Question about Canon imageRUNNER C3200 Copier
C3200 COLOR PROBLEM
Dear spinal, your help is great best on the net
I have a cannon c3200 copier and i'm getting a large 4 inch splash of all 4 colors down the center of 11x17 copy, I'm not printing from the computer i am copying. Can i email you photos of the images this copier is used in a training center for kids i volunteer there. Also how do you get in the service mode on the machine? Thanks for your help.
maria
cdromtv@email.com
  • 67 Answers
3 possibility 1-your secondary transfer is dirty or needs changing 2- your primary transfer sheed is damage or your fixing assy. is damage go with number 1 first try cleaning with a clean dry rag then blow away any lint. for service mode press and hold additional function at same time hold down 2 and 8 then add function again
Posted on Nov 22, 2008
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
WHERE DO YOU FIND METER FOR CANNON IMAGE RUNNER 5180
Hello jen,
Look on the operator control panel and you will see a little button below the power button. It says counter. Press it and look at the counter named "101". This counter represents the sheets of paper (regardless of size) that have successfully exited the device. The other counters you see, well, lets just say they are of no value. Now you could have a tech come out and "configure" the counters you see.My company sets the device to display "102"(counts 11x17 as 2 clicks), "109"(just black and white),"124"(color). Have a good day and please let "FIXYA" know I helped you. :-) SPINAL
Mar 18, 2011 | Canon imageRUNNER C5180i Color Copier
Setup up network scanning on a Cannon IR3225
you must install color network scanner then set it!after that install app (like adobe 8 professional,Corel X3,abby fine reader)!!!
1.open adobe(or other app)
2.select ,,import file from scanner"
3.select ,,network scan gear"
and...this is it!!!!!!!
Apr 06, 2010 | Canon imageRUNNER C3200 Copier
Hello, I have a problem with my c3200! looks like yellow, and color looks faded. The image I'm trying to print looks all faded. Any help would be great thank you for your time
Try running the gradient/color adjuster (do a full test). It's in Additional Functions screen.
The C3200 series is known for this and many other issues. Most of the customers that I met has since switched to a Xerox color machine that has much better results (Docucolor series for print shop/marketing type work, and the WorkCenter 7600 series for high end office work. Both same body design, different engine/system software)
Nov 25, 2009 | Canon imageRUNNER C3200 Copier
ImagePass-C1 Not Printing the Pantone Colors
you need a set of kodak cards to run full colour set up on your fiery print controller then you just follow the intructions
Oct 29, 2009 | Canon imageRUNNER C3200 Copier
Error Code E000020-0225
Wedm/Craig. I will glady help you, and I am extremely confident that I am correct. More importantly I wish to to help you avoid The "COPIER DUDE COMPANY" taking a large chunk of your cash. I work for a "COPIER DUDE COMPANY" and we charge $200 just to say "yep, you have a problem". So lets start from square one and please forgive me if I get long winded and redundant. You tagged onto a request for help initiated by a customer called Brassmonkey who had a code of E000020-0181.This code means that when the copier attempted to calibrate each color (cyan,magenta,yellow and black) as it does from time to time to maintain optimum copy quality, the target values for yellow could not be achieved. Not even close. Yellow is the first color the copier checks and is used as a reference for the rest of the color calibration.Therefore it tends to be the primary error code in the event of a problem. Now here is where it gets hairy. Hang with me here. A patch of color is placed on what is called a transfer belt. This belt is where the image/copy is created prior to it being transferred to the paper. In fact, there is a point in time where the color copy you requested exists on this plastic belt, held by a staic charge, and is waiting to be pushed onto the paper as it goes through the machine. So when the copier goes thru periodic calibrations, again it makes a yellow "patch"....looks at it....... reajusts....looks at it... until it hits the optimum target of quality. And it does this for every color. So, now to the NUTS of it all. You have a drum&developer "unit" for each color.One dual unit for each. They are fed toner as they need it. Any one unit can fail due to shear normal use,and this is not a function of toner.{I have seen weird shit that defies logic before but toner is on the wierd shit list} Now, at some point the "plastic transfer belt " fails. So no matter how new the drum/developer units are, the "medium" from which the colors are being judged by cannot provide a valid measurement. Its like an old guy like me trying to read small print with scratched glasses. New text does not mean I can read it better. So now you have an 000020-0225 code. This means that the magenta color calibration failed.This tends to lean toward the transfer belt(scratched glasses) being worn. Two color calobration failures make ya wonder. Canon says that under the best of conditions the tranfer belt is good for 300K. These are all remote troubleshooting suggestions but at least you will have the benefit of these details. And the transfer belt is A: not real expensive and B: not labor intensive. I hope this helps. Good luck and take care. ............SPINAL........
Feb 25, 2008 | Canon imageRUNNER C3200 Copier
How do you replace the waste Ink tank on a Cannon Multipass F80 All In One printer?
Hello Ms. Gonna really need to know the model because there are vast differences between the the large family of Canon devices out there. I truly would like to help so any additional info would be beneficial to both of us. I'll be listening,to quickly and happily help you. ,,,,,,,,******* spinal*******.......
Feb 20, 2008 | Office Equipment & Supplies
Olevia 32" Video question
if unit is still under warranty, utilize it. otherwise your y-sus bd is failing. the problem will get worse. hope this helps.
Feb 18, 2008 | Olevia LT32HVM 32 in. LCD Television
Copy Problem
this could be two things first, the transfer belt is slipping. It can be cleaned on the inside of the belt and the rubber drive roller. second, the laser units need to be timed, its not hard to do but a service tech will need to do both. it should be running great. the 3200 is a great box
Dec 06, 2007 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER C3200 Copier Logo
74 people viewed this question
old marine
old marine
