Question about Canon PowerShot SD1000 Digital Camera
Canon digital camera solution disk
I lost my disk and i need to transfer my pic from my camera to my computer. I don't know much about camera and computer so, I don't know if i can transfer without a disk. I installed the first time but something happen w/my computer somebody fixed and delete it.
Can you help me please... lost my canon digital camera solution disk. need to download that and the Advanced Guide. powershot sd1000
  • brianframpto Dec 02, 2008
    there is no driver download available for sd1000 if you have XP?
Get a SD card reader to read the SD1000's SD card. To remove the SD card press on it and it will pop out.
Posted on Dec 03, 2008
  • Canon Master
  • 19,396 Answers
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the USB cable and run the software that you downloaded.
The software installer will tell you when to connect USB.
Posted on Dec 02, 2008
Hi, I own the Canon PowershotA540, recently I discoverd that once I put the SD card in my computer to download the pictures it downloads them, but once I put the card back into my camera all the pictures...
This sounds like the program you are using to download the pics is set to erase them from the card when the download is complete. You need to dig into the program and adjust the settings. That's as much as I can tell you since I don't know what program you're using. Your camera is fine.
Jun 20, 2011 | Canon PowerShot A540 Digital Camera
I do not have the installer cd for the dxg 328 and can not install the driver or anything so am unable to import my pics.
Hi ,
don,t worry,
it is not so important . and very easy you can transfer your picture from camera to computer.
you need only a ram reader .
you can insert the camera ram in to the ram reader and transfer all of your pictures from
ram to your computer.
don,t worry
good luck
gorbesia
Jun 14, 2011 | DXG Technology DXG-328 Digital Camera
I am transferring images to my computer, which I have done before. Now I am getting the message "Save folder not found?" Have I moved it? Do I need to create it? How? Where? Please help....
My solution is to unistall your current canon software that holds 15 canon components in your computer. You will find them under system task and select remove programs. After you have uninstalled the program, reinstall your "Canon Digital Camera Disk" and follow their prompts. Now you should be able to transfer images again as per normal.
I have answered this question in detail under another question postered by "whitecar631" under canon "save folder not found" canon sd1100.
This worked for me, but I don"t know how to prevent it happening again. I do know the day I lost all "my pictures", I had previously deleted a large file in my documents. I also experienced "save folder not found" when I tried to transfer images from my canon ixus 100.
I was lucky enough that I had all of my original SD Flash Media Cards, so could transfer all my photos again. I have since put all my photos into labelled folders instead of dates and images.
Hope this helps, it appears to be a problem in the canon program. Joyce
Mar 02, 2011 | Canon PowerShot A470 Digital Camera
I lost my disk to download camera info to computer
You can always use a card reader to download pics....then you don't need the disk.
Sep 13, 2010 | Canon PowerShot A530 Digital Camera
Canon Powershot A70. I get a 'Memory Card Error' when I turn it on. Did this three different cards. They don no appear to be defective. I just transferred all of the pictures form them to another hard...
When you transferred the pics from the cards to your computer, did you use the "safely remove hardware" function before removing the cards or cord or whatever method you used? If not, this is why you're getting the error message. If the pics are safely downloaded, format the cards in the camera to get them working again.
Sep 03, 2010 | Canon PowerShot A70 Digital Camera
EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens: went on a trip to europe. took lots of pics and we...
1. There are hundreds and hundreds of programs that can restore lost files from a formatted drive... just google it
2. You cannot use a usb cable to transfer files (or at least not on my computer) with this camera, you have to take the card out of the camera and directly plug it into your computer
Hope I helped
May 18, 2010 | Canon EOS 400D / Rebel XTi Digital Camera...
Transfer problem
Use a card reader to download your pics.
Sep 24, 2009 | Canon PowerShot SD960 IS Digital Camera
I have a fuji z10 camera and i lost the software disc..
Hi Zack, welcome to FixYa. You can solve that problem 1 of 2 ways.
1) Are you using a memory card in your camera? If you are, then you can plug it into a slot on your pc (if you have one), and transfer them that way. If you don't have one, you can purchase a card reader that plugs into your pc, and read them that way.
2) If your pictures are in the camera's internal memory and not on the card, most camera models allow you to move pictures from the camera's internal memory to the card. Check the manual to see if your model allows that. Don't worry, all is not lost. Let me know if you have any other problems.
Rob
Mar 02, 2009 | Fuji FinePix Z10fd Digital Camera
Dig camera
Download the software from Canon Website here:
Nov 07, 2008 | Canon PowerShot A75 Digital Camera
it is very simple when u connect ur camera to pc through data cabel u seen dat dere is some driver automatically u need not ny software to connect to ur pc...
if u r using windows xp....
when u connect it automatically ask u to copy images......
if it not ask then u hv to transfer ur picture through cardreader...
connect cardreader wid pc n copy all pics..
but it can be used to transfer only ur memorycard pictures..
Jun 19, 2008 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
572 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
