Question about Toshiba 14AF44 14" TV
Toshiba 14AF44 14
The tv turns on but the channels or scramble and the cable wire is hook up and working, there is sound sometimes and no sound at others. When you go on the settings and go to the tv or cable option u see one channel appearing slightly in the back ground (which indicates that cable is present) When choosen the option (ch. program) it deletes some channels at times when completed and still no cable appears. I believe a button was press on the remote.. can u help plz?????????? anyone..... Thank you.
Yea thanks... already dumped it in the dump....tech said something with the voltage was gone...
Posted on Mar 23, 2007
    Genius:
  • 1,074 Answers
Checks sould be made in AGC circuit.and the related crcuits like the virtical ciruit and the horizontal circuit.the picture iis syncronizing.have a tech look at it to see if the operating voltage are correct and replace components.good luck
Vizio 32" tv led why some channels scrambled
if not the cable source then the MAIN pcb (not power pcb) controls all tuning. If you're using a cable box & some channels good/some channels scrambled, then is a cable issue.
Sep 08, 2014 | Televison & Video
We have Toshiba Regza 52XV645U. We have dish network hd channels and ever since hd channels were installed after tv plays for few hours the speakers get a funny sounds like channel sound is scrambling. It...
This sounds like what may be causing it is the cable going from the tv to the receiver box. If it is only happening on the sat channels, you know that it's not the tv. I would replace the cable, if that does not work, then it may be that the receiver needs to be replaced.
Becki Barned
DISH Network Customer Service
Dec 16, 2010 | Toshiba Regza 52XV645U LCD TV
I'm connected to a dish network receiver and the picture was good until my son tried to plug in his playstation 2. Now everything is back to the way it was originally installed except there is a scrambled...
Hey there. You want to make sure that the cables are tight on the back of the receiver and also that the tv is on the correct channel or input. Sometimes, if the tv is on the wrong input, you can get the picture, but it will look scrambled. So if you are in the room with the receiver box, you want to make sure that the tv is on channel 3 or 4, and sometimes on an input like Video 1 or 2. If on the secondary tv, you will want to make sure that the tv is on channel 60 or 73. I hope that this helps. You can follow this link below if you need more clarification.
http://www.dishnetwork.com/SupportSection/bbs-screen
Becki Barned
Nov 16, 2010 | Insignia IS-LCDTV32 32 in. Television
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
Basic cable scrambled on ANT input but not PIP
it sounds like you have the common problem with these models. The poblem has occured so offten that toshiba issued a service bulliteen about it. There is a problem with a cuircit board called the Hypermodule its a signal processing board/ the ideal situation would be replaced this board but it has happen so much it may be difficult to find this ooard so this board can be repaird. The secound problem is to fix this board 11 very very small parts called capacitors need to be replaced. i have also replace these and only someone advance in solder should attempt it very small. twezers and magnifer. You can hire someone but it very labor intensive. Our shop charges 300 just in labor It can be fixed but I would adviise its just no worth it
Dec 09, 2009 | Toshiba 42H81 42" Rear Projection...
Picture scrambling and no sound.
inspect your cables your a/v cables make sure there is no breaks in the cable at all if using a rf adaptor please make sure you are on the right channel and the rf adaptor is also on the right channel.
you may need new cables and if that does not work then its something internal on the unit.
Jan 15, 2009 | Nintendo 64 Console
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Cable setuo for model 27r410t
Get an antenna hooked up, even rabbit ears should pull in a few analog channels. Set top boxes will only output Ch 3 (switcheable to ch 4 on the back if needed) and cable may be dead or only give you scrambled CATV channels. You need to set your tuner to "antenna", not CATV, IRC,HRC, or ATSC (if you have a digital tuner) and do the setup again. You could have a bad tuner at worst, and all is not lost, just hook up a VCR via RCA cables and use the VCR tuner to change channels. Keep TV on Ch3.
Feb 12, 2008 | Televison & Video
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
My hdtv component jacks will give a clear pic then pop back and forth into double images. Can anyone help?
Oct 03, 2007 | Philips 60PP9202 60" Rear Projection...
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Oct 03, 2007 | Televison & Video
Toshiba 14AF44 14" TV Logo
128 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
