My new MB has only 1 IDE and i have 4 IDE devices to connect
  • 24 Answers
You can connect two IDE devices on a single IDE cable
Posted on Nov 19, 2008
When I download a program an click to install it a box pops up saying the download I am trying to install is not a valid Win32 application. This is a new problem. I have not had any problems downloading in...
This error message could be caused by a number of things. Generally it's because the program being downloaded is corrupt or didn't download completely. Have you tried a different browser to do the downloads? If it's a very large download you may encounter problems with losing packets. A download manager may help.
http://www.techspot.com/downloads/231-free-download-manager.html
Also, you may want to try doing a restore to system restore point to a date when you weren't having this issue. System Checkpoint dates (in bold) are usually very safe points to restore to. I would also recommend a virus scan and if you don't have this utility and are able to download and install it (yes I know that's your current problem, but you can download it to a flashdrive from a friend's comp and install it), I'd get Glarysoft Utilities and run the one-click maintenance which will fix any registry errors. It's free and is a great way to keep your machine running well.
http://download.cnet.com/Glary-Utilities/3000-2094_4-10508531.html
If any of this helps correct your problem I would appreciate a rating. People here seem to take the help and don't show any appreciation by taking the time to rate the help.
Jan 11, 2011 | Computers & Internet
In my motherboard manual(ASUS P5GV-TMX) specifications there is an entry showing storage/RAID -- 1 x UltraDMA 100/66/33 4 x Serial ATA First are those speeds ?? So does this mean it doesnt support UDMA...
You have 1 IDE connector (1 X UltraDMA) labeled PRI_IDE on your MB that uses a flat ribbon cable to connect with hard drives or optical drives that use that type of connection. The 100/66/33 are transfer rates: 100 MB/s, 66MB/s, or 33MB/s. These connections are quickly becoming a thing of the past and being replaced by the faster SATA (Serial ATA) connections which have transfer rates of 150 MB/s to 300MB/s. Your motherboard has 4 SATA connectors. (4 X Serial ATA)
Thanks for using Fixya.
Oct 09, 2009 | ASUS P5GV-MX Motherboard
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Secondary IDE channel
the motherboard you have can only support 4 SATA Drives. if you want to use your IDE drives, you have 3 options: 1) buy a SATA to IDE Converter which is around $20-$25. (if you selected this, you can fix the drives into the internal of the pc). 2) buy USB to IDE converter $10-$15. (if you want to fix the drive inside the pc, remove one PCI slot casing cover at the back of the computer casing and use the USB slot at the back of PC). Hope this helps. Good Day!
Jul 06, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
USB driver 2
Can you be more precise? You don't need USB driver for this PC...
Jun 25, 2009 | Gigabyte Computers & Internet
Problem
Try removing the software for the printer again and disconnect the USB cable from the computer. Reinstall the software and after its finished reinstalling, reconnect the USB cable to computer. Many USB printers require you to install the software first without the printer connected to the computer.
Jun 17, 2009 | Computers & Internet
Motherboard driver
here all the utility to your motherboard, download in this site: http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2669
Msi motherboard
Try using the cd rom on the second cable as a master.
Let me know whats up
Nov 15, 2007 | Intel Motherboard
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
