LCD panel white corners SONY KDL52XBR6
I have gone throw two sets of sony braveas in one week with the same problem.The picture has whiteish corners and sides. You can only see this when the room is dark (lights off) and the screen is dark (dark seen).I connot see this problem whan the room is lit up or on brite pictures, but everything else looks great?????.almost like there is a magnet close to the corners if the screan. sometimes it looks like the whiteish colour moves towards the centre of the TV. Please help.
    Top Expert:
  • Televison & ... Master
  • 75,169 Answers
Back - light problem; common fault to this model TVs. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Jun 05, 2017
2 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: white corners SONY KDL52XBR6
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Posted on Jan 31, 2009
KDL-52XBR6 T-CON decodering board
Usually it is t-con bad. You can find it here:1-857-237-12 LJ94-02383 Sony KDL52XBR6 T-Con module
link:
http://www.ebay.com/itm/170994317153?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Jan 19, 2012 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
I am having the same problem with my 3 yr old 52 inch Bravia HD LCD TV. The right side of screen starts out darker than the left side and then in about 5 minutes it brightens on the right and has...
To be honest, it won't be a cheap repair. You could be looking at an aging backlight inverter or possibly the CCFL bulbs that light your tv are aging as well. The backlight inverter would be nearly $60-$90 and the CCFL bulbs are close to $20 each @ 12-14 of them.
Please rate if this helped :)
Mar 09, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
How to fix scratches on lcd tv screens what is the best way to fix scratches on a sony kdl52xbr6 tv screen or do I contact Sony directly
If there deep scratches you need to replace the outter layer and that could get expensive. Now if there small scratches a lcd repair kit would work. You can get those on line for the fraction of the replacment of the lcd screen.
thanks
please do leave feedback and ratings for your free answer today.
May 03, 2010 | Sony BRAVIA KDL-52XBR6 LCD TV
I laid my sony bravia lcd tv kdl 26s3000 down on the ground while it was on and now the screen has gone white and there no picture, but i can still hear sound, what has happened and how can i fix it ?
You will need to take covers off and physically check all cables and connectors see if any were dislodged. Pay attention to the ones that go to the lcd panel itself
Jan 07, 2010 | Sony Bravia KDL-26S3000 Television
Sony Wega 42" LCD w/Bright Blue haze at bottom corner of screen
hello it sound like convergance may need setting go in to the menu click on convergance you should be able reset the picture
good luck
shaun
May 14, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
White corners SONY KDL52XBR6
Jerry G.
Nov 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony LCD Grand wega black and white picture
12000 hours you are lucky most last 2000 hours
lamp not the usual suspect for this
confirm black and white on all inputs and it will be more sinister, if only one input, it could be the signal source
Jun 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony 61" lcd has bluish spots in screen, any ideas?
Hello, inside the set there is an optical unit with 3LCD panels. Somehow the dust particles came into your set and now the dust is all over the optical unit and 3LCD panels. Only way to solve this issue is to clean the dust. Please contact your Sony dealer. Best regards, Arpi
Jul 10, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
