Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
The file system of my hard drive become RAW.
My WD My book 500GB hard drive suddenly stop working. when i check the properties, it shows the file system become RAW.
How to fix this??? anyone, please help.
  • 3 more comments
  • Anonymous Nov 28, 2008
    after re-install XP on my Laptop... My WD external hard drive stop working. It does recognise on Icon tray but doesnt show up on "MY Computer". After Rename the drive letter.. it appear but when i tried to open it.. windows doesn't recognise it.. says "Do you want to format now".. "unformat or RAW drive" ... Please help!
  • Envy2107 Jan 06, 2009
    I have Western 500g External Harddrive and after working fine for 1 year it suddenly became FAT32 and I couldnt copy anything onto it. So i backed my files up and formatted it. (Not quick format). It took ages, about 15 hours, but at the end it said it windows couldnt format it. And now it has turn to RAW and wont let me format it at all. Can anyone help me please?
  • Anonymous Feb 27, 2009
    my maxtor one touch 4 mini 120 gb hard have the same prob, i have more than 70 gb on it, it was connected to the computer , and some files were open from it, and suddently the computer stopped responding because of a virus in the system so i reseted the computer and, the hard disk became raw and inaccessible.
    Read more >> Options >>
  • litunya Mar 19, 2009
    I gave a friend my 1GB flash disk to copy on photos. the disk on returning indicated RAW file system. I have tried to access it in vain and windows does not format it.funnly it indictaes 8mb capacity. help pls
  • mgriffen
    mgriffen Dec 12, 2012
    my Hitachi Deskstar 3TB worked fine for a year then one night I was having issues playing back video while transferring files onto it, I restarted my computer and when it booted up my 3TB drive was coming up as RAW files system and Windows was asking me to format it.. I installed HGST Disk Manager, my computer restart, Windows ran chkdsk and i sat and watched as it deleted all my filesystem indexes! Never buy Hitachi hard drives! and if you plan to run a data recovery program, don't let chkdsk run on your HDD! Now my HDD detects fine but its not showing me any of my data!
  • 395 Answers
Http://www.z-a-recovery.com/unformat-tutorial.htm
This tutorial describes the procedure to recover one volume when
  • the volume was accidentally formatted
  • Windows reports the volume is "raw filesystem", or "not formatted"
  • An external drive failed, either flash (so called "thumb drive") or an hard disk connected using USB or FireWire enclosure.
  • MFT is corrupt on the NTFS volume, rendering filesystem partially or completely unreadable
The recovery is done in seven steps, requiring about eleven (11) mouse clicks. Note: The older than current versions of ZAR might have been used to create the screenshots in this tutorial. We did not update the screenshots if there is no significant difference between older and current versions. If you see some option in the program which is not described in the tutorial, just leave it at its default setting.
The file system of my hard drive become RAW. - box-btm-l.gif box-btm-r.gif box-top-l.gif box-top-r.gif Download and install ZAR just like you do with any regularThe file system of my hard drive become RAW. - box-btm-l.gif/>When you run it, ZAR displays the wiThe file system of my hard drive become RAW. - box-btm-r.gif one below:
  1. Click "Next >>The file system of my hard drive become RAW. - plashkablue_right.gif box-btm-l.gif
    plashkablue_left.gif Step 2 - Select processing mode
    The file system of my hard drive become RAW. - box-btm-l.giftp://i.fixya.net/uploads/images/plashkThe file system of my hard drive become RAW. - box-btm-r.gifif" alt="plashkablue_right.gif" class="h_mi" /> box-top-l.gif The file system of my hard drive become RAW. - box-top-l.gif"http://i.fixya.net/uploads/images/t-uThe file system of my hard drive become RAW. - box-top-r.gifgif" alt="t-unformat-mode.gif" class="h_mi" /> The file system of my hard drive become RAW. - t-unformat-phys.gifmi">Select "Recover data from a simple volume or from a functional RAID volume"
  2. Click "Next >>"
plashkablue_left.gif Step 3 - Select physical device to recover
  1. Select the appropriate hard drive
  2. Click "Next >>" for a list of volumes (logical disks) on this hard drive
Posted on Nov 28, 2008
    New Friend:
Hello, I am sorry to hear that you also get this external hard disk RAW file system error. Honestly, last time, after attaching my external hard disk to a PC, I do find my external hard disk has RAW file system and cannot be accessed, too. In order to rescue my left drive files and movies, I do tried many portable hard disk RAW error recovery methods and finally have recovered most of my original drive files back at the aid of external hard disk RAW file system recovery software.
Hence, you'd better also read more related data recovery articles and get clues here:
External hard drive turns to raw file system
Learn more drive file recovery information
Hope these words work for you.
Posted on Sep 17, 2015
RAW hard drive problem is not difficult to fix.
In your case, you could try two ways:
1). To save the contents inside this drive, you can try to use some other data recovery programs.
Even though this drive has becomes RAW, you also could use some data recovery programs to take chances.
If you don't want to waste your money on this unsure thing, you could try some free drive data recovery applications at first:
http://www.piriform.com/recuva
Or http://www.freeware-fix.blogspot.com/2013/02/hard-drive-recovery.html
Note: You'd better not save anything else on this RAW drive in case of data loss.
2). To save this drive, you could try to format it into NTFS or FAT32.
RAW file system often cannot be read/write under both of Windows and Mac OS. That's why one is always asked to format it into NTFS or FAT32 file system. (These file system could be easily read/write under Windows OS.)
Note: If this formatting process also could not save this drive, you have to replace it.
Posted on Jul 24, 2013
Wd 500gb hard drive is not shown any power it was working fine suddenly when i try to connect to my laptop nothing appearing. plz advice
Good day, this video tutorial will help you to recognize your WD 500GB. Just follow instruction and your problem will gonna fix.
Jul 30, 2011 | Western Digital My Book Essential 500GB...
Seagate 500 GB external hd that suddenly changed from NtFS to RAW
You can use a utilities like partition recovery to try to recover the previous partition.
Sep 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
WD 500GB light is on but my computer can't find a source
Verify and check by hooking it up to another pc. If another PC cannot connect or find it may be toast.
Aug 02, 2009 | Western Digital Passport WDXML800UE...
WD external Hard drive
sounds like a conflict to me.
controll panel / system / hardware tab / device manager. then find the device and right click / properties.
Jul 14, 2009 | Western Digital 500GB My Book World...
Help!! Western digital 500gb external hard drive ticking noise
Yes. This is going to sound strange. Put the drive in a plastic bag and put it in the freezer. Next day, take it out, hook it up, and see if it is recognized.
If so, under My computer, right click on the drive - click Properties - then Tools, then Error Checking. Check box Automatically Fix File System Errors. Let it run. If everything shows up, be ready to transfer wnat you want off of it.
Freezing shrinks the metal parts . Microscopically, but often enough to get stuck parts free enough to get working.
I just went through this with a 750Gig Book. now i have reformatted the drive (after transferring all over to new drive) and the clicking is gone and all disk checks are fine and i wonder whether to trust this device ever again... Hate to just throw out a large drive.
Mar 10, 2009 | Western Digital My Book Essential 500GB...
When i click my hard drive, it tell me to format it. ????
have you try to connect it to a different computer?
if yes and getting the same problem you need to call your WD for the warranty and replace it. if your up to your files inside your storage i guess they will endorse you to their third party company that will recover your data storage and it will cost a lot.
Nov 18, 2008 | Western Digital My Book Essential Edition...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
14,940 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
