Question about Epson PLQ-20 Matrix Printer
How i can change the settings of epson plq20 printer?
  • Anonymous Mar 27, 2014
    kkkkkkkkkkkkkkkkk
Turn Off the printer and as soon as u turning on the printer press F1 and F2 simultaneously then it will ask for language selection and it will give you options to change and you can continue changing the settings.
Posted on Jan 29, 2009
  • yousef448
    yousef448 Feb 18, 2012
    I have a PLQ-20 and when i print the setting , it shows it in Chinese language , How can I change it to English? , it just have 3 buttons and no Panel
Garbage printing issue in Epson PLQ20
It sounds like you need to go to menu and set the correct language. If it is set with foreign language you will get garbage characters!
Nov 14, 2015 | Epson Office Equipment & Supplies
Epson PLQ-20 is not power on. Then how to power on printer?
printer power problem no powering on (epson plq20 printer supply show digram and layout of both side please send me
Dec 19, 2012 | Epson Passbook PLQ-20 Matrix Printer
How to change from serial communication to parllel com mode
OS settings to change port ---------------------------------------Click Settings > Control Panel > Printers and Faxes > Select your installed printer and right click on it > select properties > Ports > change serial port to parallel (COMx to LPTx)
Printer Settings to change port-------------------------------------------------Click here for EPSON user manual and refer page number 36 for printer settings. Change I/F mode to parallel (Interface mode) as instructed by Epson.
Feb 17, 2012 | Epson LX-300 Matrix Printer
Printer doesn't accept the paper,power led only glow
It's onboard failure message(eeprom, rom, or microprocessor), just replace your mainboard and calibrate the machine. It solve the problem, perhaps.
Jan 19, 2012 | Epson Passbook PLQ-20 Matrix Printer
I Have A Epson PLQ-20 passbook Printer and it is connected through USB cable. after successful setup when i give print command to the printer it is not responding and nothing happened.
Sep 20, 2011 | Epson Passbook PLQ-20 Matrix Printer
Epson PLQ20 Passbook printer Problem:"comunication Error"
Hi, Check your cable connection. Check for updates from Epson. Restart your computer . Good luck.
Jun 24, 2011 | Epson Passbook PLQ-20 Matrix Printer
A PLQ20 passbook printer is not accepting passbook or another paper
Hi, here are two possible solution, kindly follow me and resolve your problem.
You mean that you load paper into the printer tray, but it doesn't pull it into the print, though it's acting like it should, and you get an error on the printer, then most likely your paper pickup/feed from rollers, it may possible that the problem is dusting or worn out. You can try to clean them with a cloth and water or alcohol, otherwise they may need to be replaced.
If your printer just doesn't see that it has paper and gives you a paper out error, then you may have a sensor problem in the printer, or the printer is expecting a different paper size or paper from a different input than what is loaded (depends on the printer), then you may have a programming issue.
I assure you that your problem will resolve easily.
Good Luck
Feb 24, 2011 | Epson Passbook PLQ-20 Matrix Printer
How to calibrate epson plq20 passbook printer
pls help how to calibarate plq20 passbook printer
Apr 15, 2010 | Epson Passbook PLQ-20 Matrix Printer
Epson PLQ-20 Matrix Printer Logo
1,500 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
