Question about Tomtom XL 330 Car GPS Receiver
TomTom One XL battery not holding charge
Hi there
I have had my TomTom for about 8 months and have always found that the battery does not last long, it has now got to the stage that you can charge it fully and turn it off overnight and it is dead in the morning. Is this a common problem? What can I do about it and if the battery needs replacing would this be covered by the warranty?
Regards
Theresa Smith
  • 3 more comments
  • Anonymous Dec 11, 2008
    I have the same problem with my TomTom XL 330S. I put it in the car and somehow it turned itself on twice already. I'm taking it in the house to monitor it this time. The battery doesn't hold its charge for some reasons.
  • SL5588 Dec 16, 2008
    Tom Tom One won't hold charge. When not in use, last severl days only with unit turned off.
  • Anonymous Feb 04, 2009
    I have the 330S and the exact same issue.
  • Casasdeluz Mar 17, 2009
    Fully charged tomtom One XL discharges to Min within 26-29 hours while off.  Bluetooth is turned off, and power settings are adjusted to minimum settings.  In the processing of contacting TomTom now.
  • Anonymous Mar 20, 2009
    same problem opn my tomtom unit
    Novelist:
  • 158 Answers
Hi Theresa,
Yes , it should be covered by warranty. It's not a common problem but sometimes batteries do fail. It's a bit like when a light bulb goes in your house , you can get a brand new one out of the cupboard , plug it in and it either goes right away or only lasts a short while. Where thats the case the bulb was in fact defective and not fit for purpose. Same with your Tomtom battery . Good luck when you contact TomTom.
Posted on Nov 20, 2008
    Problem Solver:
  • 12 Answers
If you need a new battery and want to replace it yourself, you can purchase one from NewPower99.com - it comes with video instructions and tools so I found it was not too hard to do. Here is a link -
http://www.newpower99.com/Battery_for_TomTom_ONE_XL_p/tomtom%20one%20xl.htm
Posted on Nov 22, 2010
WHY isn't MY TOMTOM CHARGING? It's BEEN PLUGged IN FOR 45 MINS.
Usually an old (or older) battery will no longer hold a charge ... or will only hold a small charge (that will let you run the GPS for only a few minutes).
Often, when the TomTom device is always connected to the charger (in a vehicle), where it charges every time the car is turned on, whether the TomTom is being used or not, the battery gets charged (partially or fully) often enough to use up the "maximum number of charge" cycles for the battery. Hence, it will no longer charge properly or hold a strong charge.
Like for all lithium batteries, it's better if your device is not always connected and being charged (whether you are or are not using it). The battery will last longer and it will still be able to hold a stronger charge.
Feb 24, 2016 | Tomtom GPS
Tip
TomTom XL 330 not coming on?
If you TomTom is not coming on after a long sleep.. I.E. more then a few days with no use, try this......
(1) Plug the unit into either a PC or your Car
(2) Wait for about 2-5 minutes to get some charge into the unit
(3) Press and hold the power button for about 15-20 seconds until you see the start-up screen
Why did it die? I have found and many other have found the battery does not live long without a power supply to charge it, it would seem to me even thou it is powered off, the TomTom is still sucking away at the battery and it would seem there is nothing that can be done about it.
on Sep 16, 2009 | Tomtom XL 330 Car GPS Receiver
I have a tomtom xl 330. the device will not start up. I tried to update the application. it still does not work. Please help.
A likely cause is that the battery is "dead" ... i.e. no longer holds a charge. The GPS runs on battery power, even if it is plugged in. It will work even if the battery holds a (small) charge. But if the battery doesn't a charge anymore, the device will not start up, even when it is plugged into a power source.
If this is the case, you'll want to change the battery.
Sep 04, 2013 | Tomtom XL 330 Car GPS Receiver
Tom tom keeps turning off ?????
The internal rechargeable battery has failed; they don't last forever.
Just search "TomTom One XL battery" and you'll find the the parts and step by step guidance on what to do.
May 28, 2010 | Tomtom One XL GPS Receiver
My Tom Tom XL 325 wont hold a charge while left off
Hi, leaving the unit in the cradle exposed to the sun during hot days has been known to fry the battery causing loss of battery capacity. perhaps this could be your problem. I replaced the battery in my last GPS 4 times because of this before I analysed the problem. This will most likely be outlined in your user manual too. You might also compare the output capabilities between your blackberry and tomtom charger - it is entirely possible that you are starving the unit of a decent charge if the blackberry charger is not to the same current capacity as the tomtom charger.
Mar 19, 2010 | Tomtom One XL GPS Receiver
Green light on but will not switch on
plug in your xl via the usb cable to your computer and let it charge a few hours, then press and hold the power button for up to 15 seconds.
do not use the car or home charger to intially charge your xl. they are to maintain the battery, not a rapid charge.
let me know if you need further help.
Nov 09, 2009 | Tomtom One XL GPS Receiver
I have not used my tomtom for a few months , an when attempting to use it today , it was dead . nothing at all help tomtom xl roseden@telus.net
connect it to a power supply and leave it for a few hours A battery that is totally depleted will take some time to recover and not show that it is even being charged as power is too low to light the LED.
It will require a full charge of about 10 hours to get it fully back into service. But the LED will ( or should turn on) after about 1-2 hrs depending on the condition of the battery. If after the charge the battery does not hold a charge lasting on average about 2 hrs , then change the battery.
Please rate our help++++Thanks for using FIXYA
Sep 25, 2009 | Tomtom One XL GPS Receiver
TomTom One XL battery not holding charge but a few hours........
You need to change this battery as if it finally collapses it will ruin the internal components
Aug 14, 2009 | Tomtom XL 330 Car GPS Receiver
How do I charge the TomTom XL 330
Hi There!
You Can charge your Tomtom when you drive, or you can charge it with a USB port on your computer.
I don't think they come with a mains charger anymore?
Toby
Dec 26, 2008 | Tomtom XL 330 Car GPS Receiver
Charging tomtom XL GPS
Hi Jill,
It all depends on your computer. The charging current via USB is limited by the computer. Some restrict this to 500mA, others (lap-tops mainly) to 200mA. If the TomTom is turned off, you should get the battery charged in 3 to 6 hours. With the unit on, it can take many times longer as the unit will take almost 200mA from the battery.
DF
Mar 28, 2008 | Tomtom ONE GPS Receiver
Tomtom XL 330 Car GPS Receiver Logo
5,352 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
