Question about Dishwashers
Fagor Dishwasher LFU-65IT - all lights staying on
After completing a quick rinse, I forget to switch off the machine before I left the house for 2 days. When I returned and opened the dishwasher, all lights on the panel were on and there was a considerable amount of water logged in the bottom of the machine. I managed to drain off the water.
I have checked the filter and it's not blocked. I have checked the drain pipe and since poured water into the machine and it's draining off fine. I have plugged the machine out and left it for a half hour and then plugged it in again but all the lights remain on.
I 'think' the lights are staying on whilst the power button is off (the button is out). I'm not sure if you pushed the button in or out to power it on. When I push it in all the lights go off and no buttons function then.
Any ideas?
Thank you.
  • sogara Nov 19, 2008
    Is there a reason why you are offering me premium assistance (for which there's a charge) as opposed to the 'Let our Experts solve your problem for FREE' option that I used?
    Thank you.
SOURCE: 7 BEEPS!!!!!!!!!!!
Please contact the Fagor America Service Center toll free: 1-877-743-2467. A customer service representatives will discuss the problem with you. If on-site service is required, they will coordinate that for you.
Posted on Jun 22, 2007
markevans
  • 148 Answers
SOURCE: my dish washer does not drian completly
the water must pump uphill to the air gap. the last water in the line drops down the hose, and is in quantity equally to the volume of the hose from the bottom of the pump to the top of the hose. that flows to the bottom of the sump in the unit. if enough, it appears as residual water in the bottom. its ok.
m
Posted on Dec 21, 2007
  • 3422 Answers
SOURCE: stuck in two minute drain cycle
It is possible that the unit has leaked.
I want you to please check THIS link it will solve your problem.
Don't forget to do the banging test mentioned there.
Goodluck..
Posted on Feb 25, 2008
wheelshot
  • 102 Answers
SOURCE: dishwasher runs, water doesn't drain out
sounds to me that you may have some suds residue in the dishwasher that keeps it from draining completely. Get you some dishwasher cleaner which you can purchase at wal-mart or wherever you buy your detergent, and clean out your dishwasher. It is a inexpensive test. Alot less expensive than having a tech come to your house. Make sure that your drain hose is mounted higher that where it goes into the drain. This is also a common problem that I encounter in the field. Hope this helps. Let me know if I can help you futher.
Posted on Apr 04, 2009
Maytag317
  • 1136 Answers
SOURCE: dishwasher does not drain properly after rinsing
Hi, Check the drain hose to see if there is a parcial blockage. If not, check the drain check valve where the drain hoseconnects to the pump.
Hope this helps
Posted on May 08, 2009
Fagor lfu-65it not getting water when it starts
Fill valve or float switch may be defective
Oct 17, 2016 | Fagor Dishwashers
How to clean between glass in oven door
split the door carefully and wash it . dry really well before putting halves back together unless you do not care if it explodes when used.
Mar 19, 2016 | Fagor LFU-45IT 18 in. Built-in Dishwasher
Fagor dishwasher not completing cycle showing f6
The heater or thermostat is faulty and not allowing the dishwasher to complete cycle as water is not getting hot enough. Try to run a cold or short cycle and see if is completed.
see explanation of fault codes in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
Sep 21, 2014 | Fagor Dishwashers
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
Fagor 1vf65it
Fixya is unable to advise whether a pump can be easily obtained.
Feb 16, 2018 | Dishwashers
Fagor LF 65IT beeps 4 times a few minutes after switching on and all lights flashing on display
This is a flood warning. You must have water in the bottom of your machine which has raised the float and activated the flood switch. Open the lower front panel on your machine and for where the leak is coming from.
Apr 03, 2012 | Fagor LFA-65 IT Dishwasher
Fagor dishwasher LFU-65IT, when switched on it sounds 9 beeps. have referred to manual which indicates that 9 beeps means "not even" please explain
Hello, mh
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Aug 26, 2011 | Fagor LFA-65 IT Dishwasher
Fagor f1-48w
The machine won't go into rinse if the rinse isn't hot enough. Check the thermal trip hasn't operated and that the thermostat bulb us fully inserted into the pocket in the front of the boiler.
Jul 02, 2008 | Fagor 24 in. FI-48W Dishwasher
7 BEEPS!!!!!!!!!!!
Jun 15, 2007 | Fagor LFA-65 IT Dishwasher
Dishwashers Logo
90 people viewed this question
Top Dishwashers Experts
