Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
White corners SONY KDL52XBR6
(SONY BRAVIA KDL52XBR6) i whent throw two sony bravias in 1 week.the corners have a whiteish apperance on dark seens and when the room is dark, that is the only time you can see the whiteish corners. its like there are magnets around the corners.(there are no speakers around the TV) when there are brite seens or the room is brite you cannot see the problem, but everything else looks great. Thanks for you help.
    Genius:
  • Sony Master
  • 1,689 Answers
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Posted on Jan 31, 2009
KDL-52XBR6 T-CON decodering board
Usually it is t-con bad. You can find it here:1-857-237-12 LJ94-02383 Sony KDL52XBR6 T-Con module
link:
http://www.ebay.com/itm/170994317153?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Jan 19, 2012 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
My 46" Sony Bravia lcd has a dark patch in the
most likely a LCD panel failure suggest calling sony customer support and see about repair accomodation 1-800-222-7669
Dec 23, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
The television just went black then slowly faded to white starting at the right side of the screen, what happened? now it wont work at all and fades from black to white like i described every time it is...
in examining your question here about going from black to white with no picture at all would thorw the backlight and inverters out of the question. Things to check here:
1. Decoder board
2. LCD panel itself
I have seen where a lcd whent dark because of a back light. but from dark to light and no picture leads me to beleave you have a bad lcd .
I hope this gives you some idea your going to need to have a repair shop fix it ether way or buy a new tv in this case. I do not see this as a common problem in sony bravia lines.
Apr 14, 2010 | Sony BRAVIA KDL-46V3000 Television
Sony Bravia KDL 46V100 has only black & white picture-no color
I bought Sony Color Bravia TV 60 inch, moved with it Kenya, Africa, when i try to tune the color is not coming. I can only get black and white. Please anybody with idea on how to change it for Africa (Kenya). Model:KDL-52SS100. My e-mail. fredwagah21150@yahoo.com
Jun 30, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
LCD panel white corners SONY KDL52XBR6
Back - light problem; common fault to this model TVs. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 05, 2017 | Televison & Video
HDMI into sony bravia
plug in hdmi cable turn ps3 off then on wait and a message will apera click yes then another message appers then click yes then it should work if not connect with the red white yellow plug and then change the settings to hdmi and plug the hdmi cable in
Sep 06, 2007 | Sony Playstation 3 (PS3) Console
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
434 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
