Question about Sony KP-53S65 53" Rear Projection Television
Standby timer light blinking, tv will not turn on
Tv had a power surge, then the standby timer light was blinking, tried resetting, still nothing , can you suggest what could be wrong
  • 8 more comments
  • lacam31 Jun 23, 2008
    same problem with the standby timer
  • Anonymous Jul 29, 2008
    no sound no pic.... standby light blinking
    no pic, no sound.... standby light bliking..... have tried and checked all connections..... nothing... HELP
    no pic, no sound stanbby light blinking..... tried everything...all connections are ok,.,..... help :(
    Please help… I see no pic, no sound….stand by light blinking….L
  • forejlo Aug 21, 2008
    standby timer light blinking, tv will not turn on problem, and notify you when a new solution is offered.
  • Anonymous Sep 07, 2008
  • Anonymous Mar 14, 2014
    The tv won't stay on when light comes om
    Timer standby. Button blinks 7 times
  • Anonymous Mar 20, 2014
    my tv whenever i try to turn it on the standby light just flashes as if it tried to come on then died after trying to turn it on from standby for around 30 mins it finally comes on. im looking to find out what's wrong with it so i can fix it
390PF 2KV CAPACITOR Sony Part Number: 1-162-133-00
Posted on Aug 13, 2008
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Posted on Feb 08, 2007
The Timer/Standby LED light is flashing on the front of the TV. Can turn on TV with sound but no picture, TV shuts off within 5 seconds.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Aug 08, 2011 | Sony Grand WEGA KDP-65WS550 65" Rear...
My standby/timer light is flashing and will not turn on.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
Jun 02, 2011 | Sony KV-27S66 27" TV
Standby light blinks 4 times
Jun 01, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Green light keeps blinking will not turn on at all
May 11, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Standby light keeps blinking but no picture
May 01, 2011 | Sony KP-53S65 53" Rear Projection...
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Kdl-52xbr4 5 blinking standby lights
Dec 15, 2010 | Sony KDL-52XBR4 LCD Monitor
Tv keeps turning itself off and then back on. green power light blinks. If i tun it off when it does that the red power light blinks 5x repeatedly.
Jun 22, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
TV Lamp light blinking
COULD BE FAN NOT WORKING. TAKE BACK OFF SEE IF TURNING, CLEAN THEM. GO TO SONY.COM,TROUBLSHOOTING, OR SHUT THE TIMER OFF.
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jul 10, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
366 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
