Question about ASUS M2N-E SLi Motherboard
Microphone didn't work in Window Vista but work in Window XP,why?
It wasn't loud to outside when i spoke with microphone in Window Vista but in Window XP it loud to outside. so how should i do? can you resolve this problem?
  • YADIN Nov 20, 2008
    Ok, now it worked properly...thank you!
  • YADIN Nov 21, 2008
    now, i have problem again but this time with Vista in DELL because DELL the sound didn't like SONY..
  • 685 Answers
Try updating your microphone driver
Posted on Nov 19, 2008
  • Juanita Vega
    Juanita Vega Nov 20, 2008
    i'm glad it worked if you need help again just come to fixya.also it would be nice for you to rate for the solution
  • Juanita Vega
    Juanita Vega Nov 21, 2008
    need the type of dell is it a laptop or desktop and model
Does the emachines e525 have an internal microphone
high definition audio device not plugged in
Nov 12, 2011 | Computers & Internet
My microphone does not work, the headphones work though...
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In the Sounds & Audio Devices Properties window locate the SOUND PLAYBACK box and click the VOLUME button. Make sure that there is not a tick (check-mark) in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Also make sure that the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
However - if you cannot get enough volume on the microphone you may need to purchase a pre-amplifier to boost the signal strength before input to the computer.
Feb 10, 2011 | Logitech (980240-0403) Microphone
How to switch on microphone?????????/
First, confirm your laptop has a microphone. I am assuming, as you have posted your question, that it does.
Go first to your Control Panel, switch to classic view if you are using XP and small icons if in Vista or Windows 7. Look for some icon such as Sound or Sound and audio devices and click to enter it.
Now here is some divergence in methods.
XP
Enter the tab near the top of the window labeled as Voice. In the Voice recording section, confirm that there is a Default Device. If there isn't, click the drop-down arrow and choose on if there is one available. Sadly, if there is not, then I do not know how to help you. My expertise lie more in Vista and 7.
Vista & 7
Once inside of Sound, enter the Recording Tab and look for some type of microphone. Double click on the Microphone and at the bottom of the screen, there should be a "Device Usage" area and click the box next to it and choose "use this device (enable)" and click ok.
Hopefully one of these two methods should get your microphone working. I apologize if it doesn't. More information on your part may be helpful.
One last side note. There are two jacks on most laptops. If you are using an external microphone, you may be plugged into the output jack as opposed to the input.
Jul 14, 2010 | HP Pavilion dv1000 Notebook
Cannot get microphone to work while connected to computer.
I found this on the Turtle Beach website: ________________________________________
Let's make absolutely sure that the microphone in your headset is working correctly. If the mic is working, a replacement talkback cable should fix it. If not, then please send in your name, shipping address, the name of the store where you purchased your X1 and the date (month/day/year) of purchase.
OK, here's how to test the X1 using the Microphone input on your PC:
1) Take the pink plug from the X1 and plug it into the pink jack (Microphone input) on your PC's soundcard.
2) Take the green plug from the X1 and plug it into the green jack (Front L/R Out or Line Out) on your PC's soundcard.
3) Take the USB plug from the X1 and insert it into a USB port on the PC (not a USB hub, please).
4) In the soundcard's control software, enable the Microphone for playback. In the Microphone > Advanced settings, enable the Microphone Boost. Make sure the Microphone is not muted (Mute switch is not enabled).
5) Adjust the volume for the Microphone to about half-way up.
6) Adjust the overall playback volume to about half-way up.
7) Put on the headset. Make sure the Mute switch on the X1 amp box is not set to Mute (the LED should be green).
Now speak into the microphone. Do you hear your voice in the headphones? If so, the mic works and your X1 headphones should be OK. If you still cannot get the X1 mic to work over Xbox Live, then you need to take a closer look at Dashboard settings and other connections, or check the integrity of your X1-Xbox Controller Cable.
In order to enable the chat make sure that the Mute button in the Off position. If it is on the ON position the Mic will not work.
Red = Muted Green = UN-Muted
_________________________________________________________________
If you're having trouble adjusting the Mic in Windows:
WINDOWS XP:
For Windows XP, there's a nice video on YouTube that takes you through all the steps of setting up your microphone: http://www.youtube.com/watch?v=Vissxo8furo
WINDOWS VISTA:
Please follow these instructions to configure your microphone within Windows Vista:
1. Left-click on the Start button. The Start Menu will appear.
2. Left-click on Control Panel. The Control Panel will open.
3. Left-click on the Hardware and Sound option. The Hardware and Sound window will open.
4. Left-click on the Sound option. The Sound window will open.
5. Left-click on Recording from the three tabs at the top of the Sound window. While in the Recording tab of the Sound window, you will see all options available for recording - Microphone should be one of them. (If you don’t see an option for Microphone, ensure your microphone is plugged into your computer using the jacks commonly located on either the front or back of the machine.)
6. Left-click on the Microphone option to highlight it. This will enable the Properties button toward the bottom-right of the window. Left-click on the Properties button.
7. You should see the Properties for your recording (input) devices. One of these should be Microphone.
8. Left-click on the Levels tab (or similar). Adjust the Level (Volume) and Mic Boost controls to at least half-way up. If your Mic Boost control is a simple check box, please make sure it is checked (Enabled). You should hear your microphone in your headset or speakers.
Once the levels are adjusted to your satisfaction, left-click OK and OK to save your settings. You can then close the Control Panel.
Your microphone should now be ready!
Apr 17, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
How do I get an internal microphone for my Gateway 510?
If u r using a vista there would be a option in control panel Realtek Hd Audio Maneger click and open it,
when u clicked on the microphone tab then it will show in the center of that window "Noise Suppression" On it mean click on it and then do recording without Noise with internal microphone.
Feb 24, 2009 | Gateway 510 S PC Desktop
I had problem with my computer that use window vista about microphone that didn't work properly but in window xp it work normal and the sound when i spoke so loud to out and in window vista not loud....
  1. Right click Volume icon next to clock in lower right corner of the screen.
  2. Click Recording Devices.
  3. Select Microphone from the list.
  4. Click Properties.
  5. Pick Levels tab.
  6. Move the slider as desired.
  7. Click OK twice.
Jan 16, 2009 | Computers & Internet
Vista Ultimate -Microphone on Cyber Acoustics Headset not working
Here you go http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_PM_1720&os=WLH&osl=en&catid=&impid go
their its the dell drivers page for Vista, download the drivers their for the microphone and you can
also download things you might need for the computer
Hoped this really Helped,
Thanks!
Dec 24, 2008 | Microsoft Windows Vista Ultimate Edition
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
ASUS M2N-E SLi Motherboard Logo
71 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
