Question about Linksys Wireless-G WUSB54G 802.11g/b
Problem connecting to my network
I have a dsl wireless broadband router upstairs, which is my main gateway into the house. I am also receiving TV through this connection. I have a hard wire I have run to down stairs, where my tv decoder and tv is. Everything worked great, but i had terrible wireless recption downstairs, so I purchaced a Linksys 54G wirelesss router. I hooked the wire from upstairs to the switch portion of the router. My problem is, I can surf the net only when I remove the connetion going to my tv decoder. If my tv decoder is hooked up, and streaming media to my tv, my laptop cannot connect to the downstairs switch. Did I by a router that doesn't have enough horsepower? I can not run another wire from upstairs, as this is a concrete house, and the conduit if full. Do I need to buy a more powerful router, or should I install a switch before the router. Thanks Andy
    Scholar:
  • 57 Answers
Well, I am probably not seeing the entire picture here, but trying to figure out why you have two routers going. Sounds like you have one upstairs and one downstairs, and they are not speaking to each other, or they are cancelling each other out. And by tv decoder, I am guessing you mean a cable box.
You only need ONE router, no matter where you choose to put it. All other computers should connect via a wireless ADAPTER, like a Linksys WUSB54G.
Wherever you have your main cable coming in to the house is where you should also try to have your router hooked up. Then all others would use wireless adapaters to connect.
Here is a link to the Linksys tutorial videos. It might help to find a scenario like you want, and then see if you have anything misplaced based on their layout graphics....
http://tinyurl.com/5zzbdq
Posted on Nov 23, 2008
  • 3 Answers
First, you didn't say just how far away the DSL wireless modem/router is from the downstairs TV, and if wireless reception is the problem, you could have simply upgraded one or more of the antennas to improve reception. If the wireless network adaptor downstairs is a notebook unit (i.e. one of those small PCMCIA cards, or some other style that do not accept an external antenna), you might try a different adapter with a wired connection to its antenna, so that you can position the antenna for optimum reception, or even upgrade it to one with greater gain. While many wireless routers can be fitted for better antennas, relatively few wireless network adaptors offer this feature, replacing the adapter may involve some searching.
Second, you description of the wiring is a little vague, but if you have wired the output of the upstairs DSL modem/router to the switch portion of the downstairs unit, the CAT5 cable should be a "crossover" type cable rather than the usual straight-through cable (in a straight-through cable, the colored wires in the RJ45 plug at each end are wired identically; in a crossover cable, four of these are switched); AND you would need to disable the DHCP server on the downstairs router (there should be only one DHCP server on each network, and this configuration "joins" the two routers to one network); AND ensure that the two routers are assigned to different WiFi channels. An alternative might be to wire the output from the upstairs router to the input of the downstairs router with the wire you already have; that would isolate the two routers, but your two computers might not then "talk" to each other because then they would be on different network segments.
Third, you need to be certain your new Linksys 54G router is properly configured to (a) enable wireless connections, (b) accept wireless connections from the MAC address of the wireless network adapter of your downstairs computer, and (c) ensure that either WEP or WPA encryption is properly configured for both the router and network adaptor. Some wireless routers are factory-configured to enable all features without any security, while others are configured with only some features enabled, and security essentially locked down. If yours is pre-configured as the latter, you'll need to change the settings for your installation; if yours is the former, you should enable some security once you're satisfied your setup is working.
Hope this information helps.
Posted on Nov 20, 2008
  • 57 Answers
I believe you don't need to remove the original setup from your old router all you have to do is to change the IP address of the second router by changing the default of 192.168.0.1 into 192.168.1.1 for the LAN side.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
It sounds like you have it setup wrong.  The Decoder is built to get random information and change it into something your TV can understand.  I own a linksys Wireless-G Wusb54g, and I can tell you that they are good little gizmos.  You may have done this but make sure that it is in this order:  1.Wire to Decoder. 2.Decoder to TV (and WiFi)
If you still have problems CALL YOUR PROVIDER!!
    Master:
  • 409 Answers
Or you could spend £10 and buy a better antenna for the original wireless router to boost the signal
    Scholar:
  • 162 Answers
What I would do is replace the wireless router with a 4 or 5 port switch to control computers (devices) downstairs. Or, if you need wireless access, purchase only an access point to cover downstairs.
This way the wire from upstairs goes directly into the access point and you have wireless access downstairs.
And yet another way would be to purchase Airlink 101 PowerEthernet boxes ($54.99 each) and use those to connect an access point anywhere in your home that has an outlet.
