Question about Casio Exilim EX-M2 Digital Camera
Casio ex-m2 My camera turns on, but will not record with or without the sd memory card installed. the flash will not even come on. the lcd turns on, and the exilim start up screen appears, and then the scene where the camera is pointed to shows up on the lcd screen. when i depress the shoot button, nothing happens.
    Genius:
  • 2,985 Answers
Does the Camera have internal memory? I think you need the card it to get any where Check out the manual
Posted on Aug 12, 2007
Videoing in hd mode with sdhc 8 gig card, sound stops recording at about 42 seconds.
The SD memory card maybe too slow. Use a class 8 or class 10 SD memory card.
Nov 25, 2012 | Casio EXILIM Hi-Zoom EX-H10 Digital Camera
I have a Casio Exilim ex-z40 camera and tried to install a 4 GB memory card. The camera says "Card Error". Will this camera take a 4 GB card or should I stick with the 2 GB I have in it now?
The EX-Z40 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work. You need to stick with SD cards, 2GB and smaller.
Feb 13, 2011 | Casio Cameras
Does this model supports sdhc cards?
In addition to its 10 MB of built-in Flash Memory, the EX-Z3 also supports use of a thin, compact SD memory cards and MMC cards (not included)
Dec 13, 2010 | Casio Exilim EX-Z3 Digital Camera
Problem with taking picture with SD card
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Nov 07, 2008 | Casio Exilim EX-Z750 Digital Camera
System error 0e01
Maximale Kapazität von SD-Speicherkarten bei Verwendung mit CASIO Digitalkameras Error 0e01: It has to do with the maximum save capacity of the used SD-Cards (max. 1GB for following models). You can format the card (somehow, maybe with docking station), then it would only have 1GB capacity...
...found on Casio Homepage...
Bitte beachten Sie, dass die folgenden CASIO Digitalkameras die Verwendung von SD-Speicherkarten mit Kapazitäten von mehr als 1 GB nicht unterstützen. Bitte berücksichtigen Sie dies beim Kauf von SD-Speicherkarten für diese Kameramodelle.
CASIO kann nicht für die ordnungsgemäße Funktion von SD-Speicherkarten in den Kameras garantieren, auch wenn die Kapazität der Speicherkarte 1 GB nicht überschreitet.
Für welche Modelle ist dies gültig?
  • QV-R3
  • QV-R4
  • QV-R40
  • QV-R41
  • QV-R51
  • QV-R52
  • QV-R61
  • QV-R62
  • EX-S1
  • EX-S2
  • EX-S3
  • EX-S20
  • EX-S20U
  • EX-S100
  • EX-M1
  • EX-M2
  • EX-M20
  • EX-M20U
  • EX-Z3
  • EX-Z4
  • EX-Z4U
  • EX-Z30
  • EX-Z40
  • EX-Z50
  • EX-Z55
  • EX-P600
  • EX-P700
Welche Probleme können auftreten?
  • Die Fehlermeldung "CARD ERROR" wird auf dem Bildschirm angezeigt. Die Aufnahme von Bildern ist nicht möglich.
  • Wird die Speicherkarte in der Kamera formatiert, reduziert sich die Speicherkapazität auf ca. 1 GB.
Jun 08, 2008 | Casio Exilim EX-Z40 Digital Camera
Casio ex-z60 cannot read memory card
Make sure that the SD card you are using is either a SanDisc, Toshiba, or Panasonic. Those are the only cards that have been tested with Casio cameras. Also make sure that you format the card WITH THE CAMERA before you try and use it the first time. If it still doesn't work I would try resetting the camera and then you should have no problem.
May 29, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera will not read memory card
Make sure you format your memory card before you try to use it other wise it will save the pics to ur internal memory instead of the mem card.
May 01, 2007 | Casio EXILIM ZOOM EX-Z10 Digital Camera
Can this model record without a memory card?
This model comes with 8.9MB of flash memory built in, which means you can record without using a memory card. Even when using flash memory, however, you still need to set the correct date before recording. If you do not set the date, certain functions may not operate and proper image recording may be impossible. Also, folders created automatically by the camera will not be named correctly if you do not set the date
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Casio Exilim EX-M2 Digital Camera Logo
85 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Steven Wander
Steven Wander
Damen Wong
Damen Wong
Are you a Casio Camera Expert? Answer questions, earn points and help others
