Question about Refrigerators
Temperature is rising up to +10Centigrade to bottom part.
The temperature rises on the bottom part(frezer) and the alarm keep ringing for sometimes then goes off. The upper part (fridge) does not work at all.
  • 833 Answers
Defrost the unit completely.  This could be a freeze up.  Ice has blocked all of the air channels and likely jammed your fans.  Minimize opening the unit, in general.  Don't allow large amounts of liquids to evaporate in the unit.  If this doesn't provide a permanent solution you have either low gas or a bad defrost system.  Both usually require a tech to fix.
Posted on Nov 20, 2008
My freezer has had ice built up on the bottom shelve for about a year now. It leaks once in awhile, what can I do?
The power cut may have damaged the compressor. If it overheated trying to restart it may just click on and off for a while. Check if the compressor is hot and running.
Jul 11, 2015 | Bosch B22CS80SNS (220 cu ft) Side by Side...
How can I Stop the bleeping on my CDA FW 381 freezer. It alarms for approx 30 seconds,but I dont think the temperature is rising. Can I isolate the alarm.
You need to use a thermometer to be sure but realize the alarm indicated a certain temperature point has reached or exceeded, not that the temperature is rising.
Try these links for additional help.
Redirect Notice
Beko CDA 565 FS Manual
Mar 02, 2015 | CDA Freezers
Alarm keeps going off
Alarm will sound if the temperature of the freezer rises to unsafe levels. An indicator light will flash and continue to flash until the temperature reaches a safe level. The buzzer will also sound and will continue for 48 hours unless a safe condition exists.
Dec 14, 2010 | Kenmore Freezers
Hi my subzero 650 refrigerator temperature keeps rising up to 42 degrees. Even after manually loweing the temperature it continues to rise again. Whats the probloem and how can I fix it?
If your refrigerator has an electronic control board, this could be the problem (fresh food compartment control on the board). Or there may be a problem with the damper assembly that opens and closes allowing cold air from the freezer compartment (if available on your particular model). In either case, consult an appliance service company.
Feb 10, 2010 | Sub-Zero 650 / O Bottom Freezer...
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
Its copier (ir2016j)to desply writh system error. wath is this problem?
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation err
Dec 17, 2009 | Canon Office Equipment & Supplies
The freezer temperature changes sporadicaly. It
The temperature would charge due to change of cycles in the refrigerator operation. For example, the temperature would slowly rise if the compressor has shut off. Also, the temperature would rise significantly during the defrost process. A heater is activated at the evaporator coil to thaw the ice that forms there. This heat would transfer to the freezer unit and would cause the temperature to go up.
As long as the cycles are constant, and the temperature does not rise significantly and keep rising for a long period, there is no problem.
Oct 19, 2009 | Refrigerators
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
