Question about Hotpoint WMA58 Front Load Washer
Changing front loader seal
How do i get into the machine to change the door to tub seal
  • Anonymous Mar 24, 2014
    How to change door seal on wmf720 washing machine
  • Anonymous Mar 28, 2014
    Change door seal
The way i done it was open the door take take the wire band of around rubber seal__as in picture one.__2 take top of machine of and take spring of as shone in picture 2 you shold be abble to take silver band of around rubber seal
Posted on May 07, 2007
2 Suggested Answers
  • 1462 Answers
SOURCE: changing front loader seal
easy.isolate from mains. take top off.remove clamp that holds seal to cabinet and unpeal seal from cabinet. seal is held to tub by a clamp (like a huge jubilee clip) undo and peel seal from tub. when fixing new seal, lubricate with washing=up fluid
Posted on Mar 19, 2007
Replace door seal loader washing
This video will show you how to change the door seal on your bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
How do i fit a new door seal to a bosch washing machine
This video will show you how to change a door seal on this Bosch front loader washing machine
Aug 22, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Change door seal
For most front-loaders:
Lubricate the slot which fits over the tub with washing-up fluid. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Pl rate me nice for the free help!
May 21, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
How to change door seal on hotpoint FEW12 washing machine
Mar 28, 2010 | Hotpoint First Edition FEW12 Front Load...
How do I replace the door seal to a Bosch Front loader washer Maxx Classic WAE18060AU?
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Feb 18, 2010 | Bosch Classixx WFO 2466 Front Load Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
Dec 22, 2008 | Neff W5340X0 Washer
Dec 11, 2006 | Hotpoint WMA58 Front Load Washer
Hotpoint WMA58 Front Load Washer Logo
481 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
