Question about JVC KW-AVX810 Car DVD Player
JVC KW-AVX815 Player USB Source does not recognize 2.5'' HD
When connecting the portable 2.5" HD to the USB source, error showing not able to read device. Verified with USB thumb drive and it works perfectly. Any firmware update needed for the player set to recognize portable HD ??? Has it got to do with HD driver missing ????
Hope to have the portable HD connected so that I can enjoy the storage capacity for videos & music. With USB thumb drive, limited video files can be stored. Appreciate yoru kind advice and solution for my problem.
Thank you so much!
I got my portable drive to work by partitioning to 127gig fat 32 only the old fat32 not the vista version it wont read above that or recognize files if you make it larger
Posted on Apr 04, 2009
    New Friend:
  • 99 Answers
I think these are the possible reasons
1. It could be the HD is faulty.
2. Format the HD to FAT32 partition.
Some players can't recognize NTFS partitions.
Posted on Nov 20, 2008
    Problem Solver:
  • 15 Answers
How big is the Hard drive? the unit might not have enough storage space on board for the part table. when you plug in the drive the head unit loads the part table so it knows where to find the info. Try to only add a few files and only have those files on the drive only 100 or so then plug it in and see what happens. If it works that is your problem, the drive is to big and the head unit can't see something that big.
Kd-r400 can't recognize usb
You might have to reset the logic by disconnecting the power to the unit. Remove the fuse temporarily, or both fuses if it has 2.
Feb 18, 2014 | JVC KD-R400
Buttons not working on JVC KW-AVX730
There must be some short circuit between the buttons. How much old it is?
Chevrolet Performance Chips
Aug 12, 2012 | JVC KW-AVX730 Car Video Player
JVC KW-xr810 source changes by itself/randomely. IS it a swc problem with my Tacoma?
I would suggest you install a 12 Volt power filter to the device in question, this will filter out any spurious electrical noise that may be triggering this problem, These filters are available on line and any auto sound supply store or center.
Jan 15, 2012 | JVC KW-XR810 Car CD/ MP3 Player
When i plug my usb into my pionner car cd player , i read error 19 what does mean ?!
This is what it says in the owners manual.
ERROR-19 Communication failure
Perform one of thefollowing operations-
-Turn the ignition switch OFF and back ON.
-Disconnect the USB portable audio player/USB
-Change to a different source. Then, return to the USB portable audio player/USB memory.
Mar 09, 2011 | Pioneer FH-P8000BT Car CD/ MP3 Player
Can i on usb of this radio a portebel 1T hd working? a usb stick wil work but a hd not is there a solution? gr ray
Unfortunately not, First, Most Many Decks don't offer a powered USB port. Because the Portable HD has Moving Parts It can't start up without a power source. Also Many HD require specifi Drivers in ordered to be Functional, which the Deck most likely does not have installed on it... and unfortunately I don't brelieve there is a way to do intall them. One Solution you could try is to buy a external drive that has a seperate power source from than the usb and then try plugging it into an inverter and connecting it to the deck via the usb. I can't garuntee it'll and i believe you may just be better off purchasing a large capacity flash drive. Hope this helped
Jan 08, 2011 | Pioneer Avic-f900bt In-dash Dvd...
JVC KW-AVX710 not save. after switch off the car .when start it again all settings become to default
If your unit is not maintaining it's memory, it may be associated with the lack of a constant 12 volt power source. Test the units yellow wire, it should rest at 12 volts with the key in all positions; off, acc, on/run, start. This yellow wire should be connected to the vehicle's battery wire. Also, test the red wire. This wire should be connected to a switched 12 volt power source. It should read 12 volts with the key in accessory and on/run only. If you used a vehicle specific wiring harness to complete the installation, the wires may be switched in the harness. It's not a common issue but, I have seen it happen.
Dec 04, 2010 | JVC KW-AVX710 Car Monitor
Jvc kw-nx7000 won't turn on
have you check all your power source
Jul 06, 2009 | JVC KW-NX7000 Car DVD Player
Bypass parking brake
Does the suggestion by djBass work with the avx800 too?
Feb 16, 2008 | JVC KW-AVX800 CD Player
JVC KW-AVX810 Car DVD Player Logo
1,724 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
