Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
No Audio with WinTV-HVR-1600 when tuning on S-Video
OS: WinXPCamcorder: Sony CCD-TRV88connected via S-Video cable
loaded latest drivers from Hauppauge website v4.6a
Video playback is clear w/ full color just no audio.
suspect a bad card.
Okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
Posted on Nov 21, 2008
I have a HP Media Center PC 470n. Is there another card just for that PC. I have the wintv- hvr 1600,not as happy as I thought I would be.
You can use any capture card you want as long as you have a slot on the mother board. Media Center works with almost every capture card.
Having said that, i found hauppauge a great capture device what was it you didnt like?
Jan 06, 2010 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Nov 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Tv tuner
Basically what I can see from what I have read one had dual tuner capability and one is set up for PCI Express. Both look like great cards.
http://www.hauppauge.com/site/products/data_hvr1600.html
http://www.hauppauge.com/site/products/data_hvr1800.html
Thanks
Armymason
Feb 24, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
Nov 10, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
Oct 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Connection Hauppauge WinTV HVR-1250 tuner?
you are not going to get anything once you disconnected from the provider. It is the same thing as just pull the cable from the wall.
you can get TV signal (normal basic-brocasted) by using the roof top antenna, I don't know what kind of antenna will be require after 2/09. when the TV broadcast change to digital signal. but in the mean time, you need a converter box from analog to digital for the TV.
Nobody want to pay the monthly fee. if you have the equipment, you can set up the receiving station from the satellite. then you don't have to pay anything. As far as I know, no body have such equipment. cable company spend millions of dollars to set them up, so you have to pay for it.
Jul 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No color from VHS on DVD/VHS player
There may be an input selection between Composite and S-Video that needs to be toggled in your Hauppauge software.
Your Hauppauge card may also be in the wrong signal format mode (NTSC or PAL). Your source device and your Hauppauge card need to be in the same mode (both NTSC or both PAL) for the capture to work properly.
If your NV-VP33 is a SCART output, then you may need to check your SCART adapter and your device as not all devices output both S-Video (Y/C - two signals) and Composite (CVBS - one signal) type signals.
If your SCART adapter has both Composite and S-Video outputs, try the other one.
And finally... if you're playing an NTSC tape/DVD in a PAL player, it doesn't mean the output is true NTSC 3.58. Most times it's NTSC 4.43 which is OK for TVs, but NOT okay for video capture devices. Video capture devices need true NTSC 3.58 to sync the color carrier properly.
Apr 29, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I get problems loading my instalation disk .
try and go to the manufacturers website and downloading the latest drivers from them. Sometimes they have trouble with the drivers on the cd but obviously can't recall every cd, so they release the updated drivers online through their website.
Nov 20, 2007 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I have problems loading my wintv version3.3b
first down load the update. when you get that open the zip file. then look for hcw clear.exe and click it . it will clear every thing and ask to reboot. then cancel all devices found after reboot. open the folder and click hcw drivers install, when that is done then click setup. hope this helps
Open Questions:
See all Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / Questions
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
393 people viewed this question
Top Hauppauge Televison & Video Experts
Iqbal Husain
Iqbal Husain
Michael Galve
Michael Galve
jason
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
