Question about HP iPAQ RX3715 Pocket PC
Slow or fast charge
What is the difference between slow and fast charge?
    Scholar:
  • 43 Answers
Yes, the amperage your charging at determines charging time. The higher the amperage, the faster it charges. Your battery is rated in mAh or milliamp hours. One Ah means the electric charge transferred by a steady current of one ampere for one hour. A mAh would be 1/1000th of an amp for one hour. If your battery is a 1500mAh battery it means 1.5 amps for one hour. This charge current should not exceed the rating of the battery. It would cause possible excessive heating and possible a fire or explosion, especially on newer more volatile batteries like lithium polymer batteries. The life of the battery charge when fully charged will be similar no matter how you charged it, but slower, lower amperage charges will maintain your battery better than quicker, higher amperage charges and help extend it's life to its potential.
Posted on Jan 31, 2010
I think it's the amount of Amper... Some laptot offer only 100mA on USB (slow Charge) instead Desktop PC can offer 500mA (fast Charge). The life time of the battery is the same (i suppose) with the fast or with the slow Charge. the difference is in power consumption.
Posted on Jan 19, 2007
Turntable running slow
Hi Ken,
it is a Technics Frequency Generator Servo (Belt drive SL-23). I have four different belts and neither one of them works. Two are too slow and one is too fast and the other one is slow and fast.
I changed the belt before that I got off of an old turn table. It deteriorated.
I would appreciate any help.
So far I am also having Gateway Monitor problems and Canon Mp560 printer problems
Thank you,.
Aug 23, 2014 | Audio Players & Recorders
I have a e100 razor scooter.I charge my scooter overnight. Then I get on it the next morning it charges for about 10 hous. It moves fast but after about 6 seconds it will start moving really slow but it...
The charger you are using might have a default in it because it is not working you can also try another charger or let it charge for a few days. I this does not work then there is probably something wrong with your scooter.
Feb 22, 2018 | Toys
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
Mar 24, 2014 | Nikon COOLPIX L19 Digital Camera
Can i use another 4a 250v fuse for my cerwin vega LS12 if its not a (slow blow) ,and what would be the outcome
Fuses have different blow characteristics. Such to protect components differently. An extremely fast fuse would protect sensitive components like tweeters and slower fuse will allow transcients to pass and blow on long time fault. If you put a slow blow in place of fast blow, it won't blow as quickly, but it could allow the protected device to be damaged. In reverse, you put a fast blow in place of slow blow, it will blow at normal transcients and be a nuscience to always replace.
You can cross to a fuse of different manufacturer. The reliable manufacturers will have detailed datasheet and subsitute or similar fuse to the fuse you are looking for.
Oct 23, 2013 | Cerwin Vega LS-12 Speaker
What is the cooking time for "slow" and "fast"
The cooking time depends on what your cooking. In general there is a 3 to 4 hour difference between slow and fast. If your cooking poultry make sure to check the meat with a thermometer until you get the hang of it.
Nov 14, 2010 | Rival 3355 5-Quart
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
94 acura legend idles fast and slow when initally starting
The butterfly valve inside your throttle body may be loose causing your idle problem. have it inspected to see if it is.
Sep 07, 2009 | 1994 Acura Legend
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
HP iPAQ RX3715 Pocket PC Logo
532 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
