Question about Epson LQ-2180 Dot Matrix Printer
The pause light on my lq2180 is permanently on
I have checked sensor on the right side of the printer and the problem still pesists
    Novelist:
    Champion:
  • 254 Answers
Check the paper sensors in the paper path, and the printhead home sensor. Paper path sensors (one or more) will be present somewhere around the platen & tractor feed areas. Printhead home will be over on the left side in the printhead movement area.
Logic board defects could likely cause this same issue, diagnosis here could be more difficult.
Posted on Nov 20, 2008
Printout not align and faults indicates led lit up
The Media Sensor is not seeing the labels or is not configured for these labels. Check Media Sensor position and settings. The Fixed Sensor models have a small window for the sensor at the bottom of the printer, about 3/8" to the right of the left side. If the printer has a movable sensor, the typical position is either 1" to the right of the left edge of the labels, or in the center of the labels. Typical media sensor setting is "Gap Mode". Another common issue is that the sensor might have a piece of label or something stuck to it, covering the lens. Finally, there is a possibility that the reflectivity threshold may need to be recalibrated (see below). This can be difficult, although there are instructions in the Operator's Manual. If physical position/clear view of labels by sensor doesn't seem to be the issue, an easier way to deal with settings issues might be to Restore to Factory Defaults (see below).
Datamax E-Class Auto Media Calibration Procedure:
The 'Auto Media Calibration Procedure' allows the operator to
automatically obtain the optimum (TOF Low and TOF Delta) values for
a particular media. These values are useful for media that continues to
have troubles after Media Sensor has been manually calibrated (usually
preprinted media). This operation feeds 10 inches of media using the
current Media Sensor Calibration setting and calculates the TOF Delta
and TOF Low values to be used. Upon completion the printer will exit
back to 'Calibration Mode' flashing the PAUSED light if successful or
the FAULT light if not successful.
Note: Before calibrating, be sure the media sensor is set for the
appropriate media type, see section 4.4.2, also be sure the
printhead is latched down and the cover is closed.
To perform the Auto Media Calibration complete the following steps:
1. Load the desired media.
2. Hold the button while powering up the printer. Continue to hold
the button until the PAUSED light turns off then release.
3. Next press the button, (the printer will now calibrate to the
media)
4. The PAUSED light will flash 5 times to indicate a successful
calibration. The FAULT light will flash 3 times to indicate an
unsuccessful calibration.
Note: If you wish to discard your changes and revert back to the
previous calibration simply turn off the printer before Step 5.
5. Now you can save your changes and resume by again
pressing the + buttons simultaneously.
Datamax E-Class Reset to Factory Defaults Procedure:
With the printer off, press and hold the F1, F2, and F3 buttons while
turning the printer on. Continue to hold the buttons down until the
PAUSED light turns off. The printer will now be set to the 'Factory
Defaults'.
Jul 22, 2014 | Datamax DMX E4203 Printer
How to adjust the top margin for epson lq-2190
Turn on the printer.
Load paper
Press the pause button until the pause light is flashes.
Press LF/FF button to move up or LOAD/EJECT button to move down.
Press the pause button to save.
This save is permanent until you change later.
May 09, 2012 | Epson Office Equipment & Supplies
How to restore default configuration
From the user manual:Feed and Pause self testperforming this self test temporarily resets the printer configuration to the factory default values. these values are active only until power is turned off unless you save them permanently in memory. If the factory default values are permanently save, a media calibration procedure must be performed.To perform a Feed and Pause self test, complete these steps:1. Turn off (O) the printer.2. Press and hold FEED and PAUSE while turning the power On (I)3. Hold FEED and PAUSE util the first control panel light turns off.the printer configuration is temporarily reset to the factory default values. No labels print at the end of this test.
Nov 29, 2011 | Zebra Z4Mplus Label Printer
I have Epson LQ 2180. When Ever i load paper from rear tractor feeder it loads the paper and still shows the paper out LED. If i press Load/Eject button it only loads the paper not eject. I have cleaned...
Hi
My friend we have LQ2180 in our office, there i a lever in the right side of the printer that indicates when you print your document. Adjust to upward to print the document from rear tractor and to print from the front push the lever downward. Maybe you accidentally, push down the lever.
Any problem, just message me. Regards.
Jan 11, 2011 | Epson LQ-2180 Dot Matrix Printer
Lq2180 when print few lines, the printer pause light on, press pause button print again, than pause again, need to stand there and keep pressing pause light
its may be heaving problem with the control panel clean replace the buttons or replace the control panel and check it ................
Dec 22, 2009 | Epson LQ-2180 Dot Matrix Printer
When I turn on my HP PSC 1315 All-In-One printer, it shows permanently 'check cartridge'. I did all the trobleshooting but the problem pesists. Can anybody give help?
I had a psc750 that did the same and no matter what I did or tried, including all the stuff from the manual and HP's website, I could not fix this. Also tried Googling it and found it was a common problem with no easy fix.
When inquiring about getting it fixed professionally, practically everybody I spoke to said it wasn't worth it as it would cost as much if not more than buying a new one.
So, unless it's under warranty, it's probably time to say goodbye.
Sorry.
Sep 07, 2009 | HP PSC 1315 All-In-One InkJet Printer
My epson lq2180 doesn't pull front tractor
check the setting on right hand side above the nob probaly you haven't positioned on the correct place,aslo check on the gears for the tractor be aligned with the roller/mast
Jul 23, 2009 | Epson LQ-2180 Dot Matrix Printer
LQ-2180 printer is Continues blinking front panel lights.
The LQ2180 blinking lights can be caused by paper jammed, printhead overheated, paper loaded not detected and cover unclosed. Try to check all this first, you may have a fragment of paper stick to the sensors, or broken sensor. If all of the light flashing try to check the carriage movement, move it side to side, but with power off condition. If the carriage movement not smooth or stuck, look for any foreign matters inside the carriage path that blocking the movement if not, try to lubricate the rail which hold the carriage. If this doesnt solve you, the machine require parts replacement.
Apr 14, 2008 | Epson LQ-2180 Dot Matrix Printer
PAPERS PRBLEMS ASSOCIATED WITH LQ2180
check paper feed machanism and paper in sensor open your printer and clean the sencer
Oct 02, 2007 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 Dot Matrix Printer Logo
877 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
