Hi recently I had a power surge through my home which prevents my Sony DVP-NS57P DVD player from playing is it possible that a fuse has blown & can the fuse be replaced if so where do i purchase one?
    Brigadier General:
  • 6,966 Answers
Most power surges as the name implies involves a rogue spike voltage over and above the standard. More often than not, this would cause as you suspected a blown fuse. In most designs, the fuse would either be at the rear and easily replaceable by the owner/user or inside the unit requiring the cover to be removed. Most electronics shops/stores and any outlet of audio/video equipment would have such in stock. The rating would also be stenciled on the fuse itself hence you would have basis for the replacement.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 19, 2008
  • Louie  Role
    Louie Role Nov 19, 2008
    Hi again,
    I had a look again at your particular model. This particular model has the fuse inside the unit. Should you consider replacing the fuse and all works well, then that would be a lucky break. If on the otherhand the new fuse also blows, then there are other problems mainly in the power supply board. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
  • 685 Answers
Did you try unplugging it and plugging it back in.if not try this first.
  • Juanita Vega
    Juanita Vega Nov 19, 2008
    http://www.sony.co.in/section/manuals also here is a site for your dvd player.if you can give me the model number i can look up more info to help you
Sony dvp-ns57p plays cds, not dvds
COMO PUEDO DESBLOQUEAR EL VIDEO DEL DVD
Nov 20, 2012 | Sony DVP-NS57P DVD Player
How to Reset a sony dvd player parental Password? Model of DVD - DVP-NS57P
http://www.retrevo.com/support/Sony-DVP-NS57P-DVD-Players-manual/id/1075ci153/t/2/
copy and paste that link to be able to download the manual for the player.
May 03, 2011 | Sony DVP-NS57P
Manuals for sony dvp-ns57p
please check the link below:
http://www.generalmanual.com/DVD-VCRs/Sony-DVP-NS57P-B-S-DVD-CD-Single-Disc-Player.htm
on the bottom of the page after the description, you will find the Owner Manual.
please check it, it should give you all the solutions you need.
thank you.
May 18, 2010 | Sony DVP-NS575P DVD Player
How to convert my dvd sony DVP-NS57P in multizone.
go into set up menu undet audio. you have to turn on the dolby digital and the dts. use a fiber optic or coaxial cable to enable
Jul 11, 2009 | Sony DVP-NS57P
Sony DVD player DVP-NS30 does not play dvds
Change the motor disc spindle,good luck
Jun 07, 2009 | Sony DVP-NS57P
Unlock region code on Sony CD/DVD Player DVP-NS57P
I don't have a solution, but I know that the one about "press Display, Top Menu, Clear, Power" doesn't work.
Sep 05, 2008 | Sony DVP-NS55P DVD Player
Sony Dax HDZ235 DVd player
the circuits might be fried. you may need to replace the player. sorry
wg
Feb 11, 2008 | Sony DVP-NS715P DVD Player
Sony DVP-NS57P all region
Try this,
1) Plug the DVD Power Cord to the wall jack, but DO NOT Turn On the player;
2) With the Remote Control, press: Display, Top Menu, Clear and Power;
3) It will enter in the Service Mode;
4) Choose option 2 and then 4;
5) It will ask for an Input Code and Current Code (its 5 spaces), press 1245 and then Zero;
6) Leave all Zero erasing 1245, and on the bottom field all Zero too, then press Enter;
7) So the DVD Display will show a Zero (all Region-Free),     then press Power to Turn Off.
Nov 18, 2007 | Sony DVP-NS57P
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
