Question about Primera Technology Bravo (Refurbished) (62701R) CD-R Burner
Looking for information on 2001 mazda bravo 2.5l turbo diesel ute
Service manual can not find any information
I have an electronic (pdf) manual for the South African Mazda Drifter 2.5 tubo diesel, i think they are pretty much the same. I will need a FTP to load it to for you though, files are large.
Posted on Feb 10, 2009
Does my 1.9 diesel Suzuki grand vitara have a timing belt or timing chain
nice to know year, and country, ? this is USA forum
1999 to 2017 , why make this so hard?
1.9 DDS or not DDS?
5ways to know that.
1:look on the suzuki site, and pretend to buy that part,'
2: buy the book there, the service manual.
3: buy part in any online store, look for said part.
4: google that engine,but....
5: tap tap tap front cover, metal? chains or gears, plastic= belt
but no year stated making the below impossible
"Pre 2001 turbo diesel models were fitted with Mazda Diesel engine, with later models fitted with a turbo diesel engine (4 cyl. 1.9L 129 hp (96 kW) manufactured by Renault)"
TRAFIC?
or MEGANE?2010 up
the renault is SOHC engine,;head , early had belt.
the 2010 up is sold by GATES,
best i can do, with only displacement of engine.
Feb 09, 2017 | Suzuki Grand Vitara Cars & Trucks
2.5 ranger td 2007 diesel pump timing marks n will da key way on the pump should b same as the timing marks
images for 2.5 ranger td 2007 diesel pump timing marks
Ford ranger 2.5 diesel pump timing marks - Fixya
www.fixya.com/.../t12609400-ford_ranger_2_5_diesel_pump_timing_...
Apr 29, 2012 - SOURCE: need the timing marks for a 3.1 td 5 cyl diesel injectionpump. isusu engine?? have you looked for a 8mm hole in timing gear that ...
Mazda Bravo 2.5 TD 2000 - YouTube
? 10:00
https://www.youtube.com/watch?v=D8zJeouIXfo
Sep 11, 2010 - Uploaded by V8Jagnut
and one other , would a miss timing on the fuel pump cause engine .... The only thing I've ever seen with a Mazda dieselengine was an old Mercury Lynx. ... Ford Ranger Mazda B25002.5TD Servicing Guide Part 2 - Air and .
Oct 29, 2015 | 2006 Ford Ranger
I have a Ford courier 2006 turbo diesel with auto hubs. I want to put in manual hubs and diff from a 2002 petrol mazda bravo. Are the diff ratios the same ?.
Petrol & Diesel would normally have different ratios because of the different max revs..
Count the teeth on the Crown Wheel & pinion to make sure you get the same ratio
Sep 01, 2015 | Ford Cars & Trucks
Fuel economy HJ75 landcruiser ute 1989 with turbo
Check that the intercooler is in good condition (no cracks or leaks) and the hoses are tight at the hose clamps . Next talk to a diesel pump repair specialist as you may have to re-tip the injectors and re-calibrate the pump for the extra air that the turbo produces. Check that you have the correct turbo for the diesel
Mar 14, 2014 | Toyota Cars & Trucks
Mazda bounty
here is a link that may have your solution if it work thank that auther
http://www.fixya.com/cars/t12681785-set_diesel_pump_mazda_b2500_turbo
Mar 07, 2014 | Cars & Trucks
1998 mazda bravo ute b2600 petrol- Cannot locate the oil filter to change. Can find the sump and bung. Is it possible this model has no oil filter?
No!!!! The motor has oil filter.Look from the top of the motor.It is right there.Under the manifold.Hope this helps
May 25, 2011 | 1998 Mazda B-Series
On a 2001 mazda bravo turbo disel when do I have to change the timming belet it's done 176000 ks
Without knowing which diesel engine you have, I'll have to guess that you have a 2.5L (B2500) - Note: the more detailed information you give us, the more accurate our answers will be :-)
As a general rule, cambelts (with tensioner assembly & seals) have a limited life and should always be replaced every 100,000km, or sometimes earlier depending on manufacturer. The reasoning behind this is that most engines will suffer major internal damage if the cambelt snaps (this is what is meant by 'Interference' engines). As the engine has to be opened up to carry out this service, it can be a costly maintenance. For this reason, it is also common to replace the waterpump at the same time (to avoid having to open up the engine again) as waterpumps have been known to fail beyond 100,000km.
The good news....if you DO have a 2.5L (B2500) engine, then this engine is a NON interference engine - which means, if the cambelt did snap, your engine would not suffer any internal damage, compared to interference engines.
Hope this helps.....
"If this has helped you in any way, please rate this solution"
May 07, 2011 | Mazda B2200 Cars & Trucks
2000 Mazda Drifter 2.5 Turbo Diesel, exhaust manifold torque settings for nuts.
Mazda B2200, B2500 and B2600 (6th Generation).
In model year 1998, Mazda B series renews its own international markets. Production at the plant AutoAlliance Thailand began in May 1998. This model is also sold as the Ford Ranger in Europe and Asia, and the Ford Courier in Australia and New Zealand. Production started this year in the factories of companies AutoAlliance Thailand and Ford Motor Philippines. Versions CKD are also assembled in South Africa, Ecuador and Colombia.
The van is sold in over 130 countries under a variety of names. Along with the emblems of Fighter and Ranger in Southeast Asia (except Singapore, which served as the flagship models Proceed Japan), was sold as the Mazda Bounty and Ford Courier in New Zealand, Mazda Bravo in Australia, and Mazda Drifter in South Africa.
Engine options:
2.2 L 2.2 L (2.184 cc) 85 hp (63 kW)
2.5 L (1.998 cc) turbo diesel 118 hp (88 kW)
2.6 L (2.606 cc) 121 hp (90 kW)
Fig. Tighten the exhaust manifold bolts in 2 stages
To install:
  1. Clean the mating surfaces on the exhaust manifold and the cylinder head.
  2. Install a new gasket and the exhaust manifold. Torque the bolts in sequence as follows:
    1. 16 ft. lbs. (23 Nm).
    2. 59 ft. lbs. (80 Nm).
Hope helps.
May 01, 2011 | Mazda B2600 Cars & Trucks
I need a new engine for my land rover and not sure the size engine i currently have
How is it possible that you dont know what size is the engine in your car. ..... unbelievable.
What type of engine do you have, petrol or diesel, or dont you know that either
If its not beyond you, open the bonnet and you will see the engine, if its a petrol engine, then its a V8 and will have it embossed on the air intake what size the engine is. If its a diesel engine then it will be a 2,5L turbo TD5. GOOD LUCK
Mar 09, 2010 | 2001 Land Rover Discovery Series II
2002 turbo diesel mazda bravo starts and runs fine but will not rev past 2500rpm it blows out a heap of smoke and will rev no further
diesels are not known to be high revving engines to begin with, anyways, it sounds like your turbo is malfunctioning, get it inspected or repaired
Feb 25, 2010 | 2002 Mazda B-Series
Primera Technology Bravo (Refurbished) (62701R) CD-R Burner Logo
604 people viewed this question
Top Primera Technology Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Terry Hair
Are you a Primera Technology Computer and Internet Expert? Answer questions, earn points and help others
