Hello I have a memorex 21" crt. There was a recent poer surge and something happened. now when i connect the tv to the mains i can see smoke coming from the back. the power light comes on sometimes. once the picture came on but it was full of wierd lines, like static.
    New Friend:
  • 99 Answers
If u can see smoke then u should know tht something is burning inside.
U have to take it apart to repair. if u donno how to repair then get a service tech.
Cheers
Rifaa
Posted on Nov 20, 2008
Tv model #46h84 wont turn on no picture or sound
Hi
Assuming thar you can open the tv case and deal with electronic parts, you should first check the main fuse. If it is OK, check the anti-surge resistor (generally 3,3 Ohms/5W). One of these components may be bad. Before replacing the bad one, check for short in MOSFET power switching transistor, fast output rectifier diode (+ or - 90V line voltage). After findind out the culprit replace the bad components a afterwards plug in the tv and test.
Good luck. I hope this will help you.
Sully
Sep 25, 2013 | JVC AV-A21M3U 21" TV
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
Sony bravia works on ups/battery not mains :(
Sure sounds like the power supply board received an insult that allowed a different voltage to work for a while . UPS will regulate top 120 volt whereas mains may be higher or lower . You may be able to change bad capacitors or just buy the power board between 80 to 200 dollars .
If it was connected to UPS during surge it should have been protected...make sure you are connected to 'battery' side as a lot of UPS have a 'surge only' side that will not stop a rapid on/off power insult .
Hugh
Mar 02, 2017 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Model 3221. Observed smoke out of the top of TV. Screen went blank, but sound and all other functions are fine. No sign of anything appearing burnt on inside circuit boards.
Where there is smoke be careful---something burned---If you cannot see it voltages will have to begin with be tested and it is possible it happened inside a place where it cannot be seen.
Look down in the area where the smoke was seen--a part or a wire or a plug even may have smoked.
May 27, 2012 | Memorex Televison & Video
I need the code for a GE Universal remote Control for a memorex TV
Hello, you will find the complete code list in the ge' website: jascoproducts.com / you will need the model number for your remote.
Oct 20, 2010 | Memorex MT2271 27" TV
BPL TV MODEL FQR 21 don't start due to moisture
i have a cpu but my monitor has been broken so i wanted to connect my Bpl feb 21 tv can i?
Sep 09, 2009 | Televison & Video
Purchased ilo tv.3/28/08.power surged.have bad pic.or none.do have 2-year warranty.direct tv.says it is the tv.i can not find correct category to return .thank you for your help joe murphy
Hello Joe. Walmart is one of the main distributors of this TV. Any Walmart should be able to honor the warranty. A word of caution for you my friend, mentioning the word power surge may void the warranty.
Jul 15, 2009 | Televison & Video
Memorex mt2024
try 1234, 0000, 1111, 2222, etc
Feb 24, 2008 | Memorex MT201224 20" TV
Won't turn off...constant hissing...blank sreen
Sounds like a power surge likely followed the outage- or maybe you were actually hit by lightning- and since this set did not have a built-in kill-switch (circuit breaker) it could have very well caused some significant damage. Check the internal fuses, if they are blown, chances are, so is the rest of the set. For the cost of repairing something as over-reaching as this, I'd be looking for something new (And be sure to buy a quality surge protector, so this does not occur again!)
Hope this helps in some small way!
Aug 16, 2007 | Memorex MT2274 27" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
