Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Headset jack the headset jack seems to be loose and non-functioning. i've tried multiple headsets but in order to hear anything, i must fiddle around with the plug in the jack. would like to know where i can take it to have it fixed. Thanks...
    President:
  • 4,402 Answers
Http://www.zenrepair.com/Zen/index.jsp
http://repair4player.org/disassembly_creative.html
Posted on Apr 08, 2008
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
Plantronics M175 headset makes crackling noises when speaking with it on and is not loud and clear.
The 2.5mm jack on your phone, that the M175C plugs into, is more than likely causing you the problem. The phone manufacturers do not dedicate a lot of power to the 2.5mm jack, so sometimes people have a hard time hearing you or you hearing them. If you are using a cordless phone, you could use a Plantronics CS55H wireless headset. This headset is intended for only one phone line, not multiple lines. The CS55H's TR1 plugs directly into the wall jack instead of your cordless phone. This eliminates using the 2.5mm jack on the handset that is causing you problems. The headset come with a one year warranty.
Plantronics CS55H Wireless Headset
Good Luck from Headsets Direct!
Jun 22, 2011 | Plantronics M175 Headset
The headset symbol is showing on my screen on my N97 and I dont have a headset connected at all, when people ring me they can hear me but I cant hear them because apparently my phone thinks there is a...
The headset jack is jammed.
Try blowing some compressed air in there and also insert a headset plug and wiggle it about to see if it knocks the stuck bit loose.
Mar 05, 2011 | Nokia N73 Cellular Phone
Xbox 360 Controller: Headset jack on my Xbox 360 wired controller isn't...
try taping it down.
If this doesn't work, you're probably stuck buying a new headset.
May 16, 2010 | Microsoft Xbox 360 Controller
My headset is grounded
pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
Jun 12, 2009 | Cell Phones
I think my phone is too old to hook up to the amplifier.
My co-worker fiddled around for a bit and finally we made it work. He plugged the amplifier into the jack for the phones handset, and then plugged the handset into the phone.
The headset we then plugged into the amp. This seems so simple, it would be great if I had been told this by our tech cupport team, maybe we would have had it hooked up sooner.
thanks!
Apr 14, 2009 | GN Netcom GN 8000 Amplifier
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Headset sign
(Plz.read fully)
Hai friends,let me first inform u that how your nokia 6630 detects it's headset.
There are 13 connector pins at the boottom of yr cellphone.4 for usb connectivity,others for headset,mic,switch,antenna(not in order).
The first pin from left(plz. neglect the isolated pin near to the edge) is ground
(-ve) and the second one act as a sensor for detecting headset is connected.
When the normal headset jack is plugged in, it short circuits the ground pin
Aug 12, 2008 | Nokia 6630 Cellular Phone
Headset plug shorting out
it could be solder connections on the jack,its usually the headset itself, try another headset.
Mar 23, 2008 | Panasonic KX-TG5431 Cordless Phone
GN Netcom GN 9120 - can't hear
Hi There, I had the same problem with a headset one of our call centre reps were using. It's usually due to some one fiddling with the button. I got it working by removing the battery from the headset then resinked the headset to the base unit. Hope it works for you
Jan 30, 2008 | GN Netcom GN 9120 Professional Headset
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
