Question about Car Audio & Video
Refitted my c.d player into other car now it wont operate.
I removed my c.d player from my van and fitted it to my car but now it wont operate.I think it has a security code but I dont know it.Is there any way of decoding it.
    Sergeant:
    Champion:
  • 226 Answers
If you can supply me with make, model and serial number, I can get the code for you.
Posted on Nov 19, 2008
How to replace distributor cap and rotor on 1999 mercury villager van 3.3 liter engine
This is a fairly easy job. Open the hood. The distributor cap will be on the front left side of the engine as you look at it. (Passenger side on US models). It is a round plastic cup shaped part about the size of your fist. See Photo below.
***Before you remove anything!***
Take the new cap and compare it to the old one. Rotate the new one until it matches as it only fits one way round. ONE AT A TIME pull each plug wire in turn and fit it to the matching hole on the new one.
REMEMBER DO THEM ONE AT A TIME!!!
If you don't you can cause more problems and have a car that wont run.
Once you have moved the plug leads across, all 6, look at the old cap. There will be two small bolts holding it down. Unscrew these nand the cap should lift up and off. This will reveal the rotor.
Pay attention to which way the rotor is pointing. It should just 'pull' off. Match the way it is pointing and push the new one into place. It should only fit one way round like the cap.
The new cap should drop into place with all the wire in place. Refit the mounting bolts. Start the engine. It should run smoothly.
IF IN DOUBT GET A GOOD MECHANIC TO DO IT FOR YOU!!
Jan 31, 2018 | Mercury Cars & Trucks
How to insert a car radio code on a Becker radio in a Vito van that only has rotating dials and no pre-sets
If you are trying to fit this radio to a different vehicle, then you may find yourself with the Error message of "PROD". This stereo is electronically paired, or "Married" to the engine management system of the vehicle it came out of using very sophisticated CAN-BUS system technology.
When it is first powered up, it will communicate with the vehicle, and whilst this process is in operation the set will appear to function correctly, and if communication has been successfull, it will continue to operate in the normal way.
However, if removed and refitted into a different vehicle other than the original one, it will not recognise the encrypted CANBUS identification of the new car, and will instead display an error message of "PROD" after around 30 seconds.
This Radio cannot therefore be transferred from one car to another, unless it has first been reset back into its original "Delivery Mode" with the internal CAN-BUS data memory reprogrammed for use with the new vehicle.
and yes that code for that serial but i dont think your need that
Jan 01, 2015 | Becker Car Audio & Video
I removed harness to wash and have refitted shoulder straps but adjustment ******** Viaggio Primo SIP wont thread through and under buckle . can you advise please
To figure out how to do this with the Peg Preggo Viaggio Primo SIP, I think it's best to contact their customer service:
1-800-671-1701. Customer service hours are Monday - Friday 8am - 4:30pm Eastern time.
Feb 10, 2013 | Baby Gear
Kia sedona instructions to replace serpintene belt
Hi, Here is the procedure for a 2002 KIA Sedona 2.9, Engine code KJ. I I can not guarantee the followingprocedure is exactly the same as your car.
Warnings and recommendations Unless otherwise advised by the manufacturer, the following procedures are recommended: Always fit a new timing belt after removal Check the tensioner and idler pulleys; renew if necessary Never turn the engine in the direction opposite to that of normal operation Check the belt(s) for cracks, fraying, wear and oil contamination Note: The engine must be cold before timing belt adjustment Note: Avoid bending, torsion or traction General Before disconnecting the battery cable, check the audio system security code kj_t_dba_uk_6.jpg
Always check the timing marks before timing belt removal Removal Disconnect the battery Remove the radiator upper hose Remove the fuel filter unit Note: Do not disconnect the hoses carniv_j3tci_t_dba_uk_3.gif
Remove the bracket Remove the right front wheel Remove the air-conditioning drive belt Remove the ancillary drive belt Remove the ancillary drive belt tensioner Remove the coolant pump pulley Remove the crankshaft pulley Remove the timing cover(s) kj_t_dba_uk_6.jpg
Remove the tensioner Remove the timing belt Check the gearwheels, tensioner and idler pulley(s) for damage and wear Renew if necessary Installation kj_t_dba_uk_6.jpg
Align the marks on the tensioner Tighten the tensioner (23.5 Nm) Rotate the engine 2 rotations by hand kj_t_dba_uk_6.jpg
Check the tensioner Repeat the procedure if required Refit the timing covers Refit the crankshaft pulley (373 - 392 Nm) Refit the coolant pump pulley (17.6 - 28.4 Nm) Fit the ancillary drive belt tensioner Fit the ancillary drive belt Refit the air-conditioning drive belt Refit the front right wheel (88 - 108) kj_t_dba_uk_4.gif
Fit the bracket (36.2 - 53.9 Nm) Refit the engine mount carniv_j3tci_t_dba_uk_3.gif
Refit the fuel filter unit Refit the radiator hose(s) Refill the cooling system Check for leaks Reconnect the battery earth cable Torque settings Tensioner: (23.5 Nm) Timing covers (6.9 - 9.8 Nm) Coolant pump pulley: (17.6 - 28.4 Nm) Special tools Special tools are not required
Jan 06, 2013 | 2004 Kia Sedona
Seat inca van 00 sdi 1.9 diesel.. tension polly came loose.. timing belt slipped.. I need to know how to reset it again. Where are the markings on the crank shaft and the cam shaft? Please attach any...
