Question about Hitachi 43FDX20B 43" Rear Projection Television
Using data what dose (+2x3000PF(Y))mean in (0.2microF+2x3000PF(Y))?
  • 979 Answers
This forum is for troubleshooting electronics. While this formulae could be an engineer's axiom for a given solution, us lesser folk need a trouble reference...
Posted on Nov 20, 2008
    New Friend:
  • 99 Answers
I'm rather confused ???
I really don't get you.
Could I put a toggle switch in my car instead of a ignition switch in a 2001 Chevy cavalier? What all dose a toggle switch require to work? What dose it all need to connect to?
On vehicles that have several control modules connected by serial data circuits, one module is the Power Mode Master, PMM. On this vehicle the PMM is the BCM. The PMM receives 2 signals from the ignition switch.
To determine the correct power mode the PMM uses the following circuits:
Accessory voltage
Ignition 1 voltage
Sep 29, 2015 | Cars & Trucks
What dose code 10 mean for my proscan 7 inch tablet
It means you will likely have to do a "factory reset." That would return the tablet to "fresh out of the box" status. Yes, you lose what ever has happened since then.
1. Look for the reset hole on the sides of the device. 2. Poke the hole for 5 sec. using a paper clip or a pen. 3. The device will reset. If that did not worked try this. 1. Power off the device. 2. Press and Hold Volume down and Power button at the same time till you see the recovery screen. 3. Use volume down and select Wipe data/factory reset. 4. Press power button to accept. 5. Use Volume down and select YES. 6. Press power button to accept. 7. Press Power button to select Reboot after the reset.
Otherwise, you might have to take it to a shop or send it off and you won't like what that will cost if it is not under warranty.
Aug 26, 2015 | Tablets & eReaders
Why dose the data light keep flashing
that's normal, it means that there is data flowing. If it wasn't flashing then your router would not be working correctly.
Jun 14, 2014 | Computers & Internet
Dose useing air conditioning in the summer make your vehicle use more gas?
Yes, it does. The reason why is, the engine works a little harder due to the A/C compressor having to be "worked"....meaning, it is an extra component putting a strain on the engine.
May 20, 2010 | 1998 Ford Taurus
Blue screen & A message pop-up on my ToshibaSatellite A105-S4011:
try removing some unwanted programs. run disk cleanup, then defrag
Apr 04, 2010 | Toshiba Satellite A105-S4011 Notebook
When it says LINE ERROR what dose this mean
That indicates that there is static or interference on the phone line. You will need to call your phone service provider for them to test the line.
Feb 11, 2010 | Office Equipment & Supplies
What dose the icons mean on front panel what is the little square hole for next to the mike connection
hello, it is most likely a firewire connection.
FireWire, originally created by Apple and later standardized as IEEE-1394, actually preceded USB and had similar goals. The difference is that IEEE-1394 was originally intended for devices working with lots more data -- things like camcorders, DVD players and digital audio equipment. IEEE-1394 and USB share a number of characteristics and differ in some important ways. Here's a summary:
  • Like USB, IEEE-1394 is a serial bus that uses twisted-pair wiring to move data around.
  • However, while USB is limited to 12 megabits per second, IEEE-1394 currently handles up to 400 megabits per second.
  • USB can handle 127 devices per bus, while IEEE-1394 handles 63.
  • Both USB and IEEE-1394 support the concept of a isochronous device -- a device that needs a certain amount of bandwidth for streaming data. This mode is perfect for streaming audio and video data.
  • Both USB and IEEE-1394 allow you to plug and unplug devices at any time.
hope this helps,
Amar Sondhi
Dec 05, 2009 | Medion M3 Director 5100 PC Desktop
What dose e13 means
error, code 13 for service man
Oct 04, 2009 | Black & Decker Heating & Cooling
What dose the red light mean on the usb stick
it depends on what stick you have, usually you have 2 lights, one will stay on constantly indicating power, the other will be data transfer (this will flash wildly whenever data is read or written), good luck
Aug 24, 2009 | Electronics - Others
Wat dose it mean when your battery sign on ur sk is a thermometer
means your battery has gotten to hot to charge, take if off the charger for a few and try again.
Jun 09, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Hitachi 43FDX20B 43" Rear Projection Television Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
