Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
My set is a few days over 4 years old. same issue. called sony-- told that D-Board needs to be replaced. Board is no longer made. waiting on call back from local service center
Posted on Jan 23, 2007
Color is not alligned
it will be ure convergance chips they are about $30 each and u need 2 also dont try and realign settings as it will stuff settings and when u put new chips in it is a very long process to realign, open the back and you will see the ICs they have about 40pins and screwed to an alloy heatsink, if its pretty old its not worth fixing for the price of these units these days second hand on ebay
May 07, 2010 | Hitachi 53UDX10B 53" Rear Projection...
My Panasonic rear projection TV color is off
hello it sound like convergance ic might be the trouble it's a big job to do yourself a lot of testing and a lot of desoldering and soldering get a quote from an engineer
Jan 19, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Green & Blue Ghosting Convergance problem
Odds are real good that the cooling fluid in the green and blue picture tube assemblies has become contaminated. You can tell by looking down into the lenses with a flash light. Funny thing is the red never gets contaminated because whatever organism is causing the problem can't survive in red light. BTW this may still not solve all of your convergence problems but when the colors are so badly diffused the convergence sensors for flash focus can't lock onto the beam landing.
Jun 01, 2009 | Samsung HCL473W 47" Rear Projection...
Color ghosts out of allignment
This is a convergence problem that can be as simple as poor connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, you can fix this yourself.
Let me know if you wish to attempt the repair and I will post additional details and instructions.
May 05, 2009 | Televison & Video
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
Sony KP-46wt510 Convergence issue
convergence ic's replace all 3 be carefull make sure to reapply the thermal compound to the heat sinks after cleaning the old stuff off stk's can be had from global
Oct 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 60" rear projection, convergence
Check out this document to adjust your Hitachi projection t.v. I did my 11 year old t.v. today.
Jul 25, 2008 | Hitachi 50UX57B 50" Rear Projection...
My red convergence is out, and it will not change
when thes tvs get around 4 to 5 years old the convergence go's out on them there are 2 stb's or someting like that it may be stc's i can't remember what they call them it's been so long sence mine did 1 has probbly went bad i chould control the red but not the blue and sometimes when this happens it will also blow green fuses as well in my books they should put cooling fans in these tvs to help cool them there is to much heat inside the tv thats why they only last a few years before having that problem i have 3 of them and all three of them did the same thing you can check the remote eye on the front of your tv sometimes when there is a problem the green remote eye will flash acode but you will have to have the service manual to find out what what the code means
Jun 25, 2008 | Akai PT5598HD 55" Rear Projection...
Blue Convergence just went out?
High Voltage Capacitor? Leave the set unplugged for 1/2 hour most components will selfdischarge, as for your problem, being a Magnavox, you have one of two problems, the convergence I suspect is what is blown out, this unit probably uses STK392-110 Ic's, I would suggest replacing with STK394-160e chips as they are probably shorted, some of the big resistors (1 or 2) may be opened up also, usually they change color. The only other thing that would cause usually a yellow color in the corners is the CRT Fluid, it changes from clear to Orange in color and clamps off the blue color from the fringes, I suspect the chips need replacement, dont forget to put some heatsink dope behind them, they are usually on the left in the front of the set (from the back) Big long heatsink that is fairly tall (probably the biggest heatsink in the set.) Good luck, and the repair usually runs around $350.
Jul 13, 2007 | Philips Magnavox 51MP392H Rear Projection...
Is it my Convergance??
Do not try to align the colors with the remote. One of your convergence IC's has gone bad and needs to be replaced, possible burning one of the 3 low value resistors next to it. If you change the convergence settings now then they will have to be reset when the new IC is installed.
May 05, 2007 | Hitachi 43FDX01B TV
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
