Question about Philips Televison & Video
Have a philips A10E Tv. Started switching itself off and being eratic. When using the remote the IR light flashes on set but nothing happens. Now there is a letter "F" on r/h corner of screen. I hope the F does not mean what i think it does?
    New Friend:
  • 99 Answers
HI
I checked the service manual for the letter "F", but could not find any thing related.
Could u describe the picture u see when u turn on the TV and any other observations
Rifaa
Posted on Nov 20, 2008
Sony bravia tv constantly changing channels
Is the tv new or has it started to do this recently ?
Try to eliminate the obvious.
Does the remote continue to flash when you release all of the buttons? Is it a stuck button ?
If you cant' see the remote output, try using your smartphone camera. Most phone cameras will capture infrared light ( invisible to the eye). Aim the remote at the camera and see if you can see the flashing light, which is data being sent to the tv. When you release the buttons does the flashing stop ? If so remote is ok
Next turn all of the lights off in the room with the tv. Also turn off any lights that may shine in from other rooms. Try using the remote
If your tv functions normally, you may be getting interference from your lighting. Some LED and CFC fluorescent lights flicker at a rate which may be close to the remote IR output frequency.
If turning off the lights fixes the issue, turn on each light to isolate the issue. Replace the bulbs with ones from different manufacturers.
Let me know
Oct 24, 2017 | Sony Bravia KDL-26V4000 26 in. HDTV-Ready...
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
Manual switch ok but remote not fundtion sharo tv
Be assured that fault does not lie with the remote handset itself. In that case repair or replace it.Remote control system has two parts. One is the remote hand set and the other lies within the TV or other device for which remote controller is being used. The hand set transmits commands in shape of singnals of particular frequency and pulses per second depending on the key pressed. The other part of the remote system lying within the TV receives, decodes and responds according to the commands received in shape of signals of particular frequency and pulses of paricular width and sequence. The remote controller uses invisible infra red light as the carrier of the signal. As the light moves in straight path, no obstacles should block straight line of sight path between the remote hand set (the transmitter) and IR sensor window (part of the receiver). Hence remove the blockage from the front side of the TV.Check if the IR sensor is not defective. Check if the associated circuit and components inside the TV are not defective.Check if the TV has any switch for selecting only manual mode and locking the remote mode.Hope, some sytematic exercise will bear the successful result.
Feb 19, 2012 | Sharp LC-32SB21U 32 in. LCD TV
Westinghouse tv turns off with rmote but cannot be turned on unless button on tv itself is used
How old are the batteries in the remotes? The on/off signal from the remote is the same. There is some lattitude in the IR reciever module for what it accepts. Low battereis may be shifting the signal's frequency or light intensity enough for it to not be recognized.
If sunlight is failing on the sensor or the remote's IR emitter, that can cause interference. Other IR devices can also interfere with the IR signal such as a "Remote Extender" being used for something else.
It may sound odd, but if your remote was working one day and not the next- was the room rearranged? If so, look around for possible sources of interference blocking the beam from the remote, or shining or reflecting light onto the IR reciever module in the set.
Dec 30, 2011 | Westinghouse Televison & Video
Remote control stopped working so i purchased a new remote control that doesnt work so now i am presuming it is the tv sensor itself
Brand of the TV? Yes it can be the IR receiver or the REMOTE switching jack if it has one in the back of the TV.
1) Test the remote:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
2) If the remote checked out OK, then look at the back of the TV for the "REMOTE INPUT", use a mini-phone plug and insert the plug ino the remote input jack in and out a couple times to clean the switch contacts that select between the front IR receiver of the TV or the rear panel IR input jacks.
See: http://www.fixya.com/support/t9056223-remote_doesn_39_t_work_all
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Apr 28, 2011 | Televison & Video
My lg doesn't work with any remotes! I checked my lg remote - put in new batteries (correctly) - and no change. I reconfigured my directv remote & nothing happened. At this time I have to turn tv on...
This TV may have IR remote input jack in the back (the size of small headphone jack), when the external remote receiver is used, it will shutoff the remote receiver in the front of the TV, this jack has a switch inside which can get corroded if its contacts are not activated once in awhile. You can plug in a small headphone plug into it a couple of times to see if the remote will work again.
And here is how to test the remote to see if it still putting out the IR signals.
Testing remote control:
Plase post back.
Dec 03, 2010 | LG Televison & Video
My tv doesnt respond to the remote any more. I fitted new batteries but nothing - not even to stich it off> TV works fine from the on set controls
www.remotes.com
Oct 21, 2010 | Philips 42PFL7403D/27 42 in. LCD TV
Remote not working
i've a philips video player model no  ( DVD622),remote not working
May 23, 2009 | Philips DVDR3575H/37
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
Televison & Video Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
