Using Dell oem xp sp2 installation disk to do sfc
I need to do a sfc /scannow on my Dell pc but am afraid the moment I put the cd in the drive it will automatically start reinstalling windows. Once this happens there is no way to cancel. The cd states that it is only for reinstallation of windows. If I run sfc /scannow and it requests for the cd should I put the cd in the drive without worrying it will automatically start to instal windows?
Thank you for your very kind attention
  • Tanzanos Mzungu Nov 19, 2008
    That is what I thought last week; when I put the cd to check its contents it automatically started installing windows without asking and there was no way to stop or cancel it. I ended up loosing some settings etc. Now windows is misbehaving and I want to do sfc /scannow but am really scared that if upon sfc request to put the cd I end up with the cd reinstalling windows.
  • 488 Answers
There is always an option where it says whether u want to install windows,it will not do that before u give permission..there will be a repair option too..what u can do is right click on the C drive and use the options to check for errors..hope it helps!
Posted on Nov 19, 2008
How do I restore XP rundll32.exe?
I've used SFC to repair Windows 2000/2003 servers in the past, it debuted in Windows 2000 and it fixes system dlls. Start > Run > type 'cmd' and 'sfc /scannow'. You will have to insert a Windows XP SP2 cd for it to work (or mount and ISO of XP with a tool like alcohol 120).
If the %systemroot%\system32\dllcache folder becomes corrupt or unusable, use sfc /scannow, sfc /scanonce, or sfc /scanboot to repair the contents of the Dllcache directory.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/system_file_checker.mspx?mfr=true
Jan 12, 2012 | Toshiba Satellite P105-S9337 Notebook
How to restore the operating sytem once corrupted?
Must use the rescue disk that came with your computer.
Nov 24, 2011 | Acer Veriton M265 (PSV880Z001) PC Desktop
ASUS X5DC Series.Problem loading page, server not found. System restore cannot fix, what can I do?
hello dear how r u so if you have a os windows xp sp2 then u go to start or type in run
commond first you insert the windows xp sp2 cd in optical drive then you type in run this commend
SFC /SCANNOW and enter
all the files of windows xp repair in just few mint in windows
after complet restart your computer
Dec 27, 2010 | ASUS Computers & Internet
Windows explorer not responding
Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files. and run reg in out registry cleaner also
Sep 20, 2010 | Microsoft Windows XP Professional SP2
When trying to reinstall windows xp, the process keeps failing during setup saying, "The file comct132.dll was not copied correctly. The file Setup on your hard drive is not a valid Windows XP system...
Click start/run Type: cmd
In the Command window type:
SFC /scannow Note the space between SFC and /scannow
You can copy/paste: SFC /scannow
Hit the Enter button
keep your xp cd handy in case you're asked to chuck it into your cd rom
The above should replace missing files and get you to the place where the install can proceed.
Let me know. __________________
If this doesnt work,yes hard drive needs to be replaced.internal hard drives are system specific.u need to contact dell tech support to get the right specifications
Sep 17, 2010 | Dell Dimension 4600 PC Desktop
RAN RECOVERY DISK AND NOW CAN'T GET ON LINE
The suspicion of possible errors in the system files in Windows, it may be worth a try to run the "hidden" program that comes with just Windows.
System allows an administrator to scan all protected files to verify their versions.
If System File Checker discovers that a protected file is overwritten, it retrieves the correct version from the cache folder (% Systemroot% \ System32 \ Dllcache) or source files for Windows installation, and replaces the incorrect file.
System File Checker also checks and filling up the cache folder. You must be logged on as an administrator or a member of the Administrators group to run System File Checker.
If the cache folder becomes damaged or unusable, you can use the sfc / scannow, sfc / Scanonce or sfc / scan boot to repair its contents.
To use SFC:
1) Press Start
2) Select Run ...
3) Enter: sfc / scannow and press OK
you should find the windows cd and put itin the cd player on the PC, if you have some corrupted system files so the process will bring it from cd to the computer
Sep 09, 2010 | HP Computers & Internet
My laptop does not working and some windows file missing pls give me advise how to recovery my window
You need to have windows disk in oreder to repair or reinstall windows, IF you have it, insert it in drive and restart your computer and follow the instructions on the screen to install windows, if you are using HP or dell laptop then you must have the recovery disks from which you can do recovery, if you misplace it then you may get in touch with HP or DELL and they will provide you the set of recovery disk.
Mar 23, 2010 | Computers & Internet
My toshiba has no sound
there is some system files are missing .
Go to start menu then type in run "cmd"
then ou see command prompt.type there "sfc /scannow"
then it scan for corrrupt system files when it need winxp source put the winxp disk in cd-rom then it get files.
Jul 15, 2009 | Toshiba Satellite A75-S213 Notebook
Copy paste
1. Type http://djlizard.net/software/Dial-a-fix-v0.60.0.24.zip in internet explorer address bar and hit enter and save the file on your desktop. after that try to open it and run dial-a-fix select all option then close it and restart the computer.
2. Try this:-- Internet Explorer, Tools, Options, Security tab, "Custom Level" button, Misc: "allow cut and paste for files", dot the "allow"
3. Try to run sfc /scannow and restart the computer ( Click on Start> Run> Type sfc /scannow )
remember inbetween the scanning you need to insert the windows XP sp2 Disk.
Nov 22, 2008 | Computers & Internet
Hello I just purchased a new hard drive for a dell inspiron 8100 and mistakenly loaded the winodws xp upgrade cd instead the plain old xp cd. Now I am getting an eroor which says ntdetect failed. Any...
Hello:
You can do reload the old xp by going to reformat the hard drive and install fresh copy of old xp:
installing windowsxp information can be found here:
http://support.microsoft.com/kb/316941
note: copy and paste the link to your internet browser address bar.
melnavz
Sep 03, 2008 | Computers & Internet
Computers & Internet Logo
133 people viewed this question
Alun Cox
David Payne
David Payne