Timing belt set-up for a 2000 Seat Inca 1.9 SDi
1. Align the crankshaft timing marks on the flywheel / gearbox
2. Remove the valve cover
3. Lock the camshaft
4. Fit the injection pump locking pin
5. Loosen the camshaft gearwheel bolt, 180 degrees. Use a wrench to counter-hold
6. Loosen the camshaft gearwheel while holding it in place
7. Fit the timing belt in the sequence as shown in the below figure: a - b - c - d - e - f - g
8. Fit the timing belt and camshaft gearwheel together
9. Turn the tensioner clockwise to align both marks
10. Tighten the large bolt on the tensioner to a torque of 20 Nm
11. Check for correct fit
12. Lock the camshaft. Tighten the camshaft gearwheel bolts: 45 Nm. Use a wrench to counter-hold
13. Remove helping tools
14. Turn the engine two rotations by hand
15. Repeat the procedure if required
16. Fit the vacuum pump
17. Refit the crankshaft pulley. Tighten torque: 20 Nm + 20 degrees
18. Fit the timing belt cover
19. Refit the valve cover
20. Fit the ancillary drive belt
21. Refit the inlet air manifold hoses
22. Check the injection timing
Torque settings:
Camshaft gearwheel: 45 Nm
Tensioner pulley: 20 Nm
Crankshaft pulley: 20 Nm + 20 degrees
May 26, 2011 | Volkswagen Passat Cars & Trucks
Can you please tell me how to change the rear wheel bearings on a 1999 Vauxhall corsa van. The make and model is not correct it didnt have Vauxhall to choose from. Thank you Rob
yes sorry but you know the americans ,they dont do geography and they beleave in flat earth theory ,lose sight of land and the world stops ,yes easy job they are taper bearings on vehicle of this age and easy to change ,hardest part is knocking the bearing paths out ,when i service vehicles and i always take the back drums off to clean and inspect and adjust the auto brake adjuster i always put some engine oil in the dust cap before i refit to keep the grease soft ,anyway dont you know this is a opel not a vauhall -GB doesnt exist anymore across the channel but its a third world religious ethnic state of mohamed .
Jan 03, 2011 | Volkswagen Corrado Cars & Trucks
Immobilser on VW polo
you need to have your car ecm reprogramed ,the anti-theft system won't let you run ,at a dealership .
Feb 23, 2010 | 1997 Volkswagen Golf
How to fit a alternator belt on a 1.8 diesal escort van 51plate
This should be the same as a car, jack the front of the car up put stands under, remove front wheels, remove bottom cover (about 7 screws), Remove powersteering pump pully 3 bolts, remove and refit new belt and P/S pully, you might get away with not having to adjust alt but if you have to youll need a 13mm spanner to undo the locking bolt then pull the alt tight (its really tight u might need a bar), once all done replace in reverse order.
Dec 16, 2009 | 2001 Ford Escort ZX2
HOW TO REPLACE REAR HAND BRAKE PADS ON A JAGUAR XJS(INBOARD TYPE) OR WOULD YOU KNOW WHERE I COULD LOOK UP A HOW TO GUIDE. I HAVE THE MANUAL BUT IT IS DOESENT REALLY HELP A LOT. MANY THANKS JIM
awkward with diff carrier in place but possible need car jacked up high as you can remove lower plate on carrier for better acces remove hand brake cable from callipers release lock tab remove the mounting bolts and the fork feed calliper round brake disc towards rear of carrier on bench note correct fitted position of pads remove nuts holding each pad clean mounting faces well if this not done new pd can be damaged fit and secure new pads unwind adjuster bolt operate calliper lever to check adjuster working should hear it click if ok refit io car guide in poition locate in position a taper gound on to bolt helps as easy to miss hole in calliper when happy it correct gently remove bolts fit fork and tab secure bolts engage fork lugs in calliper arms operate calliper lever by hand till freeplay is taken up pads now in correct position do other side refit cable and lower plate good luck
Oct 13, 2009 | 1986 Jaguar XJ6
How to install a clutch ratchet for ford escort van
Hi
If its the self adjusting pawl and ratchet on the pedal you're on about then its a nightmare, and your life will be so much easier if you actually remove the pedal assembly, fit the pawl and ratchet to it, and then refit the pedal assembly.
I think there are about 4 or 5 bolts if I'm not mistaken, a couple or three inside the car and a couple or three under the bonnet on the bulk head.
Once you've got the pedals off all will become clear.
Very best regards
Geordie
Jun 19, 2008 | 1996 Ford Escort 4 Door
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
