connector usually fails. The actual harddisk, however, is not damaged so you just needed to take that out and mount it to your computer or put it in another USB hard disk enclosure.
Aug 17, 2010 | Western Digital My Book Essential Edition...
Disconnecting unexpectedly!
Hello! My recommendation would be to check if the Drive is over heating. Excessive heat could cause the disconnection either for drive protection or because solder points lose strenght. Turn it on, use it a while, right when it disconnects check if its hot. Or try to dissipate better the heat and see if it lasts longer
Mar 22, 2017 | Buffalo Technology DriveStation Combo 4 1...
500gb St ex hard drive suddenly disconnects when still plugged in
please try to check your external hard drive if theres a problem aside on the cord connecting to pc...
Jun 16, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
The device Generic Volume cannot be stopped right now. try stopping the device again later. on Window XP
If you tried to stop your external hard drive with it open in Windows Explorer, You will get this message. You cannot disconnect the drive in this condition. Even if you close Windows Explorer after, Windows still thinks it is open. The best thing to do, is restart Windows and when the screen goes black, shut the power off to the external drive or disconnect the USB cable. Disconnecting in any other way causes Windows to have problems with USB devices in the future.
Jun 08, 2009 | Western Digital 500GB My Book World...
External Hard drive Disconnect Problem
Windows rarely wants to let my drives go either.
I assume it is the active virus inspection program scanning, or possibly google desktop indexing the drive.
So long as files are written to the disk (the copy is finished), you should be fine - I have never corrupted a disk by unplugging - if in doubt you can let it sit for an extra 30 seconds or so after a copy is finished before disconnecting.
After all, USB is hot-pluggable (can be connected / disconnected while turned on.
Apr 26, 2009 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