    Problem Solver:
  • 14 Answers
If you have not done so yet, put the Cat5E cable coming downstairs into the WAN port of the downstairs router. Make sure that the WAN/Internet light comes on. There is a small possibility you will have to get a gender changer for your Cat5E cable. Connect your TV decoder into the 4 port switch. The router should be set to get it's settings from the upstairs router.
Good Luck
Gus
Just bought a used gateway laptop model#m320s3400335 and cannot get internet access through a wireless network or online at all.
SETTING UP A BROADBAND CONNECTION
First you need to decide what type of broadband and Internet service you require and these are -
1. DSL that uses your existing telephone line.
2. Cable that uses a cable service and can include a cable TV service.
3. A wireless 3G network uses the mobile/cell phone network and can be separate or combine with your cell phone account. This type of Internet connection uses an USB wireless device shaped like an USB memory stick.
Note - Combined services generally offer discount pricing and may include a modem/wireless router.
If you use a wireless router with the DSL or Cable Internet service then your laptop with a wireless card can then connect to the Internet. You can also connect to a free WiFi hot spots like McDonalds, Star Bucks, the Airport etc. using the wireless card in your laptop.
If you use the wireless 3G wireless broadband service, then you can access the Internet anywhere where your ISP has 3G wireless coverage. You need to check the service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to check with the various Internet Service providers to see if they can offer and the cost of the various plans.
Note the download limits and the associated additional costs if you exceed the monthly download limits. Once you sign up with a Internet Service provider, their documentation will include setting up instructions and/or installation CD.
Mar 03, 2013 | Gateway Computers & Internet
How do I set up a wireless router on my computer?
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Nov 08, 2012 | HEWLETT-PACKARD Computers & Internet
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
I have F5D7230-4 router. Modem downstairs connected to DSL. Computer upstairs needs a wireless card to work This is a ''G'' router, but it only picks up signal upstairs with a ''B'' card which I stole...
The Belkin F5D7230-4 router should offer "Wireless G" connections,
unless you have used its built-in web-interface to only allow "Wireless B" connections.
So, if your "upstairs" computer, with a "Wireless B" adapter, connects, it will connect only at the slower "Wireless B" speed.
If you want "Wireless G" speed, you will need to purchase a "Wireless G" adapter.
Nov 18, 2009 | Computers & Internet
Unfortunately I live in an area with no DSL/Cable connection. So I am setting up my network via ICS with my main computer using a VodaFone 3G USB cellular modem. I need my computers and Xboxs to stop...
If you're using ICS the computer needs to have an ip of 192.168.1.1. Change the IP of the router to 192.168.1.2. You then need to tell the router that it's gateway is 192.168.1.1 and strictly speaking it should be set into "bridge" mode. It's a lot of hassle and slow and it's easier to get a Solwise 3g router which costs about £60. It will then maintain the internet connection and all the traffic flows in the right direction.
Nov 08, 2009 | Linksys WRT160N Wireless Router
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Problem with 2wire adaptor connecting to Avenue Broadband
Yes, The DSL connection and Broadband connection are different with each other.
You'll needing to reconfigure the router as Dynamic and clone the MAC address so that it will recognize to the network.
- Try resetting the router and reconfigure the settings of your router.
Mar 05, 2009 | 2wire HomePortal 100 Network Adapter
Quick Question regarding a set up
correct you only need a wireless card or usb adapter is it a laptop or desk top unit? in any case a wireless adapter should do just fine
May 04, 2008 | Linksys Wireless-G WRT54G Router
Wireless Connection
You didn't specify if you're using DSL or Cable internet.
With DSL, keep in mind the software on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer1.gif that has the software installed (verizon1.gif, etc) will be able to connect.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Jan 09, 2008 | Linksys Wireless-G Broadband Router
How do i configure my Belkin router to work with Sky broadband?
I'm not into hacking what I cannot find on ISP's sites
From what I can gather from the Sky Broadband site reading the manual installation procedures -- the process is pretty much automatic when it comes to installing their equipment leaving no clues as to how they configure it. What is the model if the Belkin router? Options probably exist to attach your device to theirs either as a router (establishing a second network behind theirs) or an access point joining as a member of their network - meaning there would would be two wireless networks in either case in the house (as there are no indications I have found on the site that the provided the sky router can be configured in any way such as turning off wireless). At least according to the documentation the sky router's wireless is running WPA-PSK security / encryption which is good -- and the documentation for attaching non-sky wireless adapters appears to be documented here.
Sky Setup
Dec 15, 2007 | Computers & Internet
Linksys Wireless-G WUSB54G 802.11g/b Logo
254 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
