Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Error code E602-0003
Recently my machine displayed the above error code yet it was in proper working c condition before. how do i over come this problem/ am stuck. patrick
  • 3 Answers
An e602-0003 is the hard disk drive.
Posted on Dec 29, 2008
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Tip
Whirlpool Calypso Washing Machine Error Code Explanations And Repair
Failure - Code Condition - Check/Repair
PF - Power Failure - PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR- Press STOP/CANCEL to clear the display and completely cancel the cycle.
FL - Flood Condition - FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
ER - Processor Reset Error - This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
LF - Long Fill - If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
CE - Communications Error - If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
  • Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
  • Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
  • Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
  • Drive motor thermal protector has opened.
  • Motor controller is not powered or fuse has opened. Replace motor controller.
LD - Long Drain - LD flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
CA or CL - Average current limit or Instantaneous current limit - If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or CL for instantaneous current limit trip.
  • Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
  • Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
OB - Off Balance - If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an OB for Off Balance.
The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
SR - Stuck Relay - SR signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
The machine control board may have a bad relay and may need to be replaced. Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller. This should have AC line voltage when the motor controller is powered.
LS - Lid Switch Error - The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
on Jul 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/09 error code on...
The error F/09 is shown on the display due to Overflow Condition detected in the washing machine.
In this problem check pressure switch , Drain Pump and also check is the door getting properly closed.
This will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
In display shown FE
"FE" error code - over flow error
-Check water conection
-Check Water valve for proper operation
When the "FE" error code is displayed the drain pump will be turned on to pump the water out of the washing machine. LG Washing Machine Error Codes
This error code comes up when there is a over flow condition. The error is coming up because a part inside the washer has failed. I suspect the water valve on the back may be the culprit, it's fairly common.
Hope helps.
Aug 10, 2011 | Washing Machines
My washer begin washing but the stop and has the code lp what sim to be the problem?
This are the only codes for your washer. hope this help. WHIRLPOOL Calypso Washing Machine Failure Code Condition Check/Repair "PF" Power Failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle. "FL" Flood Condition "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
Press STOP/CANCEL to clear the display. "Er" Processor Reset Error This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. "LF" Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display. "CE" Communications Error If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display. "Ld" Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. "CA"
"Cl" Average current limit Or
Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip or "Cl" for instantaneous current limit trip.
Press STOP/CANCEL to clear the display "ob" Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for Off Balance
Press STOP/CANCEL to clear the display. "Sr" Stuck Relay "Sr" signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
Press STOP/CANCEL to clear the display. "LS" Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Feb 07, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Tip
WHIRLPOOL Duet & Duet HT washing machine shows F/H error code on display?
This error is shown on the display due to:--
Water not getting detected while entering the washing machine or
The other possibility is that the Pressure switch is got tripped but its not getting detected.
This happens because in 30 seconds if the control does not detect water entering to the washing machine then the valves will be turned off and the error code will be shown on the display panel.
To solve this problem you will have to check the drain pump.is it properly fitted or got loose or worn out or leaking. Also check the pressure switch hose is in good condition and properly connected to Tub and Pressure switch.
This will help.Good Luck.
Whirlpool awm 8142 faul code f06 ja and i start it again, the new fault code f09 and the machine stops... whats wrong whit it!
F/06 error code, Drive Motor Tachometer Error
F/09 Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
~Check the drain hose and make sure it is not plugged or inked.
~Check Wire Harness connectors to the Drain Pump, Pressure Switch, and ~Central Control Unit (CCU)
~Check/Clean Drain Pump Filter of foreign objects
~Check for Drain Pump Failure
~Check the Inlet Valve for proper shut off
~Check the Pressure switch for proper operation
Nov 15, 2010 | Whirlpool AWM8143 Front Load Washer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
Error code 105
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2009 | Washing Machines
L S or L5 error code on Calypso top load washer (Color - grey)
LS Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
782 people viewed this question
old marine
old marine
